Old 05-22-2012, 10:06 AM   #1
das86turbo
My Ride: GTS4 M3, 330XI, 911
E46 M3 - Heater Core delete /hose rerouting
I'm building an E46/M3 GTS 3/4 race car. Heater core and supporting h/w have all been removed. Does anyone have experience rerouting the heater hose that runs from near the #3 cylinder to the heater core, back to the water/valve pump assembly and back to the radiator? I want to remove this entirely and simply route that hose back to the radiator. Removing the heater core, HVAC ducting etc was easy. Im having difficulty determining how to get to the fitting where the supply for the heater core comes off the head. Diagrams from Realoem.com and even the factory manuals are vague in this regard. It looks as if the intake manifold needs to be removed. I find that hard to believe. There has to be an easier way.
Also, I was thinking of using AN fittings with SS braided hose then form a coil to allow some latent heat transfer. That said, the heat would be given up in the left side of the engine bay near the intake plenum. Not the best please to release heat.
das86turbo is offline   Reply With Quote
Old 05-23-2012, 04:34 AM   #2
The Gorilla
My Ride: E46 M3
Hi,
You have the Heater feed outlet and then
you have the Heater return which is
a Black metal pipe which feeds underneath
the TB's back into the water pump.
Using the the ''Kwik'' fit ends, off the
original heater hose, cut the metal
bands and remove the hose.
Now you have 2 ''kwik'' fittings in
black plastic which have 'spigots'
Purchase a Samco or similar 180 deg
silicon bend with long tails, if I remember
correctly at 25mm [1''] ID.
Cut tails to correct length, fit hose to
kiwk fits with stainless steel jubilee
band clips.
Job done.
This is how I have run it in my E30 M3 /S54 CSL engine
for 4 years now.
Regards,
The Gorilla.
ID:	452809   Click image for larger version
The Gorilla is offline   Reply With Quote
Old 05-23-2012, 05:59 PM   #3
das86turbo
Dang.... your pictures aren't showing. I'll PM you my personal email. Thx.
Old 05-24-2012, 03:16 AM   #4
The Gorilla
My Ride: E46 M3
Hi,
PM replied to.
Regards,
The Gorilla.
