Old 03-05-2016, 11:41 PM   #1
evanr614
My Ride: 2000 328Ci
Genuine BMW E46 rear axle bushing removal tool, anyone used it?
I bought this tool under the impression that it can remove all 4 of the subframe bushings. The design is a lot less straight forward than I expected. I fiddled with it for a little bit on the used subframe I bought and wasn't able to figure out 100% how to use it. Just wanted to see if anyone has used it before. I will be contacting ECS or FCP to see if they have access to any 'official' instructions for this tool. Click image for larger version
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 03-06-2016, 11:57 AM   #2
evanr614
My Ride: 2000 328Ci
ya didnt think so :\
Old 03-06-2016, 05:27 PM   #3
ms9876543
My Ride: 325i M Sport Touring
Maybe this will help, you might be 'missing' a bit:
http://www.e46fanatics.com/forum/att...7&d=1224552176
ms9876543 is offline   Reply With Quote
Old 03-06-2016, 05:31 PM   #4
evanr614
My Ride: 2000 328Ci
Eh, those tools are different. I noticed this 'tool' i bought is really similar to this subframe bushings tool. It seems like I'm missing a part or something...I'm pretty stumped. Like I said I'll see if FCP or ECS is any help and if not I'll just have to see if the dealer knows anything.Click image for larger version
Old 03-07-2016, 04:55 AM   #5
jwleonard
My Ride: 1999 328I
There are two kits, one is for doing the bushings for the rear differential to subframe bushings (two small and one large) and the other is for the subframe to chassis bushings (four equal size). I made the tools to do mine and they are essentially bearing presses. Even with the subframe removed you have limited access to work.
Take a look here:
http://www.autohausaz.com/search/pro...t%20Tool%20Kit
jwleonard is offline   Reply With Quote
Old 03-07-2016, 10:44 AM   #6
evanr614
My Ride: 2000 328Ci
I appreciate the input but I am quite aware of these tools already
Old 03-07-2016, 12:15 PM   #7
jwleonard
My Ride: 1999 328I
Perhaps I didn't understand your question then. I thought with that information and previously being told you were possibly missing parts of the kit it might help resolve your issue.
Do you already have the subframe out?
Old 03-07-2016, 02:06 PM   #8
jwleonard
My Ride: 1999 328I
Ignore my question asking if you have the subframe out; I just realized you have a second subframe you tried this on.
You clearly don't have the official kit but I don't see any reason it won't work. I just noticed the large cup "receiver" has a threaded bolt hole in the center. The small round piece is for pulling the bushings and the large one is to pull the old one out into and the new one into place.
If you place the receiver over the top of the bushing (part facing down when installed in the car) it should align with the opening in the subrame and be large enough for the bushing to fit inside of it. The small one should be on the other side of the bushing and small enough to fit inside the subframe opening.
I'm working off the assumption both ends of the bolt are standard threads. If not you will have to adjust as required. If that is true the one problem I see with the design of your kit is the nut on the small end of the bolt might back off while turning the other end. If that happens you could try placing two nuts on the small end and locking them tight against each other to prevent that issue. If the ends are threaded opposite of each other you shouldn't need this.
The best way to explain it would be:
(With subframe removed)
REMOVAL
1. Remove the nut and washer from the small end of the "bolt". Slide the receiver over it with the closed end first until it engages the larger threads, then rotate it well onto the larger threads. Leave it there.
2. Insert the small end of the bolt from the top (part facing down when installed in the car) of the bushing so the small end comes out the other side of the bushing. You may need to turn the receiver further up the bolt; adjust it so the small end threads are just barely fully exposed.
3. Install the small round piece on the the small end of the bolt that is protruding from the bushing with the open end toward the bushing. Install the washer and nut against the closed end of the small round piece and thread the nut down. It doesn't really matter how far down you spin the nut but make sure there are at least two threads protruding from the nut and you don't go so far that you run out of threads and hit the shoulder.
4. Using an appropriate tool, turn the large end of the bolt counter-clockwise while holding the reciever in place until pressure begins to be applied to both sides and adjust parts of the tool to maintain alignment. The large end should only touch subframe and the small end should only touch the bushing.
5. After you have both sides aligned and staying in place securely continue turning the large end of the bolt counter-clockwise until the bushing is removed from the subframe and into the receiver.
6. To remove the bushing from the tool, remove the nut, washer and small circle piece. The bushing should be able to slide off the small end of the bolt.
Repeat for each bushing, I recommend removal all first since the tool is set up for it.
Clean any corrosion from the openings in the subrame but don't try to make them larger.
INSTALL
1. You will need to turn the large receiver further onto the large threads about equal to the height of the bushings.
2. With the large receiver still on the large end of the bolt insert the small end of the bolt through the opposite side of the subframe (so the opposite from removal).
3. Place the new bushing over the small end of the bolt with the small end of the bushing toward the subframe. Install the small round piece with the open end toward the bushing. Then install the washer and nut as before.
4. Turn the large end of the bolt counter-clockwise until it begins to apply pressure. Make sure the new bushing is perfectly aligned to the opening.
5. Continue turning the large end of the bolt counter-clockwise to pull the bushing into the opening of the subframe. Make absolutely sure the bushing is going in straight (this is very difficult), you may have to release the pressure and adjust several times. Continue turning until the bushing is fully seated in the subframe.
Repeat for each bushing.
This started short and got long as I added details; hope it helps.
Here is a link with pictures of the BMW style tool about halfway down the page.
http://www.khangfixesit.com/2011/08/...-bushings.html
Old 03-07-2016, 05:22 PM   #9
evanr614
My Ride: 2000 328Ci
None of the pieces for on the larger threaded side of the rod that is the entire issue unfortunately :/
Old 03-07-2016, 07:07 PM   #10
jwleonard
My Ride: 1999 328I
You mean I typed all that for nothing!
Can you describe what doesn't fit a little better?
Are you saying the big receiver won't thread onto the large end of the bolt?
Or does the large receiver not line up with the opining in the subframe?
Or is the large receiver not big enough for the bushing to slide into it on the way out?
Can you take/post some pictures of the part that doesn't work? We can use that to try to find a solution?
Do you have info about the kit manufacturer or a link to where you purchased it?
Old 03-07-2016, 09:32 PM   #11
evanr614
My Ride: 2000 328Ci
Essentially yes haha. What I mean is that none of the two circle pieces fit onto the larger threaded section. They are both small and fit onto the smaller threaded section.
As the title says this is a Genuine BMW tool...I am awaiting to hear back from Garreth of FCP Euro to see what he has found out about it.
https://www.ecstuning.com/ES199104/?...g7NhoCGC_w_wcB
Old 03-08-2016, 09:08 AM   #12
lmr2wil
My Ride: '00 328Ci
I believe that you bought http://workshop-manuals.com/bmw/3_se..._set_of_tools/ As you have noted, you need the "in conjunction with tools" (i.e. http://workshop-manuals.com/bmw/3_se...ersal_support/) see http://workshop-manuals.com/bmw/3_se..._re/page_1688/ for the procedure.
Good luck.
Luke
lmr2wil is offline   Reply With Quote
Old 03-08-2016, 11:05 AM   #13
evanr614
My Ride: 2000 328Ci
Good luck.
Luke
ayyyy its looks like you're on to something...where can i find the part number for the additional pieces in that second link?
Old 03-08-2016, 11:27 AM   #14
lmr2wil
My Ride: '00 328Ci
This may be of help... https://www.fcpeuro.com/products/bmw...40-83300492397
Old 03-08-2016, 11:29 AM   #15
evanr614
My Ride: 2000 328Ci
Yeah i just spoke with ECS. This is the other part needed however the entire tool from Baum is cheaper.
https://www.ecstuning.com/ES198688/
Old 03-08-2016, 01:09 PM   #16
zander271
My Ride: 6spd ZHP/5sp XI
Holy **** 400 bucks!
I smell subframe reinforcement happening also
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 03-08-2016, 01:15 PM   #17
evanr614
My Ride: 2000 328Ci
All kinds of fun stuff in the works
Old 03-08-2016, 02:44 PM   #18
Alex323Ci
My Ride: M3 & 323Ci (sold)
btw what ever happened with taking car into BMW for inspection?
Old 03-08-2016, 02:51 PM   #19
evanr614
My Ride: 2000 328Ci
They took pictures and put me in contact with someone from BMW NA they never gave me a real estimate. I heard from them last week, they wanted to cover 25% of the 4-5k cost of the repair. But I looked into another body shop that painted my bumper and they want to do the work for A LOT cheaper than my first estimate.
