Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 06-04-2012, 01:21 AM   #221
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Originally Posted by SlideFox View Post
Does your tool allow you to reset codes?
Yes it does allow for reset. So the first set i posted could have been from a long time back. But the second set were after the reset this evening. I just reset it again and ran it and i didn't get any miss fires but still running rich
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 06-04-2012, 01:22 AM   #222
being3
Modded ///Member
being3's Avatar
Originally Posted by Commanderwiggin View Post
Alot of those codes are normal...going to bed but call ChrisK tomorrow.
Ill be calling him for sure. Thanks again your support
Old 06-04-2012, 09:02 AM   #223
Commanderwiggin
My Ride: 900rwhp Turbo M3
I wonder if this could be a crankshaft position sensor...
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 06-04-2012, 12:12 PM   #224
InDiGlOM3
My Ride: HPF M3 stg 2.5
The crankshaft code you pulled is normal. Usually when that sensor goes bad car just dont start.
Sent from my PG86100 using Bimmer App
Old 06-04-2012, 05:09 PM   #225
being3
Modded ///Member
being3's Avatar
I'm shipping my aem and full wireing harness to HPF to have it checked out
Old 06-04-2012, 07:44 PM   #226
being3
Modded ///Member
being3's Avatar
Checked fuel pressure at idle and it's 64 psi. So given that its about 8psi short of 5 bar im not sure if that would cause my rich problem but it might mean a new fuel pump if its weak
Old 06-04-2012, 08:09 PM   #227
InDiGlOM3
Originally Posted by being3 View Post
Checked fuel pressure at idle and it's 64 psi. So given that its about 8psi short of 5 bar im not sure if the would cause my rich problem but it might mean a new fuel pump if its weak
Thats perfect. What year is that car? how many miles on it? Reach down and play with the cranksensor wire, push it into sensor in a way, see what it does, for some reason the wires crack.... sometimes causing damage and connection problems.
Old 06-04-2012, 08:15 PM   #228
being3
Modded ///Member
being3's Avatar
Car is an 03 with 80 k miles the kit has about 20k miles maybe more. Doesn't the kit have a new pump replacing the stock one? So I've already taken the harness out of the car to ship to hpf so I cant test the crank connection
Well I'm sure getting to know this system and how to test it , that's for sure. Its not such a mystery except for my problem.
Hpf said they would do a quick turn around on testing the harness and aem, they will also send me new guages as they may be the problem as there was an intermittent problem with them at HPF and it seemed to fix itself. The problem was they were showing lean when in fact it was normal afr. The computer compensates according to gauge readings as the aem uses the Guages as actual afr and do not use the 02 sensor directly to my understanding.
Old 06-05-2012, 01:45 AM   #229
Dreikraft
My Ride: slow m3
sorry to hear your still having problems...
your running rich at partial throttle i take it?
how rich we talking?
is it consistent or just on cold starts or warm starts?
Dreikraft is offline   Reply With Quote
Old 06-05-2012, 01:50 AM   #230
being3
Modded ///Member
being3's Avatar
Rich on idle cold or warm 10.0 afr
Old 06-07-2012, 10:00 PM   #231
being3
Modded ///Member
being3's Avatar
Well Hpf got my aem and harness. They were able to get it checked out and replaced the ground and power connection tabs. Also replaced
my jumper box They also checked out that the idle was set rich for the Motorsport thermostat so they adjusted for the standard one which I now installed. Also got a new set of plugs as well as a exhaust cam sensor from HPF. They received it today and shipped it out same day. Now that's service. I'll get it Monday and try it all out. Then go from there.
Also got my ballast for my left headlight to get that working. Hopefully this resolves all my major concerns and I'll be able to register and license the car and enjoy driving it.
Old 06-07-2012, 10:03 PM   #232
Tchleung
My Ride: 02 M3
Good luck! I hope this finally resolves all your issues!
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 06-08-2012, 12:12 AM   #233
jchris
My Ride: Sold-HPF BMW M3 Stg3
Good luck bro. So nice to see all the veterans coming together to help you out.
Keep us posted.
jchris is offline   Reply With Quote
Old 06-08-2012, 12:14 AM   #234
being3
Modded ///Member
being3's Avatar
Old 06-08-2012, 12:54 AM   #235
BMW E465
My Ride: 1dirty5
"like"
BMW E465 is offline   Reply With Quote
Old 06-09-2012, 11:35 AM   #236
being3
Modded ///Member
being3's Avatar
Here is a synerio I think might be my problem given some of the great feedback from this forum. Using the motorsport thermostat and clutch fan along with a rich aem cold start settings and with my cold temperatures here that the car runs rich and never gets warm enough and after 10 min of stop light driving the engine loads up with fuel fouling the colder plugs and starts to stall. the problem is worsened when the car is not being driven hard not Getting enough heat.
I drive it harder and it was warmer when I first got it. It also stalled but less frequently with the new plugs as well.
So I'm hoping the idle enrichment changes and the thermostat change and new plugs will solve my problem. We will see. Fingers crossed
Old 06-09-2012, 10:51 PM   #237
being3
Modded ///Member
being3's Avatar
Installed new ballast. Headlight now works. One down one to go
Old 06-11-2012, 10:08 AM   #238
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Hey this is a random question but do you know Aran??? He mentioned his counselor just bought a stage 2.5 HPF M3 when he came back to Toronto for a visit.
AMG-ETR is offline   Reply With Quote
Old 06-11-2012, 03:13 PM   #239
being3
Modded ///Member
being3's Avatar
Well got the thermostat changed (what a pain). Plugs r out and im letting the cylinders breath abit of fresh air before in put in the new ones. Just waiting for the delivery of my updated aem and harness should be in an hour or so. I have a new exhaust censor and am having hard time getting to the 5mm bolt. Still working on that. Ill give an update a a few hours
Old 06-11-2012, 08:23 PM   #240
being3
Modded ///Member
being3's Avatar
Well got everything from hpf changed the plugs, aem installed wireing harness and jumper box. The car ran badly as if the map sensor was bad As i thought the map sensor that was shipped was defective. So I'm having one shipped ASAP!
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
