Old 05-25-2012, 04:18 AM   #21
Gheybe
Gheybe's Avatar
My Ride: F80 M3
You ruined it.
I was really looking forward to someone bolting the head down then finding out that the valves hit the cylinder bore, the cooling system is different, the VANOS requires a high pressure oil supply, and that Batman is Bruce Wayne.
You get the fucck out of here.
Thanks for ruining the best movie of the year for me.
Gheybe is offline   Reply With Quote
Old 02-13-2014, 11:00 PM   #22
Bimmerman22
My Ride: E46 325i
Originally Posted by Flaboy239 View Post
My 330 already beats stock M3's and I don't have nearly as much into it as it would have cost me to buy a stock M3. It would take almost $10k more before I got to that point. A port and polish will only cost me the price of new gaskets.
Wow impressive. What did you do to it??,
Bimmerman22 is offline   Reply With Quote
Old 02-22-2014, 12:43 PM   #23
wanganstyle
My Ride: e36 M3 / E30 GTS1
S54 shares nothing in common with a m54. 0 compatibility in parts
Best move for op? Remove supercharger system; install turbo kit. Power issue solved
Or up the current blower size/boost and install a s52b32 long block in its place. 3200cc+iron block for more boost and larger port head.
The double vanos from m54 can be retrofitted to a 3200cc s52b32 single vanos engine
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
