Rating:
Display Modes |
#61 | |
Platinum Plus Quality
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#62 | |
![]() I can help with * Reading Codes / Coding your car * R&R FCAs, Tie Rods, Sway links.... * RTABs Need an RTAB tool? Or clutch fan and water pump tools? PM me. |
#63 |
Beware, my buddy tried cleaning his and the screw was impossibly tight and he ended up snapping the plastic filter disc. it shattered due to being so old and brittle.
#64 |
if helpful for someone, i found this video on youtube, you can take it as reference to clean the throttle body
#65 |
can someone clear up the whole "if you change your ATF, your transmission will fail because it is held together by sludge" myth thing?
im scared :[
![]() Jet Black 1994 325is -> Steelblue 2003 325i |
#66 |
hahahahahahaha nice myth!
#67 |
Yes. I can clear it up. That's a barnyard theory backed by barnyard mechanics. Do not be scared. Which leads me to the famous verse...
"Fear not the replacement of your automatic transmission fluid and filter for it is thy will and thy recommendation of the manufacturer." -Mango 13:14, New Testament - Bavarian Brothers BMW Club Replace it, Eclipsor. Nice meeting you at Bimmerfest, too. Didn't know you were in 818. Where at? We have to get together with LiquidDawn and crash some meets.
#68 |
what i'm referring to:
http://forum.e46fanatics.com/showthread.php?t=595553
#69 |
I'm in Granada Hills, and me an liquiddawn have crashed a few already, where have you been?
#70 | |
Take your car to Bjorn. He'll tune your auto trans right up while blindfolded. Ask Liquid who he is.
#71 | |
#72 |
Can I ask a quick question, how do you tell whether you need to replace your window regulator, or motor, or both?
for my front passenger window, the window works, but it goes up pretty slow and pops a few times, i searched and found out that this mostly means I need a new regulator as for my back windows, they havent worked at all since i got the car, no movement or sound whatsoever. does this mean they need new motors? are regulators and motors supposed to be changed at the same time? thanks, i want to have working windows before my trip to EDC in Vegas ahaha
#73 |
How about adding capacities for MTF and PS fluid?
Then I wouldnt have to do anything other than copy and paste
![]() 2004 330i ZHP |
#74 | |
You fill both 'til they're full. If you're simply evacuating the reservoir, one quart is enough. If doing the whole system, buy two. As far as MTF, two litres should cover it.
#75 |
Stay stock my friends!
Your motor in the window sounds like it's fine.
Also, 3M window weld roll is the stuff used to seal the vapor barrier. One $12 roll should be enough for all your doors...and it's also good for holding nuts and bolts into a socket in a difficult to get spot...like ccv. Just get the regulator. Use the marks from the original nuts to position the new regulator. If it turns out you don't need it once you open the door up, just return it unopened. Read a few of the diys...buy some extra door clips...get 10...you'll need them eventually...and you'll need a ziptie or two to effect a repair or to hold the cable down. Disconnect battery for 5 mins. before if you have an airbag in the door you're working on...and don't forget to position the window so you can get to the clips through the regulator. (You'll figure out what that means soon enough!)
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
#76 | |
You must keep your ambers. At the first sign of trouble with your aftermarket lights, any one, any where, you must replace all your lights...every housing, socket, bulb, wiring harness, fuses and relays. Don't think about it, just do it. Preserve your sanity by not worrying so much about replacing everything...but do enjoy low hanging fruit whenever you can! Buy Bentley...keep it by your nightstand Never be seen polishing your wheels in public...that's a private thing that should be kept in your garage.
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax Last edited by dmax; 05-25-2012 at 08:04 PM. |
#77 | |
#78 |
I included many helpful tips in that post, you know, but needed to comment on the prophylactic replacement of window regulators, because I think people here might think that's actually a good idea. My driver's window regulator went out at over 180K miles...and original regulator.
Please tell me you were kidding about the regulators...which is why I kidded back! I don't doubt you help many behind the scenes as do I...
#79 |
He said his front windows are popping and the rears dont work at all. He needs four new regulators. No two ways about it.
#80 |
I missed that part...just checked.
He has one front window that needs a regulator, and we don't know about the rear ones...it could be the 'child safety button' is pressed down...could be bad...and it could be two motors and two regulators back there. He should start with the simple things first...like press that button.
