SMG Shudder in 1st Gear - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Canada > BC, AB, Saskatchewan, Manitoba
Find other members from your area in the enthusist directory.
AB BC Saskatchewan Manitoba
Old 06-04-2012, 05:29 PM   #1
///M Powerd
My Ride: 2003.5 M3 Coupe
Hi all,
I have done quite a bit of searching on this but not found a definite answer. I own a 2003.5 M3 SMG and when accelerating from a dead stop i occasionally get a shudder and a quiet thunk seeming to come from the drivers side wheel well around 800-1000 rpm. Using sport mode seems to make this a bit better (probably because the rpms raise quicker).
I wondered if any other local M3 SMG owners can comment on this as solutions on the forums seem to range from SMG resets, new clutches/flywheels to its normal, deal with it.
Thanks,
Steve
///M Powerd is offline   Reply With Quote
Old 06-04-2012, 06:46 PM   #2
taylor192
My Ride: 2003.5 M3
I'm not sure what the "thunk" is, yet I get a ~500 rpm drop from idle when accelerating in 1st gear. Its not consistent, and there's a million posts on M3Forums with various suggestions yet no definitive answer. Do your RPMs suddenly drop?
Old 06-04-2012, 10:04 PM   #3
alvinchow
My Ride: M3
I don't think is smg related, more the suspension play noise?
alvinchow is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-04-2012, 10:46 PM   #4
///M Powerd
Thanks for the replies guys. I havent noticed any RPM drops. Is the only way to check the suspension to put it up on a lift? The PO had a set of Bilstein Coilovers installed before I bought it. I dont know if that would make a difference.
Old 06-05-2012, 12:55 AM   #5
alvinchow
My Ride: M3
lift the wheels and shake 3 and 9 position for steering, 12 and 6 for the bearings
see turnin wheels in the air makes that noise
Old 06-05-2012, 01:14 AM   #6
///M Powerd
thanks i poked around under there with a flash light but couldnt see anything obvious. i guess the next step is to lift er up and try that out. ill let u know what i find this weekend since i dont have at jack at my place here ill head out to my dads.
on a side note i got my first speeding ticket on my way back from the ferries testing it out in west van...ghost car w/lazer detector
Old 06-05-2012, 04:07 AM   #7
keinz
My Ride: '04 M3
what do you drive in mostly S1-S6?
I have that shudder once in a while, drive the car rough for a bit in S5/S6 and it should go away
if not, can always try a SMG reset (via holding down both paddle shifts at ~40mph+) so the computer can re-calibrate to the amount of life your clutch has
keinz is offline   Reply With Quote
Old 06-05-2012, 11:14 AM   #8
///M Powerd
I am mostly in S3-S4. I'll give the higher settings a try and try out the SMG reset too. Thanks all for your suggestions.
Old 06-11-2012, 10:29 AM   #9
Hockeyman17
My Ride: 2005 E46 M3 SMG
I get the same shudder in first gear occasionally. Ive had it since I bought the car a few years ago. No idea what it is.
Hockeyman17 is offline   Reply With Quote
Old 06-11-2012, 11:46 AM   #10
///M Powerd
I tried the SMG reset and it seems to have cured the shudder. Still getting the noise from my front driver suspension starting from a standstill so I'm going to take it and get looked at. Doesnt seem bad but better safe than sorry I guess.
Old 06-19-2012, 11:46 AM   #11
Hockeyman17
Update:
I did the SMG reset by holding both paddles going over 40MPH and it seems to have completely cured the shudder. That was easy
Old 06-19-2012, 11:47 AM   #12
///M Powerd
Old 06-19-2012, 04:51 PM   #13
///M Powerd
Ok quick update. Took it into Nixon and they say the popping noise is the aftermarket brake pad moving around a bit in the caliper as its not quite the right size. Anyone ever heard of this?
Old 06-19-2012, 05:27 PM   #14
taylor192
My Ride: 2003.5 M3
Do you know the brand of pads? I just did my front pads and they were a very tight fit, also dirt cheap @ $40:
http://store.bimmerworld.com/perform...ads-p1074.aspx
Oh, sorry for not getting back to you this weekend. Started drinking then forgot
Old 06-19-2012, 05:42 PM   #15
///M Powerd
No idea on pads brand. The PO had them put in. If I were to order these, can i just change on set or will I have to do all four sides? Hahaha no worries, as we all know alcohol is the cause of and solution to all life's problems
Old 06-19-2012, 10:57 PM   #16
taylor192
My Ride: 2003.5 M3
Not sure if I understand? Do you mean: Do you have to change all 4 front pads? Yes, you should for brake balance - and you should measure your front rotors to see if they need to be changed at the same time since its only 2 more bolts to change them.
Old 06-19-2012, 11:10 PM   #17
///M Powerd
Yup thats what I meant. Chris checked the pads and rotors, almost brand new. I'll see how much this bothers me and look into those pads. He recommended OEM pads as they give the best braking power Said the play in the pad wasn't causing any issues so no need to change em unless the sound is bugging me.
Old 09-30-2012, 04:27 PM   #18
chetured
My Ride: 2003 M3
See my other post just do a full smg reset using carsoft or gt1 works wonders !!!
Shay Reddy
2009 335i M Sport
2003 M3
2001 330i M Sport
chetured is offline   Reply With Quote
Old 12-23-2012, 08:15 AM   #19
dal1557
My Ride: m3 e46
bad gear changes
hi
when am slowing down to junctions my m3 comes down the gears am sometimes getting a clunking noise and the car kangaroos a bit
can anyone advise ????
dal1557 is offline   Reply With Quote
Old 12-25-2013, 09:22 PM   #20
maw1124
My Ride: Allroad; S55; 500E
Originally Posted by Hockeyman17 View Post
Update:
I have had the same issue, but I've noticed it is only when the car is cold. I will try the SMG reset though and see if that cures it, just to build a library on the issue for the forum. No O2 sensor codes for me, although I have had this on other cars before the cars warm up -- a form of uneven acceleration. '05 M3 Convert, SMG, 79k odo.
Merry Christmas, Gents.
maw
maw1124 is offline   Reply With Quote
