Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 08-14-2012, 04:19 PM   #61
smooth1
My Ride: BMW FTW
No, it shoots out the lambda integrators. As I'm going to be tuning a lot of these cars I imagine I will be able to locate and add that data in the future for a lot of the newer DMEs, or if someone can find me a datasheet for the sensor as I do currently have access to the voltage.
smooth1 is offline   Reply With Quote
Old 08-14-2012, 04:21 PM   #62
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
Originally Posted by smooth1 View Post
No, it shoots out the lambda integrators. As I'm going to be tuning a lot of these cars I imagine I will be able to locate and add that data in the future for a lot of the newer DMEs.
Definitely awesome!
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
Old 08-14-2012, 04:47 PM   #63
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Maybe this might help...
http://www.picaxeforum.co.uk/showthr...e-lookup-table
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
Old 08-14-2012, 05:02 PM   #64
smooth1
My Ride: BMW FTW
Thanks for looking around. It does not say there what the sensor they're using is from and they're not all the same. The 08M they're referring to is not a BMW.
Old 08-14-2012, 05:05 PM   #65
BimmerBrakes
The Brake Newbie!
Yes, I know that. Its a 8 pin micro chip. I am not sure what voltage you get from the BMW DME but down on the list there is a voltage to AFR conversion. Might help but might not. Doesn't hurt to try.
Old 08-14-2012, 05:15 PM   #66
smooth1
My Ride: BMW FTW
Ya, but that's not likely for the sensor BMW is using for MS45. I see no mention of BMW at all.
Old 08-14-2012, 05:41 PM   #67
BimmerBrakes
The Brake Newbie!
17014, 17215 and 17216 is widely used for Wideband Monitor Tools. Difference between them is the Plug and Length of the Cable on the sensor. Can also make your own if you have the know how.
Old 08-14-2012, 06:15 PM   #68
smooth1
My Ride: BMW FTW
Aftermarket stuff, absolutely. I'll be checking to see if BMW uses any of those and I'll let you know what I find. Thanks for the info here and in PM!
Old 08-15-2012, 07:04 PM   #69
jared_wiesner
My Ride: 1999 328i (M54b30)
I'm definitely going to be purchasing this. I was just wondering if you already have or would be able to add the ability to see A/F ratio based on Lambda readings. Just makes it easier than for me to multiply each reading out myself to find the numbers. Even if it was just a toggle between Lambda voltages and A/F ratio.
jared_wiesner is offline   Reply With Quote
Old 08-15-2012, 07:08 PM   #70
smooth1
My Ride: BMW FTW
I'm currently researching what sensors are on what vehicles hoping to make A/F a logged datapoint for most DMEs. As for now you get to see the lambda integrators at work.
Old 08-16-2012, 02:58 AM   #71
xcar360
Past Site Sponsor
My Ride: BMW 318i
Smile Renault CAN Clip Interface
Renault Can Clip main menu allows you to:
See all the information relating to the vehicle
Look at the function you want to use:- computer test
Automatic test of all computers
Reprogramming
Airbag test
Scantool (OBD tests)
Base Doc (access to Technical Notes)
Physical measurements
Antipollution
Multimeter
Renault CAN Clip package includes :
1. Renault CAN Clip Interface
2. 2 cables for CAN Clip <-> Car connection
3. 1 cable for CAN Clip <-> PC connection
4. 1 software CD (CLIP V115, can be installed on ANY PC)
It's very simple to diagnose a vehicle using Renault CAN Clip Diagnostic Interface: just select the vehicle make, enter the V.I.N. and press ENTER.
Renault CAN Clip Support language: English,German,Brazil,Denish,Spanish,Finnish,French,Italian, Norwegian,Dutch,Portuguese,Romania,Swedish.
see the following pictures shows.(Picture one shows the optional country; Picture two shows the Language available)
http://www.xcar360.com/renault-can-clip.html
xcar360 is offline   Reply With Quote
Old 08-16-2012, 03:03 AM   #72
xcar360
Past Site Sponsor
My Ride: BMW 318i
Thumbs Up Renault CAN Clip Interface
Reprogramming
Airbag test
Antipollution
Multimeter
Old 08-16-2012, 09:26 AM   #73
smooth1
My Ride: BMW FTW
Hey, thanks!
Old 08-16-2012, 11:23 AM   #74
TrippinBimmer
My Ride: Just Fast!
lol is he just spamming?
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 08-16-2012, 11:40 AM   #75
smooth1
My Ride: BMW FTW
Ya lol. Just looking for some attention.
Old 08-21-2012, 06:20 PM   #76
NIVO
This software works!
cool to see the datalogs
Old 08-22-2012, 03:17 AM   #77
daniel_f.
My Ride: 330iC
realtime lambda values would be somewhat awesome
Old 08-22-2012, 09:54 AM   #78
smooth1
My Ride: BMW FTW
We talked about that above.
I'd like to see if you're running rich or lean too since you're unable to hit your top speed now. I also posted that log in the datalog demo area of the site. Thanks, btw.
Old 08-22-2012, 02:44 PM   #79
TrippinBimmer
My Ride: Just Fast!
MS45 still have some bugs? Cant Register Battery and some error about can't read packet from DME...
Alpine White M3
MaximumPSI Stage4
Old 08-22-2012, 03:07 PM   #80
smooth1
My Ride: BMW FTW
NIVO and I got everything up and running with MS45 logging. Thanks NIVO! E46 doesn't require battery registration since it doesn't have IBS so you'll always be denied for that request. MS45 on the E60 5 series does have IBS, so it will work for that.
