Old 06-04-2012, 08:00 PM   #1
DOC_Race
My Ride: 03 M3
E46 Topmount Tubular Turbo Manifold
Hey everyone! Just picked up an E46 M3 SMG and i'm really excited about this car and have completely enjoyed it the last few weeks.
DOC-M3-1
I am working on building a topmount tubular manifold setup for this car. I am coming from a 2003 350Z which was great; I built a "mid-mount" single turbo system for it to gain some extra power but became limited. By building a topmount setup, I feel the manifold design will be much more capable of power potential: i.e. better merge collector, wastegate outlet for boost control, no scavenge pump system (which was needed with my 350Z mid-mount setup)
I started by creating some space for the turbo with a new coolant expansion tank.
DOC-M3-2 (2)
DOC-M3-3
That definitely free'd up some space for the turbocharger to exist in the bay; should be picking the turbo up the next few days to continue forward with necessary deletions and modifications so I can begin building the tubular manifold. Looking at a 62mm Precision Turbo right now, i'll be sure to update as soon as it's in-hand!
DOC_Race is offline   Reply With Quote
Old 06-04-2012, 08:09 PM   #2
Commanderwiggin
My Ride: 900rwhp Turbo M3
Nice!
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Commanderwiggin is online now   Reply With Quote
Old 06-04-2012, 08:18 PM   #3
jtrejo
My Ride: e46 m3
in for the build!
2006 Vert AW/Cin. SMG SOLD
Custom Designed WON Direct Port Nitrous System
jtrejo is offline   Reply With Quote
Old 06-04-2012, 08:20 PM   #4
djtrini
My Ride: 04 M3 & 05 330i ZHP
Sweet!!! In for the build as well!!
djtrini is offline   Reply With Quote
Old 06-04-2012, 08:42 PM   #5
MaverickM3
My Ride: gets badge
Nice project OP.
Can you just start with 76mm turbo. That way we know they will all fit. LoL.
MaverickM3 is offline   Reply With Quote
Old 06-04-2012, 08:56 PM   #6
SlideFox
My Ride: A Bucket w/ 4-Wheels
Nice!!
Specs on the Z?
SlideFox is offline   Reply With Quote
Old 06-04-2012, 08:57 PM   #7
Snik
Snik's Avatar
My Ride: IR M3 Vert.
oh sh1t
Do you ride a sportbike?
Old 06-04-2012, 09:06 PM   #8
dan avoN7
My Ride: A car
Awesome! Subscribed for future updates
dan avoN7 is offline   Reply With Quote
Old 06-05-2012, 03:02 AM   #9
Dreikraft
My Ride: slow m3
bout time someone did this!
any plans on reproducing this if its a success?
Dreikraft is offline   Reply With Quote
Old 06-05-2012, 04:00 AM   #10
zcchen
My Ride: Z3M/F80M3
Keeping AC? or no?
zcchen is offline   Reply With Quote
Old 06-05-2012, 04:36 AM   #11
Cipri
My Ride: E46 M3 2002
You need to relocate alot more things to do a top mount!
http://forum.e46fanatics.com/showthr...640&highlight=
Good luck with the build!
Cipri is offline   Reply With Quote
Old 06-05-2012, 09:53 AM   #12
02black330ci
My Ride: spaceship
This is a GREAT idea! By any chance are you guys the ones that built HPF's drag car exhaust manifold http://docrace.com/ ? Also, just for starters those of us who would be interested in this set up, have our aftermarket ECUs right where you relocated the expansion tank to, so please take that into consideration for this build if it's going to cater to the masses.
02black330ci is offline   Reply With Quote
Old 06-05-2012, 01:31 PM   #13
DOC_Race
My Ride: 03 M3
Originally Posted by MaverickM3 View Post
Nice project OP.
I will definitely keep 76mm in-mind when building! I just started mapping things out and am planning to keep my engine factory internals (for the time being) so am looking at smaller frames for the initial build and response.
Originally Posted by SlideFox View Post
Nice!!
Specs on the Z?
My Z setup was a 67mm "mid-mount" factory VQ35DE engine that I realized was very limited in stock form when looking towards the 500whp range less the solid 6 spd trans.
Reproduction is definitely a possibility, this is the early stages of design so I will be sure to keep you guys in the loop!
Originally Posted by zcchen View Post
Keeping AC? or no?
Definitely going to keep A/C on this car! Some custom lines and/or reworking will most likely be necessary to do so but I will make sure this is executed.
This is "step 1" of my plans, so i'm more then aware there will be things needing adjustments, modifications, relocations. I will definitely take a look at your link for some possible motivation! I've spent some time going over the initial "manifold design" and feel very confident topmount is the way I want to go on this.
Yes, the HPF drag manifold was a custom tubular manifold I built. I will definitely keep ECU location in-mind; among the ABS unit which I found is positioned differently for other generations aside from mine. The expansion relocation has other possibilities, I used this area because it was so open!
Old 06-05-2012, 01:40 PM   #14
MaverickM3
My Ride: gets badge
Thank you Sir.
Old 06-05-2012, 10:00 PM   #15
SlideFox
Sweeet!!! I come from the VQ community. I'm a regular on My350Z.
Old 06-05-2012, 10:49 PM   #16
02black330ci
My Ride: spaceship
Perfect, just what I wanted to hear!
Old 06-05-2012, 11:26 PM   #17
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Subscribed!
Old 06-05-2012, 11:44 PM   #18
6spd_legend
My Ride: acura legend 6spd
Wow- this is awesome. I've been waiting for someone to step up to the plate and do a top mount build. I can see this + ProEFI being a great options for those wanting to go turbo w/ the e46 m3. Subscribed.
2001 LSB M3 Coupe
6spd_legend is offline   Reply With Quote
Old 06-06-2012, 12:00 AM   #19
MaverickM3
My Ride: gets badge
I think a top mount turbo would look bad @ss under there.
Old 06-06-2012, 02:27 PM   #20
DOC_Race
My Ride: 03 M3
Found a nice spot for the turbo yesterday. I'm starting to see why people do bottom mount but I'm used to working with no room so this will be interesting...
ID:	455178   Click image for larger version
