buying a used HPF M3 - Page 11 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 06-03-2012, 10:45 AM   #201
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Originally Posted by armyB4 View Post
First thing I would check is that all your engine grounds are present. And of course make sure they are all bolted down.
Second, and this maybe a bit of a leap. But If they tuned the car with an (unknowingly) bad map sensor or they did not zero out their data for a proper baseline. Then all the changes after that are wrong. Hence when you installed a new map sensor the car went apeshit.
Also, since we are all really just guessing. You really need to get the car scanned. What codes does it currently have? smooth running values will tell you a good bit.
I was thinking the same thing.foresure something is off if two sensors cause such a problem between them. The harness may be a separate issue. It seemed to be the smaller cable running,down under the car behind the engine ill check it .
Ill check the grounds as well.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 06-03-2012, 12:05 PM   #202
being3
Modded ///Member
being3's Avatar
Just checked the voltage on the map sensor and im getting 5volts
Old 06-03-2012, 03:38 PM   #203
being3
Modded ///Member
being3's Avatar
Ok checked the new map sensor shows 2.1v at 0 so the new one is wrong and is why the was acting up with new one. My old map sensor tests correct at1.6v. Vacume is 24 and afr 10.0 an blinks flat lines periodically. no idea whats going on. Im wondering if the fule pressure regulator is acting up anyone know how to test that
Old 06-03-2012, 04:12 PM   #204
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Whats the part numbers on both of your AEM MAP sensors.
EDIT: They need to match otherwise you are hooking up the wrong one.
Old 06-03-2012, 04:23 PM   #205
Commanderwiggin
You want 5bar at your fuel pressure regulator. There is a port on the regulator to hook a gauge up to. Some more info here: http://m3forum.net/m3forum/showthread.php?t=316333
HPF verified for anything Stage 1-2.75 is 5 bar. REF: http://www.horsepowerfreaks.com/Prod...ing/11037/2/27
Old 06-03-2012, 04:29 PM   #206
Commanderwiggin
Mabe your vac line to your FPR is shot? Throwing that one out there?
Old 06-03-2012, 05:20 PM   #207
InDiGlOM3
My Ride: HPF M3 stg 2.5
He already checked that I believe and it was good. Its gonna be the main harness, he said he played with it and car ran good.
Old 06-03-2012, 05:50 PM   #208
being3
Modded ///Member
being3's Avatar
What I meant was it ran rich
as before but was not missing any cylinders. So I'm still stuck my original problem.
Old 06-03-2012, 06:22 PM   #209
Commanderwiggin
So have you checked the vacuum line going to the fuel pressure regulator? (under the car, drivers side under the driver seating area)
Old 06-03-2012, 07:30 PM   #210
being3
Modded ///Member
being3's Avatar
Yes i did check it and I can't blow that line at all.
Old 06-03-2012, 07:32 PM   #211
being3
Modded ///Member
being3's Avatar
I just picked up a scanning tool and going to check my Codes. I have no
Idea whats going on and I'm afraid I'm
Going to have ship this car back if they don't come out to help. What a pain in the ass as well as a few more grand.
Old 06-03-2012, 07:34 PM   #212
being3
Modded ///Member
being3's Avatar
Old 06-03-2012, 07:50 PM   #213
InDiGlOM3
Gets those codes and send them to me. What tool are you using to scan?
Old 06-03-2012, 07:55 PM   #214
being3
Modded ///Member
being3's Avatar
Thanks for sending me the codes ill send u mine tonight I purchased Innova OBD II scanner with cable. I have a Gopoint bluetooth scanner but is doesn't work For some reason with my m3 but fine with my other cars.
Old 06-03-2012, 10:55 PM   #215
being3
Modded ///Member
being3's Avatar
Im,getting p0303 cylender 3 misfire
Old 06-03-2012, 11:33 PM   #216
being3
Modded ///Member
being3's Avatar
Here are my Codes.some look normal for this car expect for the misfire and possibly, Coolant temp & the crank sensor. Not sure bout the lean condition. My guess anyway???
P0171 System Too Lean (Bank 1)
P0012 "A" Camshaft Position Over-Retarded (Bank 1)
P0015 Exhaust Camshaft Position Timing - Over-Retarded (Bank 1)
P0102 MAF Sensor Circuit Low Input
P0113 Intake Air Temperature Sensor 1 Circuit High Input
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0174 System Too Lean (Bank 2)
P0303 Cylinder Number 3 Misfire Detected
P0335 Crankshaft Position Sensor A Circuit
P0010 Intake Camshaft Position Actuator Circuit / Open (Bank 1)
P0013 Exhaust Camshaft Position Actuator Circuit / Open (Bank 1)
P0139 O2 Circuit Slow Response (Bank 1, Sensor 2)
P0159 O2 Circuit Slow Response (Bank 2, Sensor 2)
Old 06-03-2012, 11:58 PM   #217
being3
Modded ///Member
being3's Avatar
Cylinder 3 plug
Here is my plug from cyl 3
Name:	Plug Cycl 3.jpg
Old 06-04-2012, 12:32 AM   #218
being3
Modded ///Member
being3's Avatar
Ran the scann tool again and got theses codes
P0300 Random/Multiple Misfire Detected
P0302 Cylinder Number 2 Misfire Detected
P0306 Cylinder 6 Misfire Detected
Somethings is not going very well with these random acts
Old 06-04-2012, 01:06 AM   #219
SlideFox
My Ride: A Bucket w/ 4-Wheels
Does your tool allow you to reset codes?
SlideFox is offline   Reply With Quote
Old 06-04-2012, 01:07 AM   #220
Commanderwiggin
Alot of those codes are normal...going to bed but call ChrisK tomorrow.
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
