Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
Rating:
Display Modes |
#241 | |
#242 |
My Ride: 05'M3, 03 996TT
^^^ Seriously! Sending over some 4 leaf clovers and rabbit's foot for ya, you needzzz it! Keep us posted once you install the new MAP sensor.
M3: Best ET 11.93 Best Trap 134 996TT: Best ET 11.36 @ 124.24 w/ 1.65 60' |
#243 |
we need better MAP sensors... i've gone thru enough to know they fall outta spec way too often for no damn reason.
anyone know if a haltech would be an upgrade over the current aem? |
#244 |
Engine , AEM and harness all put back together . I cleaned it up while I was at it.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
#245 |
#246 |
Car with new side skirts. They are black and am deciding if I should paint them silver with a black tapered stripe or all silver or leave them black
#247 |
Well got new map sensor installed. I found one locally 250 bucks !!! Car started and idled at 11.5 ( still rich but better than before) drive it a block and it stalled??? Started it again and drive it afr is 10.0 under light driving vacume 20. Car after a few more blocks stalled and ran rough as it did before. Now am completely baffled
#248 | |
Chris.
![]() ![]() HorsepowerFreaks.com 12905 NE Airport Way Portland, OR 97230 (503) 256-5600 BMW Performance Parts Product questions or to purchase - sales@horsepowerfreaks.com |
#249 |
Well I'm going to install exhaust cam sensor but I doubt that's it as the car can read from the crank sensor to compensate. I have too big of a afr problem for that im sure but I've been fooled before.
If that doesn't work I'm having Hpf get me a new gauge harness and gauge set to replace the ones I have in the rear view mirror. If that doesn't work I'll change out the vanos unit as a last resort. $$$ Other than that I have no idea what to do
#250 | |
#251 |
Can't get the dang cam sensor bolt off. Any suggestions? I have the cover off and air filtration etc. just can't get the 5 mm Allan wrench to line up.
#252 |
Its an odd angle. Try to feel it good and get an idea of it. Otherwise you can easily get to it from under with long extension and a swivel
Sent from my PG86100 using Bimmer App
#253 | |
you tested the wideband with a ether soaked rag to make sure it goes full lean? |
#254 |
To make sure it doesn't go full lean you mean...brake clean or ether should peg it rich
#255 |
I replaced the 02 sensor. No change at all.
#256 |
I ordered a new vanos solenoid in case that's failing. Will take a week to get.
#257 |
Off to buy a car tomorrow so that my wife can have her car back. My guess is that this car wont be running for a while.
#258 |
Daaaaammmmmnnnnnn!!
#259 | |
also just to see how the gauge responds to the rag. how was this car driving down in san antonio? |
#260 |
Apparently Hpf said it was Running like crap barley running when it was unloaded off the truck hpf attributed it to wrong plugs and a bad map sensor and ran fine afrer that although the guages did miss read intermitly and somhow reaolved it self I was told by the seller it ran great. I certinly feel I was mislead but that's partly my mistake in trusting and letting this happen.
| Tags |
| e46 m3, hpf, stage 2.5, turbo |
