Old 06-27-2012, 11:17 PM   #21
Stinger9
My Ride: '04 330Ci
Very possibly.
Do you even have the F connector?
Got a pic?
Old 06-27-2012, 11:39 PM   #22
The Thomas J
My Ride: 2002 325Cic
Originally Posted by Stinger9 View Post
Probably a minimal amount. It leads to the fuel filter pressure regulator.
With such a small amount of vacuum, it can't have much influence.
But if it were my car, I'd want it hooked up just because it's not that hard to do, and the car was designed that way.
Ok, thanks. I'm going to replace the fuel filter soon. When I do it I will re do the hose. I do like everything in place as it came from the factory.
I should have added this in my first post. That's still unmetered air running in past thE MAf. So as far as air leak goes it was a bit of a big deal. I was getting a running lean code & a misfire code. I could hear the car sucking air from the bottom of the car. Once I had time to look around & found the hose hanging I removed it, pluged it up, cleared the code it's running ok now.
I hate vaccum hoses.
The Thomas J is offline   Reply With Quote
Old 06-28-2012, 01:26 AM   #23
Stinger9
My Ride: '04 330Ci
In good conscience then, and to be true to our principles, pull that nasty vacuum hose off of your brake booster drum!
Old 06-28-2012, 02:34 PM   #24
The Thomas J
What will that do? I don't wanna rock the boat to much. I need to get all the system monitors up & runiing so I can pass NYS inspection & renew my regi.
Old 06-28-2012, 02:51 PM   #25
Wolrab
My Ride: 330Ci MT, 545i SMG
You'll have to push like a mutha to get the brakes to work at all without vacuum boost. Not recommended. I think it was a joke. hahahahaha
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 06-28-2012, 03:40 PM   #26
Stinger9
My Ride: '04 330Ci
Def a joke.
Silly to say you hate all vacuum hoses.
Apologies to The Thomas J for making a joke and assuming you knew a little more about engines, etc. You'd lose most all of your brakes without the vacuum hose.
Old 06-28-2012, 10:18 PM   #27
The Thomas J
Def a joke.
Yea...that one went right over my head. I should have known better. I should have said I hatre traceing vacuum hoses for problems.
In any event, all monitors were ready after just 36 miles of mixed driving, extended periods of ideling & 1 cold start.
Old 11-17-2012, 04:50 PM   #28
ELCID86
My Ride: 2004 330i (ZHP) x2
Crap, I not only broke the f-connect, but also managed to yank the smaller tube out from wherever it is connected on the other end!. Advice on where it goes and how to get it reattached? --feeling really stupid.
ELCID86 is offline   Reply With Quote
Old 11-17-2012, 05:05 PM   #29
Stinger9
My Ride: '04 330Ci
Probably down to fuel filter.
you picked a good one
Never touch the F connector without having a spare in your tool box.
Old 11-17-2012, 05:09 PM   #30
ELCID86
I know that now! Guess I'll drop the bottom tray and see if I can find a hole to put it in. Click image for larger version
Shawn in VA (USA).
- Shawn's 2004 IR/Alc. w/6MT ZHP (1/351 built)- http://bit.ly/1nhx4gk
- 2004 OB/Sand w/6MT ZHP (1/25 built)- (sold)
- 2004 OB/NB w/AT ZHP- (sold)
Old 11-17-2012, 05:34 PM   #31
Stinger9
My Ride: '04 330Ci
Drop the fuel filter shield and take a took.
Old 11-17-2012, 07:14 PM   #32
ELCID86
Will try tomorrow. Sure seems like it came from the back of the block though.
Shawn in VA (USA).
Old 11-17-2012, 07:25 PM   #33
Stinger9
My Ride: '04 330Ci
I'm not the last word on this. Just looks long enough to reach the filter and that's what others have said.
Never pulled mine out!
Old 11-17-2012, 08:35 PM   #34
Landlorder
My Ride: 330CI Sport
been running my car without small tube connected for a while and i get occasional hesitation/misfire, hoping that reconnecting it sorts it out....
Landlorder is offline   Reply With Quote
Old 11-18-2012, 09:30 AM   #35
ELCID86
Well it does hook to the fuel filter-thanks! Fun little Sunday morning before church project. I replaced the piece of rotting hose too. Wonder if this will help clear my lean codes? Well after I replace the f-connector. Click image for larger version
Shawn in VA (USA).
Old 11-18-2012, 11:35 AM   #36
Stinger9
My Ride: '04 330Ci
Thanks for the confirmation. Now I know for sure.
How the heck did you reach all the way in to get access to your fuel filter?
I tried to get my car up high enough and never could make it.
Old 11-18-2012, 11:50 AM   #37
ELCID86
On jack stands. Had to drop the plastic shroud and the metal cover/shroud in order to get access to snake the tube through. Not my idea of a pleasant Sunday morning. Did make it to church and feel better now!
Thanks again for your response and suggestion.
