Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > NY / NJ / CT
NY / NJ / CT
NY NJ CT
Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 12-26-2012, 01:51 PM   #21
zhenkaaaM3
My Ride: Fst'r then your e46
Originally Posted by VonGeiss View Post
I may be interested in these as well, as soon as I get my car back!!!
Pm me when ready
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 12-30-2012, 10:53 AM   #22
1nyce46
My Ride: 02 bmw 330i
Send a message via AIM to 1nyce46
Pm sent
my dog leo is the best!
1nyce46 is offline   Reply With Quote
Old 12-30-2012, 11:47 AM   #23
zhenkaaaM3
Originally Posted by 1nyce46 View Post
Pm sent
Didnt get anything
Eugene
Old 12-30-2012, 12:14 PM   #24
dambro24
My Ride: 330ci
How much for the simulor coe readers?
Sent from my SPH-D700 using Bimmer App
dambro24 is offline   Reply With Quote
Old 12-30-2012, 05:17 PM   #25
1nyce46
Sorry I sent you a private message that how much are they and when can I get them cause I needed inspection lmk thru pm thanks my car don't pass cause of cat problems
Old 01-07-2013, 02:20 AM   #26
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
More information on the 02 sims
Hey Eugene,
Just found this thread. thanks buddy!
LEGAL NOTE: These are solely for "off road use" if you plan on using them to pass emissions, your accountable, and I'm not responsible for what you do with the 02 emulators. I will just be responsible for the emulators to do their job and work as described.
More information on the 02 sims:
HOW do they work?
When attempting to simulate a post 02 sensor or down-stream sensor, there are two areas that need to be emulated; the voltage the ECU sees ranges from .1v (lean) to ~.9v (rich) the second area is heater part, thats built-in to the 02 sensor (used to accurately read the Air/Fuel ratio or AFR)
What I have done is used a resistor and capacitor to show the ECU a consistent voltage (.415v) witch seams to keep the ECU happy and keep the car in open-loop right before the closed-loop mark (.45v) so logically speaking the car stays at a perfect balance between rich and lean ~ 14.7 AFR. This method I found out was a hit or miss, as the spark plug defouler method.
A more complex circuit would need to be built so the ECU does not flag the consistent voltage. This would call for a oscillating signal generator, that would oscillate the voltage signal from .11v to .81v greatly mimicking what a typical working post-cat 02 sensor should be doing, and in-turn, keeping the ECU happy.
For the heater, I now put a large military-grade resistor in-line, between the heater wires of the 02 sensor, keeps the ECU from throwing a fault for the heater sensor.
how do I order them?
Since I do this on the side, and haven't found a vender to produce 02 sensor connectors, there will be 3 ways to go about it:
1. Send me both post-02 sensors ( I cut them 2" from the sensor, then include them when shipped back)
2. Cut off 2-3" from the connectors (see attached diagram)
3. You don't send me anything, I just make the 02 sim (with leads) and you hard-wire it to the 02 sensor wires.
Please note for number 3: You will need a multimeter to find the polarity in the same color wires(white) or follow wires to the correct color at the other end of the connector. Also if the polarity is not correct, the 02 sim can be fried!
PM me if you would like to order them!
ABOVE is a video of live data (on BMW e46) showing the difference between the more complex slim oscillating (02B1S2) for Bank 1 sensor 2. The simple, consistent voltage (02B2S2) for bank 2 sensor 2.
Name:	cutting diagram.jpg
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
Old 01-07-2013, 10:40 AM   #27
zhenkaaaM3
Eugene
Old 01-07-2013, 12:21 PM   #28
Think0rz
My Ride: 05 AW M3
i need an emissions as my car will never pass
Think0rz is offline   Reply With Quote
Old 01-08-2013, 01:00 AM   #29
bimmerguy055
My Ride: M3
PM me
Old 01-08-2013, 01:01 AM   #30
bimmerguy055
My Ride: M3
Latest version
Old 01-19-2013, 12:23 PM   #31
limpiabota809
My Ride: 330 XI
pm'd
limpiabota809 is offline   Reply With Quote
Old 03-04-2013, 03:56 PM   #32
straight_beamin
My Ride: 2000 bmw 323i
I bought these and p0161 and p0141 vanished for 2 days. Now p0141 is back and inspection is in 5 days!! What to do??!!
straight_beamin is offline   Reply With Quote
Old 03-04-2013, 07:04 PM   #33
The Thomas J
My Ride: 2002 325Cic
When I drove Caddy's I used the same resistor's to disable the suspension error messages after swapping the air & magnetic strut system for a passive setup.
The Thomas J is offline   Reply With Quote
Old 03-04-2013, 08:32 PM   #34
bimmerguy055
My Ride: M3
I have PMed a solution
Old 03-04-2013, 09:06 PM   #35
straight_beamin
Will report back guys! Seems to definately know his stuff!
Old 03-04-2013, 09:56 PM   #36
straight_beamin
Fixed the wiring hiccup! Works like a dream. Pull the trigger if you are considering because these things work!
Old 03-04-2013, 11:11 PM   #37
zhenkaaaM3
There ya go!
Eugene
Old 03-05-2013, 07:22 AM   #38
straight_beamin
Woot woot! So happy
Old 03-05-2013, 10:28 AM   #39
straight_beamin
Wait -_-. Isnt there still a visual? Check for cats n crap or smoke from exhaust. I read that if they see smoke or no cats they wont even test it -_-
Old 03-05-2013, 10:55 AM   #40
zhenkaaaM3
Nobody ever looked if i had em in new york so... i dont think so
Eugene
