Old 05-29-2012, 09:26 PM   #1
philandrews
My Ride: Bmw 318i e46 1999
Bmw 318 e46 cold start problem / cuts out
Having trouble starting my bmw in the morning when its cold. I've taken it to two garages and there are no fault codes on the computer. I've replaced the MAF myself but it does not it seem to have made a difference. When its warmer I can start it easier, I need to rev it a bit then it will idle at around 1000rpm, seems fine on the open road too. Any help would be appreciated.
Made a quick vid which shows the issue.
philandrews is offline   Reply With Quote
Old 05-30-2012, 03:49 AM   #2
jcjdavis1
My Ride: 323ise 1999 saloon
Hi. I have had the same problem for 3yrs, your cold is not as bad as ours but I have changed nearly every sensor and hose and still no luck. Good luck. Jim
PS Start with your vacuum hoses.
The older I get the wrong bit gets stiff!!
jcjdavis1 is offline   Reply With Quote
Old 05-30-2012, 05:02 AM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Check the sap hose from pump to valve...check the valve for a clog in the inlet (from decayed hose collecting inside it like mine).
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 05-30-2012, 07:39 AM   #4
mojako
My Ride: bmw
This happened to me once (318i N42 engine). I just had my solenoid o-rings replaced.
I removed them, cleaned my solenoids and installed them again. Then the sputtering went away.
mojako is offline   Reply With Quote
Old 07-10-2015, 02:30 PM   #5
Rocktion
My Ride: BMW E46 318
Hi guys,I also have the same problem and I don't seem to understand which solenoid and sap hoses they are talking about.pls pls please help.
Rocktion is offline   Reply With Quote
Old 07-10-2015, 02:45 PM   #6
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Check the fuel pressure. The fuel pump may be failing.
What are the trouble codes you read with your OBD code reader? Not sure if your car has an OBD plug or not.
///Mmmmmm...
