///M3 Forum
Old 06-08-2012, 05:48 PM   #21
Ballerbrian4u
My Ride: 2004 BMW m3
Do you guys recommend a professional to install or my self?
Ballerbrian4u is offline   Reply With Quote
Old 06-08-2012, 10:37 PM   #22
Rockyminator
My Ride: :)
If you've never worked on your car then let a professional install it. It is a major pain in the ass to install... and they will charge you up the ass to install it! I can do a transmission fluid change, oil change, differential fluid change, ssk install all in less time than how long it took me to install the angel eyes!!!! . Pulling the headlight housing apart was a huge headache! The wiring isn't so bad though. Good luck
HPF Stage 2.5 BMW M3
Rockyminator is offline   Reply With Quote
Old 06-09-2012, 03:31 AM   #23
gqkris
My Ride: 02 BMW M3 99 Cr-V
You can do it yourself. You will be so much cooler. There are detailed instructions...some brands like mine were different colored wires (I had to figure what was what compared to the instructions) did it myself, had no idea what i was doing except years ago i had to take out the headlight to swap out an Hid, the only pain is the lower trim under the headlight (i used a nail to pull the last clip) everything else for the headlight is easy. Taped up all the wires and made it tidy like in the instructions, wired the tap wire to the interior lights for remote under the glove box and the other tap wire to the accessory wires.
gqkris is offline   Reply With Quote
Old 08-16-2012, 08:12 PM   #24
ViperZ
My Ride: 1992 325i & 2006 M3
How about the Night Time remote with the Orion V4's? Same answer?
it the remote a wireless remote, or some dial that needs to be mounted to the dash?
ViperZ is offline   Reply With Quote
Old 08-16-2012, 09:39 PM   #25
AW Pegasus
My Ride: 2000 328i
I have the V4s and the built in night controller is just an extra wire that comes out of the little box that the angel eyes connect to. You tap the extra wires to your low beams so when you turn them on they somehow know to dim. I installed them myself, pretty easy install actually
AW Pegasus is offline   Reply With Quote
Old 08-16-2012, 10:08 PM   #26
ViperZ
Sounds like a nice feature, so the combination of all the lights don't over power oncoming traffic... I'd hate to be annoying as well..
Old 08-18-2012, 05:36 PM   #27
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
They won't overpower any headlights.
Old 10-09-2012, 12:30 AM   #28
THECLEANERBEAMER
My Ride: 2002 325i
I just installed my v2's and man there are super BRIGHT. Lol I like them a lot especially during the day and the look amazing at night but im still worried I could be blinding people,it'shard for me to look at them for a period of time at night it's not blindly per say but more like hurts your eyes if you stare too long lol
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 10-09-2012, 12:13 PM   #29
umnitza
8774866489
umnitza's Avatar
You can also use a rheostat if you want to dim them together. You can install a variable rate one inside your dash. It's a bit of work, but it will allow you to decrease the output at your desired level.
