Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 05-29-2012, 08:14 PM   #1
ryanmyo
My Ride: 325i Imola M Sport
behr vs wahler thermostat
Any thoughts gentlemen? Im about to pick one up from pelicanparts
ryanmyo is offline   Reply With Quote
Old 05-29-2012, 08:16 PM   #2
Blocked Out
My Ride: Imola 330i M-Sport
Walher
Original BMW Teile ///
IMG_1725
Old 05-29-2012, 08:16 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
BMW switched to Wahler later on for reasons that I don't know, but I would imagine Behr fixed whatever that issue was by now that caused them to switch over.
I went with Behr, simply because I have mostly Behr parts in my cooling system (expansion tank, cap, radiator). I try to keep manufacturers as close as I can to each other for compatibility's sake. Is that a little paranoid? I dunno, but I just find things tend to work better when they're made by the same manufacturer
Either way, you'll have solid performance from both.
Old 05-29-2012, 08:25 PM   #4
ryanmyo
Beautiful. Thanks for your quick thoughts gents, i think ill stick with the oem wahler.
Old 05-29-2012, 09:25 PM   #5
Sweetness
My Ride: '01 325i
10k with wahler..no problems.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 10-10-2012, 07:58 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Bump. Been looking around and Behr looks like the way to go. Correct?
Old 10-10-2012, 08:02 PM   #7
a32axo
My Ride: 2004 bmw 330CI
Behr, my wahler recently leaked from connection
a32axo is offline   Reply With Quote
Old 10-10-2012, 10:48 PM   #8
robj213
My Ride: '03 325i
Have a Wahler installed for almost 50k miles now and no issues at all so far.
robj213 is offline   Reply With Quote
Old 10-11-2012, 12:32 AM   #9
illestminimike
My Ride: Project Drama
Where the hell is Mango?
Old 10-11-2012, 06:29 AM   #10
PerfectStorm01
My Ride: 320Ci
My wahler leaked within 2 months so swapped it with a behr and no problems.
PerfectStorm01 is offline   Reply With Quote
Old 10-11-2012, 06:57 AM   #11
jfoj
My Ride: 330CiC, M5, X5, E93
For you US guys, I am starting to get with Stant stats when available. For example for my M5 the OEM thermstat from the dealer with the stupid inner seal is around $110. I found a Stant direct fit with the inner seal for under $20 on my doorstep.
Check Rock Auto and Amazon.com for pricing and application.
I figure all the stats will fail at some point, but Stant has been making them for years and by the millions so they should be able to get them right by now.
Not sure I have been excited about Behr, but this is what was used in my M5 before.
Old 10-11-2012, 08:10 AM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
I have a Wahler on my car and I know it's failing/failed. 77C and the needle is in the middle? I think not.
Old 10-11-2012, 09:49 AM   #13
My Ride: Lexus
Huh? Are you talking about replacing the thermostat inside the housing? Like individually? What do you mean by using a stant on the E46? Confused.
As for brand... you guys guesses are as good as mine. I have a Wahler. 30,000 miles and all is perfect. I think either would be fine. Wahler is OEM though.
Old 10-11-2012, 10:05 AM   #14
Solidjake
Zero. Leaks.
Solidjake's Avatar
I'll double check in an hour what I have, most likely wahler.
Old 10-11-2012, 10:08 AM   #15
My Ride: Lexus
Behr:
Wahler:
Behr is $45 and Wahler $42 (BMA)
Old 10-11-2012, 11:33 AM   #16
pawelgawel
My Ride: 330CI
bear looks to be from a different plastic compound..
looks more oem :p:what:
Sent from my SGH-I727R using Bimmer App
pawelgawel is online now   Reply With Quote
Old 10-11-2012, 11:41 AM   #17
My Ride: Lexus
Any difference in color is likely due to the AWB setting of the camera or the particular way the image was processed. Don't think too far into the color.
Old 10-11-2012, 12:23 PM   #18
cvx5832
My Ride: 325Ci, 325Cic, C300
Same experience here, 48k and the Wahler is fine.
cvx5832 is offline   Reply With Quote
Old 10-11-2012, 12:25 PM   #19
pawelgawel
My Ride: 330CI
i was kidding Mango... either one will do the job
Old 10-11-2012, 12:33 PM   #20
Solidjake
Zero. Leaks.
Solidjake's Avatar
^ Not when my wahler starts to fail after 30k miles.
