Old 05-28-2013, 05:08 PM   #1
Svince00
My Ride: 06 Acura rsx
2000 323ci no fuel pressure?
Hi, I have the opportunity to purchase a 323ci 2000 model for CHEAP! However the current owner states there is no fuel pressure to the rails, but says he has replaced fuel pump. Any ideas as to what it could be? Worth the money?
Svince00 is offline   Reply With Quote
Old 05-28-2013, 05:31 PM   #2
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Fuel filter, fuel pump fuse or even Captain's e-Box fuse.
If you can buy it on the cheap, go for it.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-28-2013, 06:59 PM   #3
Svince00
Ok talked to the guy a little more he said he thinks its electrical, bc it's throwing 02 sensor code and a CPS code even though he replaced the CPS.. I know electrical issues are expensive but he's only asking 2k..
Old 05-28-2013, 07:46 PM   #4
BMWCaptain
First thing you should do is check the Captain's e-Box fuses.
If a Captain's e-Box fuse is blown, it can give you the CPS, etc codes as well.
Tell him you will buy it and we will fix it.
BMWCaptainE46.com
Old 05-28-2013, 09:13 PM   #5
Svince00
Thanks for your help! Will let you know when I purchase & how the repairs go! Hoping to get up there to get it this weekend!
Old 06-04-2013, 09:19 AM   #6
shanneba
My Ride: 2003 330Ci
The 323 has a separate fuel pressure regulator...... could be that
Could also be the 3/2 Way valve.
01 3/2 directional control valve 1 13311438795 $221.68
03 PRESSURE REGULATOR 3,5BAR/PIERBURG 1 13531729319 $75.10
Join BMWCCA
Old 06-19-2013, 10:19 PM   #7
BMWCaptain
Did you purchase the car?
BMWCaptainE46.com
