Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 07-11-2012, 12:13 AM   #421
dan avoN7
My Ride: A car
Originally Posted by being3 View Post
No I haven't as I it sounds fine at idle and I thought it made a lot of noise if it was broken.
I am starting to think I might be vanos oil pressure related.
You can have a broken tab and not even know it. I checked mine not too long ago and it was broken (~105K miles). I didn't have any odd/strange noises prior to checking.
dan avoN7 is offline   Reply With Quote
Old 07-11-2012, 12:56 AM   #422
being3
My Ride: HPF 2.5 M3 Vert
Thanks for your sharing. That's good information for me. I'll check it for sure
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 07-11-2012, 09:08 PM   #423
being3
Been driving the car putting some miles on it. I changed the oil and filter along with the ultrasonic cleaning of the vanos valve body and regulator.
The afr at idle is in the high 11 and mid 12s and I see 13s at times as well at idle. Car runs well and the odd time I see mid 10s but climbs up to 11.5 or more.
This is the best I have seen.
High boost is 10.00
Old 07-11-2012, 09:29 PM   #424
being3
Battery harness , crank sensor and intake cam sensor will be here this week. I'll install them try it then send my logs down to Hpf. From there I'll see where things r at. I'll also check the vanos oil pump tabs.
Old 07-11-2012, 11:01 PM   #425
being3
What kind of symptoms did ur car have with the broken tab? Rich idle ? Any codes?
Old 07-11-2012, 11:46 PM   #426
dan avoN7
My Ride: A car
No symptoms at all. With the recent horror stories on the forum I decided to change the cam gear bolts and fully inspect the vanos exhaust hub. Turns out one of the tabs was broken My engine is stock so I don't have an air/fuel gauge or a bazillion engine codes
Old 07-12-2012, 12:36 PM   #427
02black330ci
My Ride: 05'M3, 03 996TT
Originally Posted by HPF Chris View Post
High boost on pump/meth or race should be 12-13psi.
He is referring to his AFRs Chris, not boost.
Best ET 11.93
Best Trap 134
02black330ci is offline   Reply With Quote
Old 07-12-2012, 12:37 PM   #428
HPF Chris
My Ride: 2002 M3, 2006 530i
Too many threads to read today. ha ha.
HorsepowerFreaks.com
12905 NE Airport Way
Portland, OR 97230
(503) 256-5600
BMW Performance Parts
Product questions or to purchase - sales@horsepowerfreaks.com
HPF Chris is offline   Reply With Quote
Old 07-13-2012, 10:02 PM   #429
being3
Did u go with the dr vanos hub? $899 seems crazy price
Old 07-13-2012, 10:38 PM   #430
Commanderwiggin
My Ride: 800rwhp Turbo M3
So I went to check my spare sensors today and looks like I was given the wrong spec MAP sensor...I have a 50PSI one and the spare was a 75PSI one...mabe you were given the wrong sensor back when you swapped them.
Commanderwiggin is online now   Reply With Quote
Old 07-13-2012, 10:57 PM   #431
being3
I had checked and it was the correct one .but The one I did get was faulty and I had it replaced.
Any ideas why my afr would be better with the ac on?
Old 07-14-2012, 12:36 AM   #432
Commanderwiggin
More load?
Old 07-14-2012, 05:27 AM   #433
being3
More load?
Good one. Now what would more load cause a leaner afr at idle?
Old 07-15-2012, 06:38 PM   #434
being3
Been driving the car all week. Lots of miles. Afr ranges at idle from 11 cold to 12s to mid 13s warm. Best it's ran so far and no fuel smell. I'll be heading back to my tools so I can make a few more checks and changes. Then off long haul with the car
Old 07-15-2012, 06:49 PM   #435
Dreikraft
My Ride: slow m3
where in bc are you?
Dreikraft is offline   Reply With Quote
Old 07-15-2012, 07:56 PM   #436
being3
Been all over Vancouver island now off to Vancouver then to the interior and back.
Old 07-15-2012, 09:55 PM   #437
Tchleung
My Ride: 02 M3
Hey I'm in Penticton. Give me a shout next time you're in town.. haha
02 Carbon Black M3 6MT
456whp/312wtq @ 8psi, No #'s yet at 9.5psi
4.10 / Headers / ESS VT2-550+ / Tuned by Evolve
Tchleung is offline   Reply With Quote
Old 07-15-2012, 10:23 PM   #438
Dreikraft
My Ride: slow m3
That's a hop n a skip to Portland
Old 07-16-2012, 09:58 AM   #439
being3
Pulled a plug just to see what's going up after several days of driving. ( theres some old carbon residue that hasn't been burned off yet from when it was running rich) looks great.
Old 07-16-2012, 10:05 AM   #440
being3
Battery harness ready to be installed thanks to Chris.
Logs now be saved to be diagnosed by HPF
e46 m3, hpf, stage 2.5, turbo
