Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 08-31-2012, 05:00 PM   #101
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Originally Posted by smooth1 View Post
YUP. Already in the works. Direct serial logging for LC-1, LM-1, and LM-2 USB.
Like a boss Excited to see that feature...You go email
BimmerBrakes is offline   Reply With Quote
Old 08-31-2012, 05:10 PM   #102
smooth1
My Ride: BMW FTW
Newer PLX too.
smooth1 is offline   Reply With Quote
Old 08-31-2012, 06:07 PM   #103
BimmerBrakes
The Brake Newbie!
Newer PLX too.
When would this be ready for testing? My Lc-1 is all hooked up and ready to test
-Anthony@BimmerBrakes
Old 08-31-2012, 06:13 PM   #104
smooth1
My Ride: BMW FTW
Will keep you posted. Have a few things going on, including the holiday weekend.
Old 09-02-2012, 05:08 AM   #105
alex230ro
My Ride: BMW 325ti compact
so a cable for INPA will work with this product?will work on european models?MS43 is the software that i have but i don konow if there are any differencet between EU and US .
thanks
alex230ro is offline   Reply With Quote
Old 09-02-2012, 06:31 AM   #106
AMCINK
My Ride: 2000 323CI
I need this for E30,e36,e46 and e46, which software to download?
AMCINK is offline   Reply With Quote
Old 09-02-2012, 08:25 AM   #107
daniel_f.
My Ride: 330iC
thanks
No difference between euro and us except the change from ms43 to ms45 with the facelift in usa.
im using the software since the first release and even better then the software itself, is the support from james
Old 09-02-2012, 09:57 AM   #108
smooth1
My Ride: BMW FTW
You can see what the software covers on the product page. I have not done much with E30 because of the lack of interest. E36 and E46 are already fully supported.
Thanks for saying so. MS43 and MS45 are both fully supported.
Old 09-02-2012, 10:56 AM   #109
AMCINK
My Ride: 2000 323CI
[QUOTE=smooth1;14699241]You can see what the software covers on the product page. I have not done much with E30 because of the lack of interest. E36 and E46 are already fully supported.
How about e53 ( i have 5 bmw)
For the e36 i need to get the recommmended cable + an adapter for the 20 pins correct? Which adapter thought?
Old 09-02-2012, 11:06 AM   #110
smooth1
My Ride: BMW FTW
Which DME? If it's a 3.0 it may have MS43. If it's a 4.4 it could have a few different older DMEs. I haven't fully supported the older stuff yet, as there's only a few older DMEs with protocols that are fast enough to support real-time logging. Are you just looking to check and clear codes or what? The much slower protocols really aren't worth buying logging software for, which is why I only support what I do currently.
Any compatible K-Line cable and the OBD2 to 20 pin BMW adapter. They can be found all over including places like http://interfaces4beemers.com
Old 09-02-2012, 02:21 PM   #111
daniel_f.
My Ride: 330iC
a few guys over here are still interested in DDE
Old 09-02-2012, 02:43 PM   #112
smooth1
My Ride: BMW FTW
Can you give me the models they're interested in?
Old 09-02-2012, 04:21 PM   #113
daniel_f.
My Ride: 330iC
It should be DDE4.0 EDC15C2
Old 09-02-2012, 04:52 PM   #114
smooth1
My Ride: BMW FTW
Will look into it this week. Got an email for EDC16 as well.
Old 09-03-2012, 03:35 PM   #115
daniel_f.
My Ride: 330iC
does anyone have a logfile from a M54B30 (NA) with MS43 doing topspeed? im REALLY interested in comparing the values
Old 09-12-2012, 10:29 AM   #116
mrf
My Ride: Car
Just bought the software for my MS41! Now it's time to go test.
Is the following the extent of what can be datalogged? It would be extremely helpful to be able to log MAF, Engine Load, and Knock Signal. How can I help you add support for that?
Release of MS41 logging support.
RPM
TPS Voltage
Speed
Intake Air Temp
Engine Coolant Temp
Ignition Timing
Fuel Pulse
Cam Position
Lambda Integrator 1
Lambda Integrator 2
Battery Voltage
Datalogging speed increase for MS42, MS43, MSS52, and MSS54.
How much did the speed increase by? Is something similar possible for MS41?
mrf is offline   Reply With Quote
Old 09-12-2012, 11:06 AM   #117
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Just bought the USB cable! Going to check it out on my ms43 hopefully be able too reset my adaptations and get some pids. And maybe buy it
325CiMaN is offline   Reply With Quote
Old 09-12-2012, 11:12 AM   #118
smooth1
My Ride: BMW FTW
I've added LOAD and I will be adding MAF. MS41 is not as good for logging, so the more items I add the slower it will be. That's why it's cheaper.
The speed increased a lot, but that's not something MS41 is capable of at all.
You'll be able to reset adaptations and check/clear codes without a license. If you do clear adaptations be aware that if your engine/components aren't in the best shape it may idle rough after you clear adapts. You can start the vehicle with the throttle down for about 10 seconds to help normalize the running.
Old 09-12-2012, 01:24 PM   #119
mrf
My Ride: Car
OK, thanks. What did you do to increase logging speed for the other ECUs? And why doesn't it work on MS41?
Also, with your program, will I able to select just a few items out of the set to be logged? I don't want to be forced to log everything just because it's there. Sometimes it's better to only long the items one is interested in.
Old 09-12-2012, 02:17 PM   #120
smooth1
My Ride: BMW FTW
MS41 is older and doesn't have the same options, as you'd expect from the model number.
No. It grabs everything I allow you to log, and it's fast in doing so... just not as fast as MS42 or MS43.
