Old 06-02-2002, 04:27 PM   #1
maynardc
My Ride: '03 M3 - 6-speed
Unable to Dyno Supercharged 2002 330 CI
I made an attempt to dyno car, using a DynoJet Dynamometer (http://www.dynojet.com/a248.shtml); however, it was a totally inaccurate read and was plagued with problems. Here's a list of problems I ran into:
1. Unable to turn DSC off.
2. DSC and ABS kicks in the moment the rear wheels begin to move and the front wheels don't. The system obviously believes that the car is losing control and it attempts to compensate which results in totally inaccurate measurements.
3. When DSC kicks in power is greatly reduced.
4. Unable to measure torque w/ the Dynojet, the mechanic mentioned that there's no proper "hookup" on the newer BMWs that will adapt to the DynoJet (whatever that means).
5. Unable to compare hp with RPMs for the same reasons in #4. On a side note, while I was actually looking at the computer monitor and my RPM guage, there was a very sharp decrease in HP at about 5200 RPMs which is BS. I'm sure this a result of the DSC limiting power to the rear wheels. My car pulls very strongly till about 6200 RPMs.
What Dynamometer will accurately measure my car and factor out all of the problems I ran into? Any ideas would be greatly appreciated.
FYI, the maximum hp I was able to attain according to the flawed dyno runs was 219 rear wheel hp! Incredibly difficult to believe knowing that I raced my friend's 2002 SMG M3 to 100 mph and beat him by about 2 car lengths. Needless to say, there's NO way my car only has 219 hp at the wheels!
maynardc is offline   Reply With Quote
Old 06-02-2002, 04:50 PM   #2
Banana_Bread
My Ride: 323Ci
A shop in my city, technik motorwerks, warned me about this exactly problem. A while ago they had a special going on and i was going to get my stock hp readings to determine if bmw underrates or overrattes their cars. The owner warned me that they wouldn't be able to get a proper torque reading due to the problems you listed. I decided against doing it, didn't want to risk my 50$ on a run that wouldn't work.
I hope you can find a dyno that can measure your car, i'm very interested in how much power your putting to the ground. There has to be a method of properly dynoing the car as i've seen dynocharts floating around the internet. Sorry this wasn't any help, just wanted to let you know that i've had the same problem.
Banana_Bread is offline   Reply With Quote
Old 06-02-2002, 05:49 PM   #3
Samir
My Ride: Supercharged E92 M3
This is strange...I've dyno'd my 330 plenty of times already, and have not had any issues with the DSC reducing power under load. The abs/dsc lights do come on, but they don't affect power delivery to the wheels...they turn off by themselves after a few miles of driving. However, I have heard of this problem with certain M5s, so perhaps certain 330s have this issue as well. The way around it is to fully disengage the DSC by removing the fuses associated with it...
As far as not being able to measure torque on newer BMWs w/ a dynojet, this is complete BS...the dyno I use is a DynoJet 248C. To get the torque readings, all they have to do is remove the rubber sleeve on one of the ignition coils and attach the connector.
Samir is offline   Reply With Quote
Old 06-02-2002, 05:53 PM   #4
JawKnee
JawKnee Motorsports
My Ride: Nissan 350Z Track
Send a message via AIM to JawKnee
  • '05 Honda S2000 '03 Nissan 350Z Track ('00 BMW Dinan 3)
  • '04 Subaru WRX Wagon ('01 BMW 330i)
  • '04 Honda CBR600RR
  • '05 Honda CBR600RR
  • JawKnee is offline   Reply With Quote
    Old 06-02-2002, 06:01 PM   #5
    maynardc
    ***RE: As far as not being able to measure torque on newer BMWs w/ a dynojet, this is complete BS...the dyno I use is a DynoJet 248C. To get the torque readings, all they have to do is remove the rubber sleeve on one of the ignition coils and attach the connector.***
    I guess that's what I get for going to a dyno shop that specializes in Honda's!
    So, where are the fuses located? And what specific kind of results have you gotten w/ your 330? I'd really like to see your charts. Could you please post them?
    Anyway, thanks for the information; I'll try a different shop next time.
    Old 06-02-2002, 06:18 PM   #6
    drewcon
    Bavarian Motor Slave
    My Ride: 330ci
    why can't you just turn DCS off?
    right?
    drewcon is offline   Reply With Quote
    Old 06-02-2002, 06:31 PM   #7
    Amil
    mY Name Is aMiLioooooooO
    Amil's Avatar
    My Ride: 04 Range Rover 07 A4
    Send a message via AIM to Amil Send a message via MSN to Amil Send a message via Yahoo to Amil
    im in the la area...where and how much can i get a dyno test?
    ooolala
    Amil is offline   Reply With Quote
    Old 06-02-2002, 06:35 PM   #8
    Samir
    The fuse tray is located in the glove box. There are two clips which hold it in place...
    twist them to unlock the tray and it will drop down...
    The fusetray has numbered slots...just find the right ones and remove them...depending on the options you have, some of the fuses might already be removed. BMW also provides a handy clip to help remove the fuses easily (the red piece in the middle).
    Here's a chart...stock vs. ITG drop in filter:
    Old 06-02-2002, 06:39 PM   #9
    Samir
    I use R&D Dyno in Carson...310.516.1003. $75 for 3 runs. I'll be there again sometime next week.
    Old 06-02-2002, 11:58 PM   #10
    maynardc
    Thanks so much for the really helpful info, Samir! I'll be sure to go to R&D w/ my next dyno. I'm currently waiting (like everyone else) for my UUC exhaust. So once I get it (hopefully in the next 2 weeks), I'll be sure to get it dynoed. It just sucks that I wasn't able to get a good result from my first dyno so that I could see what type of increase I'd get with exhaust.
    Old 06-03-2002, 12:08 AM   #11
    JetBlack330xi
    My Ride: 2002 330xi
    couple things:
    Maynardc: how much did it end costing total to supercharge your car? how long w/ out your car?
    also, what are all those fuses for?
    JetBlack330xi is offline   Reply With Quote
