///M3 Forum
Old 06-06-2012, 01:22 PM   #1
Hobohunter
My Ride: 2001 M3
M3 top speed limiter question
Hi, guys. I did a quick search and didn't find anything about this. I'm also not really expecting much in the way of an answer, but giving it a shot nonetheless.
I found out about six months ago that my 2002 M3 has had its top speed limiter removed. I bought the car used about two years ago and don't know much about the previous history of the car. I know it's been local to the PNW for it's entire lifetime and had a few previous owners, but not much more than that.
I was wondering if anyone has any suggestions on how to figure out what method a previous owner may have used to remove the speed limiter. If it's software related, like having a chip flashed, will that get a sticker placed on it to indicate who did the flashing?
Thanks in advance for any help you may give, it will certainly be appreciated.
Hobohunter is offline   Reply With Quote
Old 06-06-2012, 07:56 PM   #2
wildpig
My Ride: 2003 BMW M3 Convert
How y find out limiter was removed? sorry there is usuakky not a sticker,,, Limiter is software based. For example some people buy evolve tune which does remove the top speed limit....
2003 BMW M3 Convertible
wildpig is offline   Reply With Quote
Old 06-06-2012, 08:10 PM   #3
illestminimike
My Ride: Project Drama
The limiter isn't exactly "strong" and will let you go past 155. Trust me. I know. A tune or some coding can easily remove it.
Old 06-06-2012, 08:45 PM   #4
sakumaxp
My Ride: 02 M3 convertible
Just get a stage 1 tune, no speed limiter, more power and much more
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 06-06-2012, 09:34 PM   #5
sick.boy1986
My Ride: ///M3
That's actually your speedometer reading incorrectly, they can be as much as 10% incorrect. Trust me. I know.
E46 M3
FZJ80
sick.boy1986 is offline   Reply With Quote
Old 06-06-2012, 09:59 PM   #6
illestminimike
No it's not. My car is THAT fast. Lol probably. I like to think my car is that fast though.
Old 06-06-2012, 10:38 PM   #7
wildpig
When you figure in the M3 erroneous speedometer, which could show you going 5-6 mph faster than your actual speed (maybe slightly more at higher speed?), you are going at 155. I would not trust the speedo for a top speed run and only trust the GPS to verify your speed. Even playing with ncs expert to recode a few lines in the computer module, was only able to reduce error to 1-2 mph.
Old 06-06-2012, 11:49 PM   #8
illestminimike
I'm just saying thy maybe OP went past "155" and thinks his limiter is gone but it's just the speedo sucking.
Old 06-07-2012, 08:21 AM   #9
Hobohunter
My Ride: 2001 M3
Thanks for the input so far, guys. I know that the speedometer isn't going to be accurate at the high end of its range, but from searching on a few of the forums, it looks like the usual error is only a couple of MPH. Suffice it to say that I was more than just a couple of MPH past where limiter sets in. I've also heard that you can trick it by making it past 155 in 5th gear.
I don't think it's just the speedometer sucking, since the top speed limiter should be based on speedometer reading, since that should be the only way that the car knows its speed. But, if I'm wrong, then it's possible that the limiter is still there and I was at an error of 10% of speedo vs actual speed.
Has anyone who's read this gotten a tune or had their limiter removed in a similar fashion? I'm curious as to any documentation you get from the tuning company. I've worked at a couple of jobs now where software or hardware gets updated in a system and in my experience it's always followed up with a sticker or some form of identifying marking (I haven't done this sort of thing with car electronics, but it stands to reason that it could be a similar practice). Or, in the case of a tune, would I be able to contact tuning companies and find out if they've worked on the car by providing them the VIN?
Once again, thanks for any assistance!
Old 06-07-2012, 08:37 AM   #10
hassmaschine
My Ride: '91 325ix
the speedometer gets a different coding factor than the odometer, with the speedo purposely made to read higher. the question is, does MSS54 get the speedometer reading, or the one that the odometer gets?
hassmaschine is offline   Reply With Quote
Old 06-07-2012, 11:31 AM   #11
yagesz
My Ride: 05 M3 SG/IR
Just gonna say on autobahn Speedo claims 181. But My GPS puts it at 169.
2005 Space Grey M3 w/ Imola Red Interior 6MT
My Build:
http://forum.e46fanatics.com/showthread.php?t=934353
yagesz is offline   Reply With Quote
Old 06-07-2012, 11:32 AM   #12
wildpig
I guess you did hv yr limiter removed?
the only way to know limiter off for sure is either a gps verified top speed run or some way to read the ecu showing the tune has changed the ecu code. unless anyone knows of another way
Old 06-07-2012, 01:38 PM   #13
Julian Moore
My Ride: 2002 M3 Vert
I thought you could bybass the limiter by staying in 5th?
Julian Moore is offline   Reply With Quote
Old 06-07-2012, 01:42 PM   #14
illestminimike
OP, yes a lot of tuning companies can run your VIN too see if you have their software.
And yes there was a thread a few months ago about bypassing the limiter by staying in 5th.
Old 06-08-2012, 01:02 AM   #15
04cbM3
My Ride: M3
If you do the 5th gear by pass will it kick in when you shift to 6th
04cbM3 is offline   Reply With Quote
Old 06-08-2012, 01:21 AM   #16
illestminimike
Nope
Old 11-13-2012, 01:33 PM   #17
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Just to clarify.. this weekend I was still hitting the limiter in 5th. I didn't remove my limiter for an event where I knew I'd reach speeds above 155, based on multiple people telling me if you stayed in 5th you'd be fine. This was not the case for me, the limiter still kicked in in 5th.
Old 11-13-2012, 02:30 PM   #18
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
I had my 2006 to an indicated 165+ but my 9500ix (radar detector w/ GPS) showed 154 so I am going to chalk my "past the limiter experience" to the % loss of most speedometers.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 11-13-2012, 02:32 PM   #19
TerraPhantm
My Ride: M3 & ZHP
The proper speed seems to be sent through the CAN-bus. It looks like BMW deliberately miscalibrated the speedometer scale so that it reads high. The digital speedometer is pretty damn close though.
