The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 07-01-2012, 12:30 PM   #161
domcreates
My Ride: Jet Black 1999 323i
Need Help!
My car has been vibrating realllllly bad. Could it just be the tires? I'm ordering some new rear tires tomorrow and hopefully that will take care of it.
Yes i'll get an allignment once I get the new tires.
Can I get 205/50/16 tires for the rear or do they need to be 55 like the front?
Do I have to get the same tread pattern as the front?
FRONT:
REAR:
STUFF FOR SALE:
SEDAN CARBON FIBER CSL TRUNK
GET A CUSTOM GRAFFITI PHONE CASE DESIGNED BY ME:
CLICK HERE FOR PHONE CASES
POST YOUR E46 IN THESE THREADS IF YOU HAVE..
18" WHEELS
19" WHEELS
domcreates is offline   Reply With Quote
Old 07-01-2012, 12:34 PM   #162
djnekkon
My Ride: MB3ci Regensburg Bav
The thread pattern doesn't have to be the same, but I recommend you to get 55 too for the rear. Otherwise, it would be like having 16's wheel at front and 15's at rear.
Old 07-01-2012, 01:49 PM   #163
ImSoFreaknWhite
My Ride: '06 M3 SMG VERT
Send a message via ICQ to ImSoFreaknWhite Send a message via AIM to ImSoFreaknWhite Send a message via Yahoo to ImSoFreaknWhite Send a message via Skype™ to ImSoFreaknWhite
Nice tread
Jordan
My Build Thread
EuroSpec CSL V1 Bumper l CSL One-Piece Lip l 18x10 Square HyperBlack APEX ARC-8 l Black Grills/Gills & Emblems l Carbon Fiber Roundels
Status Rear Section l Carbon Fiber Intake Duct l Gruppe M Intake l OEM JB Hardtop l Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL Trunk
ImSoFreaknWhite is offline   Reply With Quote
Old 07-01-2012, 02:36 PM   #164
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
Tires dead? Buy useless shifter instead of new tires.
Old 07-01-2012, 02:44 PM   #165
domcreates
You're sure the tread pattern doesn't matter?
If so then what tires do you guys recommend for the rear?
http://www.onlinetires.com/user/vehi...allbrands.html
Cheaper the better but I don't want ones that are going to be hella loud or die quick
Thanks!
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-01-2012, 02:46 PM   #166
domcreates
Yea since that shift knob/beer tap took up all my money?
I have plenty of money to get tires.
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-01-2012, 03:26 PM   #167
djnekkon
Thanks!
It does matter, but we are not driving M3's where grip and other things count for track etc...Just make sure you get the same size and brand at rear (Both rear tires). If you're are to spend a bit more, then get a type that best suit your driving. Where I live now rains everyday, so summer tires that work good on water is what I got.
Old 07-01-2012, 05:05 PM   #168
domcreates
Ok thank you man
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-05-2012, 10:07 PM   #169
domcreates
Please let me know if you know of one! I've decided to fix up my interior before other things.
http://forum.e46fanatics.com/showthr...7#post14545737
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-11-2012, 12:02 PM   #170
domcreates
got new tires because I needed them and to hopefully get rid of the bad vibrations.
got the tires on and drove around, the really bad vibrations were still there.
Took the car to the shop to get diagnosed. It sounds like it might be my left rear wheel bearing. I just had the right rear one replaced.
They haven't had time to look at it yet.
Interior work will have to wait.
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-11-2012, 01:28 PM   #171
djnekkon
the bearing also sound stupidly loud whee running. Did you check your control arms/bushings?
Old 07-11-2012, 02:39 PM   #172
98bimmer
My Ride: 99 C23k, 01 330i
Also could be a minor bends in your wheels, might want to check those as well.
98bimmer is offline   Reply With Quote
Old 07-12-2012, 01:17 AM   #173
domcreates
It is really loud when running? I didn't check those, it's at the shop already so they'll take a look. Thanks for the heads up though. I need the car fixed asap so I can get to work and not have to take my moms car lol
That could be it! The mechanic mentioned that a couple times a while ago that the wheel might have a slight bend. I'll call and ask him to check that out.
Thanks for the words of advice guys. When the mechanic tells me what's wrong, i'll ask you guys to see if I can fix it on my own.
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-13-2012, 11:59 PM   #174
domcreates
The problem was the hub. Spent about $500 to fix it. Hopefully i'll be able to start the interior after my next pay check. GF is coming to visit at the end of July so I need to start saving money for that also lol
I wish all my hubs looked like this one we replaced
Before:
After:
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-14-2012, 12:29 AM   #175
djnekkon
+1 on saving money. I am Glad you found the problem and it got fixed fast. Enjoy brosky!
Old 07-14-2012, 08:12 AM   #176
domcreates
Thanks man, you're saving for the gf or something else?
also my cars handling has either turned to **** or its a lot better than it has been and i'm not used to it.
I'm guessing this is because of the new tires of course, but why exactly?
I start taking a hard turn and it feels normal, then all of a sudden it cuts hard and I'm not turning the wheel anymore than I was...
Is it because of the different tread patterns? Because the tires were inexpensive? Or just that i'm not used to having a lot of tread on my rear tires since I came home from college and have been driving with barely any tread until now?
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-14-2012, 10:58 AM   #177
98bimmer
The handling got worse or better? Should be better because of new tires. Cheap new tires are better then used bald tires regardless.
Old 07-14-2012, 11:18 AM   #178
djnekkon
+1.
I would also visually check the Control Arms, Sway Bar Links, Tie Rods, Strut mount points or a worn spring pad. I do this a lot, I just remove my wheels and look very carefully.
as an example check this guy videos
Old 07-14-2012, 07:45 PM   #179
domcreates
+1.
I'm not sure whether to say it's better or worse, I'm so used to cornering the way I used to with the old tires that now it feels really weird. I'll just get used to it haha I'll check all that asap DJ, thank you for the video
STUFF FOR SALE:
18" WHEELS
19" WHEELS
Old 07-23-2012, 09:05 AM   #180
domcreates
My rear right window decided to crap out on me now. how do I find out what's wrong with it? I'm guessing it's the motor?
STUFF FOR SALE:
18" WHEELS
19" WHEELS
-*nga*-
