Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 07-09-2012, 03:18 PM   #401
Ky///m3
My Ride: 1988 E30 M3
Originally Posted by turboi View Post
High idle, rich conditions etc are all signs of boost leaks, test it with a home made boost tester to make sure 100% there are no leaks, or take it to a performance shop and they can test it there.
With that said i love how hpf just sits back and watches you suffer while you pour countless of hours and dollars into the car, after they ok'd it and said it was fine to leave.
u clearly havent read the thread, nor know what has transpired
2006 E46 M3 HPF stg II SOLD
1988 E30 M3 Touring Class
1995 E36 M3 I-Prepared Class
Ky///m3 is offline   Reply With Quote
Old 07-09-2012, 04:53 PM   #402
Commanderwiggin
My Ride: 1000rwhp Turbo M3
s. T. F. U.
Old 07-09-2012, 04:56 PM   #403
M3PTGSC
My Ride: M3
S T F U X88788383883
09 SL63 AMG Designo,pano and whole nine yards lol
07 S550 P2 4matic-gone
03-M3-6766 DBB..Tubular manifold...
97-M3-
95-M3 SC stage 2-Widebody...
08 Gix 1k 08 ZX10R
M3PTGSC is offline   Reply With Quote
Old 07-09-2012, 05:14 PM   #404
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
S.T.F.U. X 10,000,000.
HPF Chris is offline   Reply With Quote
Old 07-09-2012, 05:30 PM   #405
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Hpf Has been helping me a lot. I have no issues with them at all. I'm glad for their support and the support i have received from this forum and a lot of caring people r going above and beyond to help me out. Yes I'm frustrated with this problem but it's a car that's hard to diagnose because u cant use factory codes. it will be sorted out. The car has had a lot of improvements since I have bought it and just have this snags to deal with. Apparently the bat harness is almost ready to ship so
My logs can be diagnosed at Hpf.
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 07-09-2012, 05:48 PM   #406
Tchleung
My Ride: 02 M3
Originally Posted by being3 View Post
Car is at afr at idle 12s then down to 11a and 10s. And 10.0 at high boost sometimes it's 10.5
Originally Posted by HPF Chris View Post
That's fine.
That is certainly not fine. Perfect way to wash the cylinders and dilute the oil.
There is no need for a car to idle that rich.
Follow me on Instagram @tommtomm84
03 Carbon Black X5 4.4 - Parts Hauler/Daily
02 Carbon Black M3 6MT - Fun Car
456whp/312wtq @ 8psi, No #'s yet at 9psi
4.10 / Headers / ESS VT2-550+
Tchleung is offline   Reply With Quote
Old 07-09-2012, 05:51 PM   #407
HPF Chris
Past Site Sponsor
10:1 to 11:1 on full boost is perfect for our kits. 14:1 is ideal "at idle", but we will usually see between 13:1 and 14:1 at idle. 12:1 is a little on the rich side at idle but won't hurt your motor any.
Chris.
Old 07-09-2012, 06:55 PM   #408
being3
Modded ///Member
being3's Avatar
Chris.
I am seeing 10.0 at idle at times and others times between 10.5 and 11.1 max. On the rare occasion I see 12 for a few seconds. I have never seen 13 to 14
Old 07-09-2012, 07:15 PM   #409
HPF Chris
Past Site Sponsor
Your car should not idle at 10.0 or you will foul the plugs immediately.
Chris.
Old 07-09-2012, 07:46 PM   #410
being3
Modded ///Member
being3's Avatar
Chris.
Believe me the plugs r black and my wife's tired of me smelling like raw fuel. Since changing the vanos selinoid it now only hits 10 at a stop
Light and moves to 10.5 an while driving lightly it's at 11.5 to 12. I have gone over this car with a fine tooth comb so I'll be sending in my aem for the logs to be diagnosed
Old 07-09-2012, 10:35 PM   #411
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
My apologies if this has been asked/mentioned but I didn't see it while searching the thread.
Have you done a compression test.. the symptoms you're experiencing sound very similar to a oil contaminated cylinder. Are all your plugs equally fouling? When my car was getting blow by my afr's would be doing exactly what you're describing.. oil was getting past the rings and mucking it up..
EDIT: I searched compression, but I see now you've had a leakdown done. So disregard.
Old 07-09-2012, 10:57 PM   #412
being3
Modded ///Member
being3's Avatar
I have checked the plugs a few times and they r all the same. Since the vanos selinoid fix the plugs look much better an r consistent across all cylinders.
Old 07-09-2012, 11:05 PM   #413
InDiGlOM3
My Ride: HPF M3 stg 2.5
Do you have a hpf m3 or even an m3 boost leaks dont cause idle problems. Only vac leaks. And a vac leak would cause a high idle. I can completely remove my manifold and the car will still idle just fine. Anything pre icv dont matter when it comes to idle. Please stop chim'n in if you dont know what your talking about.
Sent from my PG86100 using Bimmer App
Old 07-10-2012, 03:58 AM   #414
red375
My Ride: //HPF E46 M3 stg2
Chris.
What about when the A/C is on ? is it the same?
MM
red375 is offline   Reply With Quote
Old 07-10-2012, 10:25 AM   #415
being3
Modded ///Member
being3's Avatar
MM
Started the car cold. Afr Hits 10.0 then the oil for the vanos comes on line about 15sec. Then afr climbs to 11s. Shut car off. Start back up. Afr starts at 14.7 stays for about 30sec. Then falls down to 11.5. Put ac on afr climbs to 12.6. Shut ac off and afr back to 11.5. This is all cold start. Idle rpm about 1100
Old 07-10-2012, 10:54 AM   #416
being3
Modded ///Member
being3's Avatar
Here is a video of cold start. The car has sat all night.
The u can hear the vanos oil pressure come up and see the afr go from 10.0 climb to 11s. U can also hear a high pitched squeal. I believe that's vanos pressure. I have heard this sound and for example and seen the afr from 14.7 drop very quickly to 11.5 when warm. Anyone expierence that sound before. ?
Old 07-10-2012, 04:57 PM   #417
mbdarkwinter
My Ride: 2004 E46 M3 HPF S2
Something is wrong there... At idle mine is right at 14 and 24
mbdarkwinter is offline   Reply With Quote
Old 07-10-2012, 05:59 PM   #418
being3
Modded ///Member
being3's Avatar
Ok here is my idle after some
Changes by ultrasonic cleaning of vanos oil regulator and value
Body. It's better but still a concern. A/C makes a difference if anyone wants to shed like on what that could indicate.
Old 07-10-2012, 06:44 PM   #419
Commanderwiggin
Have you checked your Exhaust Hub for tab breakage?
Old 07-10-2012, 06:56 PM   #420
being3
Modded ///Member
being3's Avatar
No I haven't as I it sounds fine at idle and I thought it made a lot of noise if it was broken.
I am starting to think I might be vanos oil pressure related.
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
