Sponsored by The Tire Rack
Old 06-07-2012, 12:30 PM   #1
bosljeff
My Ride: 2001 325i
Plain and Simple: 2001 325i, size tire/wheel to fill...
Every other thread I found was a different combo of questions that didn't match my simple, stock scenario.
I have a 2001 325i. I'm still thread researching to find out if I have any sort of upgrade package (sport etc).
Tires are due so I might as well upgrade.
Simple: What tire/wheel size can I max out on without anything else (no rolling, nothing else)?
Tire size:
Wheel (and offset) size:
Pix of your set up would be great.
I'll keep searching the threads, but thank you for your time.
J.
bosljeff is offline   Reply With Quote
Old 06-08-2012, 12:09 AM   #2
2003 325i
My Ride: '03 Orient Blue 325i
Can fit 20s, possibly 21s but anything over 19s looks like crap. 18s are what you want IMO.
Rim width choice affects offset choice and tire choice. Likewise offset choice affects rim width choice and tire choice. Likewise tire choice affects offset and rim choice... Suspension you have affects all these choices.
Your choice.
Your question is too vague for anyone to help you.
Old 06-08-2012, 02:00 PM   #3
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
I would agree with the 18" or 19" suggestion. It still gives you driveability with a good amount of tire as well as looks good. You are going to want to go for an 8.5 ET35 front and 9.5 ET45 rear. These are our recommended specs.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 06-08-2012, 02:09 PM   #4
bosljeff
My Ride: 2001 325i
Your choice.
I apologize. Once I find the stock dimensions of the stock 16 wheel I have, I'll let you know.
I don't care about the specific numbers as far as the request, just the answer. What numbers will give me a low profile tire, fill the wheel well, not rub, run close to flush with the fenders (I know it isn't possible, but close), keeps me from rolling the fenders and probably won't rub? I want same size front and back.
I would like to put 18s on? Is that possible as a simple bolt on? If so, what combo can pull it off?
Old 06-08-2012, 02:18 PM   #5
bosljeff
My Ride: 2001 325i
I don't want to assume, but to square it off, just use the 8.5 35 front and back....
Old 06-08-2012, 05:17 PM   #6
VMRWheels
VMRWheels's Avatar
Correct. Benefit to this would be that you can rotate between all four tires.
Old 03-27-2013, 10:38 PM   #7
Bimmerboye46
My Ride: 01 325i Sport
I have a 2001 325i Sport Package (rides 1" lower). I called in to discount tire to make sure the wheels I wanted to buy would fit (18X8.5 Squared +35 offest). They said I could go up to 18X9 in the front.
Point is I rolled my fenders but my R/H rear wheel still scrapes when the suspension is compressed!! The lip clears but I want to tear out the damn plastic in my wheel well!
Any ideas or suggestions!? thanks guys...
Bimmerboye46 is offline   Reply With Quote
Old 03-29-2013, 10:25 AM   #8
Miko_10
My Ride: 330i 5 Spd
I'm curious about this also, what max tire specs can you put on these without doing any fender work? 245s? 255s?
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 03-29-2013, 11:13 AM   #9
Grande D
My Ride: E36 M3
255/35 on an 8.5, ET35 may rub with totally stock suspension in the rear. I'd go with a 235/40 or 245/35.
It will change your life!
Old 03-29-2013, 11:40 AM   #10
2003 325i
255/35 ET35 on an 18x8.5" wheel will absolutely NOT rub in the rear, but it may in the front. I had them in the rear of my car and I've got the H&R touring cupkit (lower than sports package).
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 03-31-2013, 04:43 PM   #11
Grande D
My Ride: E36 M3
255/35 ET35 on an 18x8.5" wheel will absolutely NOT rub in the rear , but it may in the front. I had them in the rear of my car and I've got the H&R touring cupkit (lower than sports package).
Old 03-31-2013, 10:10 PM   #12
2003 325i
did i stutter?
Old 04-01-2013, 01:26 PM   #13
Grande D
My Ride: E36 M3
did i stutter?
Your experience is not normal, or your tires are narrow for 255s. What brand and model?
Old 04-16-2013, 07:19 PM   #14
Bimmerboye46
So, after rolling my fenders until they have clearance, grinding the plastic inside of the wheel well (where the fender mates with bumper), I sill dont have clearance on the metal clip that holds the bumper to the fender! It looks like I will need body work done to flare the fender/bumper a bit, similar to an M3.
My alignment is maxed out at -3 chamber. My tires are aligned per spec but I am still having problems mainly with my rear right corner wheel well. Any ideas/solutions?
