Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 05-26-2012, 11:56 AM   #81
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
I only have insurance for the day to get it inspected until I can register it
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is online now   Reply With Quote
Old 05-26-2012, 11:58 AM   #82
being3
Modded ///Member
being3's Avatar
Originally Posted by Commanderwiggin View Post
14 is where you should be at idle when warm...plugs def looks like its running pig rich. Has anyone given you the HPF bat line?
If u have the bat line I would appreciate it
Old 05-26-2012, 12:00 PM   #83
being3
Modded ///Member
being3's Avatar
There are actually 3 TPS on our cars...one of them is not cheap iirc.
Have you called ChrisK@HPF? (Batline?)
I changed the front sensor. Where r the other two?
Old 05-26-2012, 12:13 PM   #84
Commanderwiggin
My Ride: 900rwhp Turbo M3
Believe the other is at the rear and the third is the gas pedal iirc*
Batline PM sent
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 05-26-2012, 01:15 PM   #85
being3
Modded ///Member
being3's Avatar
So the igniter was changed on the headlight. That didn't do the trick. My ballest isn't here yet so I'm screwed for my inspection today. I'm trying to talk my wife into letting me take her ballest out of her car lol
Old 05-26-2012, 01:44 PM   #86
02black330ci
My Ride: spaceship
Whats your vacuum holding at when the car is warmed up and idle? Sucks you are having all these issues and that 1 OEM coil is just some none sense, damn! If HPF changed out the plugs, why didn't they advise you of this 1 OEM coil?
02black330ci is offline   Reply With Quote
Old 05-26-2012, 03:25 PM   #87
being3
Modded ///Member
being3's Avatar
Holding at 20ibs
Old 05-26-2012, 04:10 PM   #88
Commanderwiggin
Have you checked your AEM Wideband O2 or your AEM Intake Air Temp Sensor?
http://www.horsepowerfreaks.com/Prod...ing/11037/2/27 there are some links to videos on testing them.
Old 05-26-2012, 06:18 PM   #89
being3
Modded ///Member
being3's Avatar
I replaced the o2 sensor and I ordered an temp sensor it will be here next week I am
Going to pull the intake again and test the sensor. Car is acting funny like its at 14 then creeps down almost like air temp goes up afr goes rich so maybe it's the sensor. I sure hope so
Old 05-26-2012, 06:19 PM   #90
being3
Modded ///Member
being3's Avatar
Here is the driver side skirt damaged. I just put the stock one on
Old 05-26-2012, 06:20 PM   #91
being3
Modded ///Member
being3's Avatar
Passenger side skirt damage
Old 05-26-2012, 06:22 PM   #92
being3
Modded ///Member
being3's Avatar
Rear bumper hanging down
Old 05-26-2012, 06:23 PM   #93
being3
Modded ///Member
being3's Avatar
Front splitter damage
Old 05-26-2012, 06:57 PM   #94
Commanderwiggin
Wow man...funkyboy must've believed in a zero care, zero maintenance policy...that is complete bs...I wouldn't be able to sleep at night if my car was in that condition...let alone selling it and hiding those problems.
It clearly is in better hands now
Old 05-26-2012, 07:29 PM   #95
being3
Modded ///Member
being3's Avatar
Tested air
Temp sensor seems
To be ok
Old 05-26-2012, 07:37 PM   #96
Commanderwiggin
Map sensor, ecu/jumper box wiring loose...stumped otherwise.
Old 05-26-2012, 07:39 PM   #97
being3
Modded ///Member
being3's Avatar
Disconnected the jumper box and reinstalled wireing. No change still a problem. Looked at all vacuum connections no problems.
Old 05-26-2012, 07:40 PM   #98
being3
Modded ///Member
being3's Avatar
Map sensor and relay was replaced by HPF.
Old 05-26-2012, 07:41 PM   #99
being3
Modded ///Member
being3's Avatar
I'm having new gauges sent out to see if it's the Scott wheeler gauges acting up
Old 05-26-2012, 07:43 PM   #100
being3
Modded ///Member
being3's Avatar
I passed federal inspection so the car is good to stay in canada now. Could not do provincial as the right head light isn't working yet. So I'll have to wait another week for that. Can't drive the car anyway with the afr and stalling problems
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
