Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 05-25-2012, 09:45 PM   #61
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Yes DRL s done. Have to install front left headlight so it's working and the idle control valve. I'll do that first thing in the morning as I'm traveling today and won't be back till late tonight
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 05-25-2012, 10:10 PM   #62
Dreikraft
My Ride: slow m3
let us know how the icv works out
Dreikraft is offline   Reply With Quote
Old 05-25-2012, 10:23 PM   #63
being3
Modded ///Member
being3's Avatar
. Will do.
Old 05-25-2012, 10:27 PM   #64
being3
Modded ///Member
being3's Avatar
I just ordered a aem intake temp sensor as well in case ICV is not the problem
Old 05-25-2012, 10:32 PM   #65
being3
Modded ///Member
being3's Avatar
I could also be the jumber box on the driverside so check that first and I might if all Thai fails send in the aem and Humber box to see if HPF can duplicate my problem. They have been very supportive in helping me solve my problem. I'm the one who's a way a lot working so have not been arround to work on it
Old 05-25-2012, 10:41 PM   #66
being3
Modded ///Member
being3's Avatar
Old 05-25-2012, 11:34 PM   #67
Commanderwiggin
My Ride: 900rwhp Turbo M3
You work in the oilsands by chance?
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Commanderwiggin is online now   Reply With Quote
Old 05-26-2012, 10:08 AM   #68
being3
Modded ///Member
being3's Avatar
No oil sands.
Old 05-26-2012, 10:09 AM   #69
being3
Modded ///Member
being3's Avatar
Well
I got up at 5am. Installed the idle control valve and the car still
Runs rich at idle and after 10
Min of driven it starts to stall and run very rough
Old 05-26-2012, 10:11 AM   #70
being3
Modded ///Member
being3's Avatar
This sucks. Seems my idle afr is 11.4 and after it warms
Up it's
I'm the low tens. Now that's rich.
Old 05-26-2012, 10:16 AM   #71
being3
Modded ///Member
being3's Avatar
I shut the car off let it sit. I restart it then for about 25 seconds afr is at 14 which is good. Then it creeps down to 11. Which is rich. This is after car is warm
Old 05-26-2012, 11:43 AM   #72
being3
Modded ///Member
being3's Avatar
Pulled a plug to take a look. Lots of carbon so too much gas for sure. I also noticed that one of my
Coils was stock and the rest were Okada as they were suppose to be. I'm finding out things every day in this car that r Micky mouse. I just am doing the headlight now and some broken wires with black tape were
Evident. I'm off to get a soldering iron to fix that.
Old 05-26-2012, 11:45 AM   #73
being3
Modded ///Member
being3's Avatar
Here is the broken wire
Old 05-26-2012, 11:58 AM   #74
being3
Modded ///Member
being3's Avatar
Found out the source of the oil leak. Seems the rubber seal in the oil cap is toast. The oil ended up leaking under the cover and accumulated and leaked down onto the turbo manifold. Thats a relief as I thought I was going to have to do the value cover gasket again.
Old 05-26-2012, 12:01 PM   #75
Commanderwiggin
1 OEM coil...thats pretty darn Mickey Mouse...geez that really blows dude.
Old 05-26-2012, 12:04 PM   #76
Commanderwiggin
14 is where you should be at idle when warm...i think...I know mine sits around there when cruising but I can't exactly remember right now...plugs def looks like its running pig rich. Has anyone given you the HPF bat line?
Old 05-26-2012, 12:34 PM   #77
B33MER
My Ride: 330i SMG M-Sport
Originally Posted by being3 View Post
Attachment 453319
Sucks to hear that ... I'm surprised the peeps at HPF didn't notice that when they were inspecting your car ... What sort of inspection did they do when you send it in?
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
B33MER is offline   Reply With Quote
Old 05-26-2012, 12:50 PM   #78
being3
Modded ///Member
being3's Avatar
Replaced throttle positioning sensor. Still have idle and afr problems
Old 05-26-2012, 12:52 PM   #79
Commanderwiggin
There are actually 3 TPS on our cars...one of them is not cheap iirc.
Have you called ChrisK@HPF? (Batline?)
Old 05-26-2012, 12:55 PM   #80
being3
Modded ///Member
being3's Avatar
They did a full turbo kit inspection. Ran it in the dyno etc
They found a lot of stuff. Te list was over a page
Long. They saw a afr problem initially but it seems
Not to repeat it self. Also when the car came in to HPF it was running rough but that went away when they put in the proper plugs. The owner had the wrong ones in for some reason. I drove the car for few hundred miles and then the problem started. So I do t see HPF being to blame. There r two car events this weekend as I'm frustrated I have leave My car parked. I'm also worried about the inspection as the car reaks of fuel
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
