Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 07-01-2012, 04:53 PM   #361
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
Originally Posted by Derun View Post
Hi, I bought HPF stage1, the first run was
strong detonation, piston broke
bought a new engine, detonation continued
what to look for, what it is, how to check the firing angles?
I will appreciate help HPF
I apologize for my English language skills
Sincerely, Igor, Russia, Moscow
http://www.drive2.ru/cars/bmw/m3_cou...upe_e46/derun/
I send you a PM. Please hook up your knock siren. That will let you know about pre-ignition long before you can actually here it. You won't have to check firing angles. There is something not installed correctly. Please follow the steps in our troubleshooting manual to diagnose it.
http://www.horsepowerfreaks.com/Prod...ing/11037/2/23
HPF Chris is offline   Reply With Quote
Old 07-02-2012, 12:21 AM   #362
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Had a blast playing with gt500 he couldn't figure out why he was losing. Ground to a little old m3
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 07-02-2012, 12:23 AM   #363
HPF Chris
Past Site Sponsor
Ha ha. Nice kill
Old 07-02-2012, 01:12 PM   #364
02black330ci
My Ride: spaceship
Ha! Nice man, pump gas right?
02black330ci is offline   Reply With Quote
Old 07-02-2012, 03:45 PM   #365
Sweed
My Ride: 07 6.0L / 04 M3
AA HKS Stg 2 / Nitrous Express
Sweed is offline   Reply With Quote
Old 07-02-2012, 05:05 PM   #366
being3
Modded ///Member
being3's Avatar
Yes just pump. Didn't want to have him experience too Much shame all at once.
Old 07-02-2012, 05:47 PM   #367
being3
Modded ///Member
being3's Avatar
Originally Posted by HPF Chris View Post
Ha ha. Nice kill
U guys make a great sleeper. The m3 is fast enough stock to be underestimated by high HP cars never thinking u have a
Heap load of power above stock. I took a friend of mine out who thought I had a bout 400 HP and he was literally shocked when i put the hammer down. Lol.
Old 07-06-2012, 06:42 AM   #368
Commanderwiggin
My Ride: 900rwhp Turbo M3
On a side note...looks like this issue has been present for a few years... http://www.e46fanatics.com/forum/showthread.php?t=727254
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 07-06-2012, 09:24 AM   #369
02black330ci
My Ride: spaceship
Good find, I remember that thread now. I wonder what the fix was since there was no update on the fix.
Old 07-06-2012, 06:21 PM   #370
being3
Modded ///Member
being3's Avatar
Thanks for the research. I understand that this issue ended up being a vacuum line that blew off the fuel regulator. Robbie actually sent the car to Hpf to get that figured out as that line was buried under the plate under the car and he didn't see it and the problem was resolved. He disclose that to me prior to the sale.
Old 07-06-2012, 06:23 PM   #371
being3
Modded ///Member
being3's Avatar
I'm still waiting for
My vanos valve body and crank sensor and batt backup. I should have next week.
Old 07-06-2012, 06:59 PM   #372
Commanderwiggin
Cool, I was looking at stuff last night in regards to idle as I'm going to clean my ICV as preventative maintenance next week.
Take some pics of the install of the valve body and sensor...my stuff should be shipping out next week sometime and will most likely install the week after when I get back from work.
Old 07-06-2012, 07:26 PM   #373
HPF Chris
Past Site Sponsor
That's a great preventative maintenance plan. This gets gummed up on so many M3s.
Chris.
Old 07-06-2012, 07:26 PM   #374
being3
Modded ///Member
being3's Avatar
Will do for sure and I'll post them
Old 07-08-2012, 05:56 PM   #375
being3
Modded ///Member
being3's Avatar
New / used vanos value body arrived and all cleaned up inside and out with break cleaner. Really
Appreciative for the man who have this to me to help out. It saved about 800 bucks. Hopefully this wil work but if not it will have eliminated one more suspect.
Old 07-08-2012, 05:56 PM   #376
being3
Modded ///Member
being3's Avatar
Engine still hot from a long country road burn with the wife. She Was telling me to keep my foot in it. Scary. Lol. I'm preceding despite the heat
Old 07-08-2012, 06:05 PM   #377
being3
Modded ///Member
being3's Avatar
Removed passenger side fan shroud. Put red cloths underneath vanos unit to catch oil dripping while removing. No need to remove clutch fan. It's tight but can be removed and installed with it on.
Old 07-08-2012, 06:14 PM   #378
being3
Modded ///Member
being3's Avatar
Lossen all five 5mm bolts as well as 12mm vanos oil valve and unplug connector on passenger side bottom.
No need to touch rest of vanos unit
Old 07-08-2012, 06:23 PM   #379
being3
Modded ///Member
being3's Avatar
Lift vanos selinoid and value body out from passenger side of engine. Comes right out. U might have to turn the fan blades a bit to coach it out.
Old 07-08-2012, 06:26 PM   #380
being3
Modded ///Member
being3's Avatar
Now remove vanos selinoid (black box) and install on new valve body. Also clean underside of vanos head unit before mounting.
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
