Old 05-22-2012, 05:37 PM   #1
ColeD707
My Ride: 2001 325i
ebay headers install on e46 325i
jsut installed ebay headers on my e46 325i and am getting a leak out of the gaskets that came with the headers. every DIY ive looked up says buy the OEM gaskets from dealer and use those, yet theres not enough holes in them to bolt up so not really sure what to do. What has everyone done to make these fit and not leak?? any help would be awesome. thanks!
ColeD707 is offline   Reply With Quote
Old 05-22-2012, 06:48 PM   #2
ColeD707
My Ride: 2001 325i
The Oem headers have 8 holes, new eBay ones have 12.
Old 05-22-2012, 07:17 PM   #3
sedanpowersc
My Ride: 330i 5 speed
You need to use OEM gasket, and make sure the bolts are torqued correctly
| BB Gen 3 Headers | Cosmos Racing V2 CAI | Muffler Delete | RE Underdrive Pulleys |
| 3.46 Diff | Tein S-Tech | Bilstein Sports | Hawk HPS | ASA AR1 | 35% Tint |
sedanpowersc is offline   Reply With Quote
Old 05-22-2012, 07:37 PM   #4
Steven747
My Ride: 05 330ci
jeez if you read everywhere that u need to use new bmw gaskets why don't you use it
Old 05-22-2012, 07:55 PM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
There also aren't enough studs in the head. Just use oem locations.
Old 05-22-2012, 09:20 PM   #6
fastjasonbmw
My Ride: 330Xi
I used oem gaskets and drilled out the extra holes, and installed more studs. I figure, it could use more clamping force, the headers are from China. No leaks in 8K miles. I've noticed some of the early heads don't have the extra holes machined in the head, if that is the case for you, I would just use oem gaskets and new nuts.
fastjasonbmw is offline   Reply With Quote
Old 05-23-2012, 01:18 AM   #7
Steven747
My Ride: 05 330ci
oem gaskets don't have all the holes cut out so they shouldn't be touched.
Old 05-23-2012, 11:57 AM   #8
Calidownhiller
My Ride: 02 325i/13' FRS
Actually there are...
Calidownhiller is offline   Reply With Quote
Old 05-23-2012, 12:01 PM   #9
Calidownhiller
That's what we were thinking. I'm the one that insalled the headers. Coles head has enough holes so we purchased the extra studs and installed them. It helped with the leak but it's still there.
Obviously BMW makes a gasket that will fit. His head has the 24 holes predrilled.
Do any other e46 models use different headers that use all 24 holes? Maybe a gasket set for an e36?
Old 05-23-2012, 12:27 PM   #10
///Mostarac
///Mostarac's Avatar
My Ride: 370z & Cbr600rr
I used the ebay gaskets. Make sure its tight enough and make sure the bunges are closed if your not using o2 sensors and if you are using them, make sure theyre in there good enough. Also, check for any leaks at the gasket where the headers meet the exhaust.
Sent from my SGH-T989 using Bimmer App
Eurowerkz | East Coast
-Benny
///Mostarac is offline   Reply With Quote
Old 05-23-2012, 01:13 PM   #11
Calidownhiller
Honestly, the eBay gasket would have worked if we had installed all 24 at once. But since I only had the 16 from the old headers it didn't get them tight enough. The eBay gasket ended up separating. The only reason we reused it was to get the car drivable. The only isse we have now is gaskets.
The o2 sensors are in, the plugs where we didn't use sensors are tight. We even used new gaskets for the header to midpipe connection.
Old 05-23-2012, 01:18 PM   #12
///Mostarac
You just answered your own question. Go to bmw and get new bolts and, if needed, threaded shafts and reinstall the headers basically. Your probably going to need new gaskets if there are any rips. When i did my headers, i think i missed like 3 bolts because i couldnt reach them and mine seems fine.
-Benny
Old 05-23-2012, 02:52 PM   #13
aggieE46
Keep it clean
aggieE46's Avatar
I think you're right
Old 05-23-2012, 04:50 PM   #14
Calidownhiller
I actually didnt notice at first. Its kind of weird that they would have extra holes. That's why I'm trying to find the gaskets that would fit. Maybe the european cars had different headers that used all the holes or something.
