Brake kit+flush tomorrow. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-23-2012, 06:01 PM   #1
Gus330vrum
My Ride: 330ci
Hey all,
I will being my Rotors(F-ate,Rear Zimmermannn) brake pads (8-ATE) & two sensors.
Also doing a brake fluid flush my self.
Any heads up ?
Gus330vrum is offline   Reply With Quote
Old 08-23-2012, 07:56 PM   #2
Stinger9
My Ride: '04 330Ci
Remember you may run across stubborn rotor retainer bolts on each corner. Pre-soak them in PB Blaster.
And if you mess one of them up, remember you don't need them to drive. They only hold on the rotor when the wheel is not mounted.
When the wheel is on, the five wheel bolts hold the rotor tight too.
How are you getting your car up in the air?
Old 08-23-2012, 08:01 PM   #3
Zell
Zell's Avatar
My Ride: so turbo wow
Eh just don't spill the brake fluid on your car haha, other than that it's a fairly straight-forward job.
Oh, and you may possibly run into a seized caliper bracket bolt. My passenger's side was stuck on there good, you should've heard the "pop" when we finally got the sucker off. It was incredible!
Old 08-24-2012, 12:01 AM   #4
Gus330vrum
My Ride: 330ci
Ofcourse WD40, ill use jack stand & hydraulic jack.
If those bolt go bad on extracting it out, just a make trip to Global stealership in ATL.
