Thread Tools Search this Thread Rating: Thread Rating: 19 votes, 4.89 average. Display Modes
Old 06-11-2012, 03:11 AM   #1
falk1984
My Ride: E46 318i, E85 2.5i
Passenger Side Rear View Mirror Tilt not working
Hi guys,
I have a 2004 318i with memory seats and passenger side rear view mirror tilt function when in reverse (kerb view?). The mirror controls all work and I can manually select any position the mirror possibly allows. Lately, however, the tilt function goes haywire and when I reverse, the mirror tilts downwards to some angle, but not the the stored setting. Even worse, then I go forward (D - automatic transmission), the mirror goes down even more instead of the initially programmed position and stays there. To me it appears that the mirror does not store any mirror settings anymore or the calibration is off. I have already tried selecting a different seat memory, but to no avail...
Have you guys experienced the same symptoms? Is there an easy DIY fix, or even better, how can I deactivate the feature altogether?
Also, another thing to note is that the switch position on the mirror selector has no impact (drivers side / passenger side) - the mirror tilts downwards / upwards either way, no matter what the position, and worse - the tilt function cannot be deactivated by simply switching to passenger side The memory seat function works perfectly though...
Many thanks in advance!
falk1984 is offline   Reply With Quote
Old 06-11-2012, 08:30 AM   #2
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
I don't think it's properly activated. May need to plug into OBD port and re-configure it.
In reverse mine does that as well, tilts down to some terrible un-useable angle. I'm unable to change the angle to what I need and save it. Before I changed my mirrors however I don't remember having that problem.
In the meantime, I've positioned my mirrors to a reverse friendly position and saved it under Memory 2 on my driver seat. This way when I reverse, I just hit 2 and my mirrors go down so I can see the curbs.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 06-11-2012, 01:11 PM   #3
falk1984
I already tried saving to a new memory position, but it still doesn't want to remember the position i want it to be in...
Also, the angle the mirror selects changes each time I reverse :S at times its 30degrees off, at times 45 degrees etc...
The mirror used to work perfectly, including remembering the exact setting/position, but only recently it started to have a mind on its own.
Is there a way to deactivate the kerb view feature via software? I don't mind if the mirror doesn't swing downwards, as long as it doesn't always change the position when i reverse and then drive forward..
Or even better, do you have any suggestions on how to fix this? I do not want to buy a new mirror only because of that function - after all, the motors / heaters seem to work perfectly..
Thanks,
Old 06-11-2012, 01:32 PM   #4
ThatGuy_JZ
With software it can be activated/de-activated I've been told.
You should not have to replace a mirror, I do not think that will solve the problem.
Old 06-11-2012, 01:37 PM   #5
falk1984
uh oh - do you think it may be more serious like the whole seat-mirror memory module :?
Old 06-11-2012, 01:48 PM   #6
///MPR77
My Ride: 02 ///M3 Tri-Ped
Old 06-11-2012, 01:51 PM   #7
falk1984
>Is the mirror switch in driver side position?
Somehow doesn't matter in my case - the mirror activates the kerb view in reverse in either switch position.
Driver side position = mind of its own
Passenger side position = mind of its own
Is there any fuse that is specific to the mirror tilt? i could only find the one that deactivates the whole mirror and then I can not even manually set it anymore..
Thanks,
Old 06-11-2012, 02:37 PM   #8
ThatGuy_JZ
no I doubt it. You may want to check with someone with more experience dealing with this.
Auto-tilt is a programmable feature that can be turned on or off given you have the right equipment for it
Old 07-06-2012, 03:28 PM   #9
theLedger
My Ride: 2001 E46 330i
Send a message via AIM to theLedger
When I put my power mirror adjuster to the passenger side, the reverse tilt feature stops working (which may be the intended behavior - haven't read the owners manual on it).
My rear view mirror doesn't return to the memory setting after putting it in D so I often have to hit the memory switch for it to go back to the right spot.
theLedger is offline   Reply With Quote
kerb, memory, mirror, problem, tilt
