Old 05-21-2012, 12:28 PM   #21
Trashcan
My Ride: 2002 330ci
Originally Posted by Brinkley View Post
When I pulled my 325ci motor I pulled it with headers attached. Unbolt A/C compressor and sling from frame rail, will save you from having to open up the system, disconnect wiring harness at drivers side box sling on top of motor, the shift brace arm thing can give you trouble when pulling the engine/trans out, so remove that and shifter. Leave intake manifold on, but remove things like DISA, air intake elbows, air box, obviously the cabin air filter housing (maybe you've done all this, just trying to help). Have a helper for the engine removal and installation that will be invaluable.
I am not one to replace parts prematurely, but new clutch kit for sure, and if your starter is original, it will never be easier than now.
Reinstall as complete as possible, minus a/c of course, have wiring harness attached to new motor and as connected as you can, minus disa and maf, then you just reconnect in the fuse/relay box, headers attached. Be careful with the bolts to the head from the headers as you swap, remember head in aluminum so be sure they are threading correctly before giving them the beans.
Leave the intake manifold on? Its impossible to get to the to transmission bolts and rear engine lifting point then... Its already off anyway
Trashcan is offline   Reply With Quote
Old 05-21-2012, 01:12 PM   #22
Brinkley
My Ride: 99 328i, 07 z4 3.0
oh well if it's off then so much the better. Will make the job much easier, however upon reinstallation ( and I'm not saying that it was cake, but preffered over manifold/wiring harness install in the car) I had the intake back on with most accy's upon installation. It's not easy to get to that back engine hoist with manifold on once it's back in...but doable, I did it.
Brinkley is offline   Reply With Quote
Old 05-21-2012, 01:25 PM   #23
Trashcan
My Ride: 2002 330ci
How did you reach the top transmission bolts then?
Old 05-21-2012, 02:47 PM   #24
Brinkley
what do you mean? I installed trans out of the car, put the engine/trans back in as a unit, with the shift brace disconnected it will go, you'll have to play with the angle a bit, and go veryyyyy slowly. You will surprised what preassembly + patience on the reinstall will get you. I reinstalled engine w/headers, intake manifold, accys ( minus A/C of course, and power steering) wiring harness, along with trans. You'll need a hoist that will go high, and clearance above to crane that thing up.
Looking back on it, I should have replaced the starter while it was out.
Old 05-21-2012, 04:00 PM   #25
Trashcan
My Ride: 2002 330ci
So are you recommending I leave the transmission attached? Sounds easier to remove everything once the transmission is detached, plus giving a little more wiggle room.
Old 05-21-2012, 04:12 PM   #26
Brinkley
Well that's up to you. I certainly did it with trans attached, however either way will work, it would be easier to lower the engine onto the mounts w/o trans, but it is much easier to install the trans out of the car than in it. Of course, mount flywheel/clutch/pp first. The hard part about the trans is getting the clutch aligned perfectly and getting the trans to "plunk" in place, that will be easier out of the car, the clutch kit will come with an alignment tool, which will help big time!
Old 05-21-2012, 04:12 PM   #27
BeMyWhip
My Ride: 01 BMW 330ci
Ttttt
I would separate the trans. Mich easier to work.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 05-22-2012, 05:53 PM   #28
Trashcan
My Ride: 2002 330ci
Ok so i'm torn as to whether I should do the responsible thing or the fun thing. Group buy for vf engineering SC will get me what I've always wanted at a price I can afford, but if I order it I won't be able to get my control arms and bushings and everything for a couple months. But it's a price that's hard to turn down. Am I a complete idiot if I pause this project mid way through, set it aside and buy a SC for a car that currently is a pile of parts and not running atm?
Old 05-22-2012, 07:04 PM   #29
Trashcan
My Ride: 2002 330ci
Bump, somebody please share some sense with me so I know what's right to do
Old 05-22-2012, 07:10 PM   #30
NOVAbimmer
My Ride: E60M
do what's needed to the car, once the car is in good running order, then you can start chasing the dragon of more power
NOVAbimmer is offline   Reply With Quote
Old 05-22-2012, 07:11 PM   #31
Trashcan
My Ride: 2002 330ci
For 1k off retail price brand new you would still ignore the deal?
Old 05-22-2012, 10:50 PM   #32
Trashcan
My Ride: 2002 330ci
I'm thinking oil pump upgrade for now and supercharger, then control arms and bushings, then cooling system, then subframe, then LSD and then maybe I'll be content
Old 05-30-2012, 12:02 AM   #33
Trashcan
My Ride: 2002 330ci
Old 05-30-2012, 12:38 AM   #34
BeMyWhip
cool, love pulling motors!
GL. Keep us posted!
Always Mod!!!
Old 05-30-2012, 12:54 AM   #35
lab rat
My Ride: '02 330iT
Looking good.
Some useful info can be found in the thread in my sig.
Because sleeper
Old 05-30-2012, 01:44 PM   #36
Trashcan
My Ride: 2002 330ci
It's so empty
ID:	454019   Click image for larger version
ID:	454020   Click image for larger version
Old 06-01-2012, 04:30 PM   #37
Trashcan
My Ride: 2002 330ci
Probably not going to have time to start reassembly for 2 or 3 Weeks, but I got my parts in the mail today.
New control arms, new lollipops with bushings inside, oil pan gasket, dipstick tube o ring, exhaust manifold gaskets, water pump, both serpentine belts, left and right tie rod ends, cabin air filter and stretch bolts for my front chassis reinforcement. Should be a whole new car when i'm done. Still might get some more stuff for the cooling system, engine and transmission mounts and possibly a new clutch
Old 06-01-2012, 04:31 PM   #38
Trashcan
My Ride: 2002 330ci
Oh and also my oil pump upgrade
Old 06-03-2012, 02:30 AM   #39
Trashcan
My Ride: 2002 330ci
A little teaser picture of the car as it's being switched between stalls in the garage until we finish the race car
Old 07-29-2012, 02:24 AM   #40
Trashcan
My Ride: 2002 330ci
Update! Found this is the oil pan Click image for larger version
This us how the gear rested, completely off the spline.
My original engine with 120+k miles bottom end
The bottom end of the new engine claiming 60k miles
Looks newer to me.
two engines just chilling
And tomorrow she goes in and gets wired
