Old 05-27-2012, 09:10 PM   #1
scotts330
My Ride: 330Ci
Question Is my inner tie-rod bad?
Gentlemen,
I have a bad lower control outer ball joint for sure...got the pirate ship creak and some play. I'm wondering if my tie rod assembly should be replaced while I'm doing the control arms, since both require an alignment (plus I think I have some play in the tie rod).
Background: 2002 330Ci 158k miles; new LCA (Meyle) in 2006 at ~95kmi. Whole front-end of the car is jacked up, and steering wheel is locked.
First video views the LCA outer ball joint and outer tie rod...lots of play in the LCA outer ball joint:
Now the tricky one; is this tie rod bad? (I can see some relative motion between the tie rod ball and tie rod socket.)
Your thoughts would be greatly appreciated!
Thanks,
scotts330
scotts330 is offline   Reply With Quote
Old 05-27-2012, 09:18 PM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
your control arms are shot.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 05-27-2012, 09:26 PM   #3
2003 325i
My Ride: '03 Orient Blue 325i
and that inner tie rod. Get both replaced and an alignment. Do not NEED to do both sides. I wouldn't.
Old 05-27-2012, 09:27 PM   #4
scotts330
My Ride: 330Ci
Thanks for the comment.
Indeed, the ball joint is shot--but is the inner tie rod also going south?
Old 05-27-2012, 09:30 PM   #5
scotts330
My Ride: 330Ci
Thanks for the comment. I'll probably do both, since blowing money on this car is my way of life!
Old 05-27-2012, 09:41 PM   #6
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'm not really seeing play in the tie rod.
Try control arms first. Although I know that we think alignment needs to be done after all suspension work, not much to change if you're only doing Control Arms. See what you end up with.
See me in NYC in May!
Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 05-27-2012, 10:27 PM   #7
2003 325i
dmax, if you look closely there's visual play in the ball/socket joint while opposing pressure at 9 and 3, I can't say for sure on the owner's outer tie rod end, but there is some inner, and it's much more than acceptable (which is none). I would replace both innner and outer tie rods on that side as well as the LCA. It may likely save the OP money to do both inner and outer as that may be time consuming to separate (due to rust), and the tech will thank you, especially on the alignment.
Old 05-28-2012, 06:39 AM   #8
dmax
dmax's Avatar
Ok, I looked closely, and you're right...I do notice some little play in the upper tie rod ball joint.
dmax on Facebook
Mangofy your E46!
Old 05-29-2012, 08:00 PM   #9
scotts330
My Ride: 330Ci
Smile
Thanks for the input guys--going to replace control arms, CA bushings, and tie rod assemblies on both sides. Going with Meyle (my first set of replacement LCA was Meyle; got about 55k out of them) from http://www.oembimmerparts.com/e46meylesuspension.html
Thanks again for your input!
Scott
Old 06-02-2012, 07:20 PM   #10
I8UrCat
My Ride: 06 325CI M-Sport
Outer ball joint for sure, inner tie rod end had slight play. There was more play from your steering rack bushings than the inner tie rod end.
I8UrCat is offline   Reply With Quote
Old 06-03-2012, 03:25 AM   #11
325rider
My Ride: gone, not forgotten
Send a message via AIM to 325rider
Wow I think this is my problem. MY car has 120,000 miles and its getting clunking really badly. Even from a stop if i give it a lot of gas sometimes it will clunk loudly just on weight transfer and I can almost feel vibration in the steering wheel it seems. Been happening for a week or so now. Need to do something about it It is starting to sound over every bump
Schrick 264/248 | Ebay Headers | AA dyno tune | SSR GT2 18x9 | 3.46 | Full OEM Mtech 2
My Fitness YouTube Channel!!! Thanks for all the support I am GRATEFUL
http://www.youtube.com/channel/UCozwn8gNwXQVuG0se8cTpUQ
325rider is offline   Reply With Quote
ball joint, control arm, suspension, tie rod
