Sponsored by BimmerWorld
Old 06-13-2012, 04:41 PM   #41
My Ride: Lexus
Here are some quick pics
ID:	456123   Click image for larger version
Old 08-15-2012, 08:13 PM   #42
Ballistic325
My Ride: slow and steady
how did you go with your RTAB replacement. I have the Meyle RTABs and MIS Tool ready to go this weekend and I was looking for some feedback on your experience.
Cheers
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
Old 08-15-2012, 11:15 PM   #43
My Ride: Lexus
Preload went well. I put the carrier at the same angle it went out. it naturally lines up with a line thats cast into the trailing arm. you'll see it. compensate in the opposite direction slightly before you apply your final torque of 81 ft lbs otherwise it'll rotate out of position as you torque it down. use a long breaker bar on one side and a torque wrench on the other side. make sure you use lots of oil on the bottom half of the MIS steel threaded rod. oil after every use (a total of four times)
don't forget to unclip the brake line from the trailing arm via the 10mm nut. very very important step. jack up the car via the rear subframe and put a jackstand on either side. remove the lower 18mm shock bolt as well. torque shock bolt to 78 ft lbs and carrier to body @ 47 ft lbs each.
Old 08-16-2012, 11:08 PM   #44
Ballistic325
Thanks Mang-o.
I'll be on to this either this weekend or the next, depending on available time. I'm budgeting about 1.5 hours per side. Too little?
I can help with
* RTABs
Old 08-17-2012, 01:13 AM   #45
My Ride: Lexus
Originally Posted by Ballistic325 View Post
Thanks Mang-o.
More than enough. I can do it fairly quiclkly now. 30 minutes a side.
another tip, the trailing arm has a beveled edge. MAKE SURE you push the new bushing in on THAT side of the trailing arm. It acts as a guide to get it started. Of course make sure the bushing is clamped with a large hose clamp. Keep tightening the clamp til the bushing is fully compressed (no gap in the splits)
Old 08-20-2012, 10:51 PM   #46
Ballistic325
No time this past weekend unfortunately.... aiming for the coming weekend.
Will report back once done
I can help with
* RTABs
Old 08-25-2012, 08:55 PM   #47
Ballistic325
Ok so first snag. Copper grease is not readily available.
Is there anything else I can lube Meyle HD bushings with instead of copper grease? I've seen a fair few other lubes such as brown, black, silver and marine and according to the packaging they are suitable for wheels breaings, joints and chasis mounting or flex points. Most of them are PTFE or lithium based.
Any ideas?
I can help with
* RTABs
Old 08-25-2012, 10:10 PM   #48
Alex323Ci
My Ride: M3 & 323Ci (sold)
You lube the poly ones. Meyle HD are rubber like stock.
Old 08-27-2012, 01:44 AM   #49
Ballistic325
Excellent. So no lube required?
Might give this a shot tonight....
Sent from my V9 using Bimmer App
I can help with
* RTABs
Old 09-05-2012, 03:43 PM   #50
fanatic128
My Ride: 2005 330i
SO once it's clamped so there are no gaps , you just push it in a bit and then remove the clamp? should I put some dish soap, anti-sieze or something to help it in?
fanatic128 is offline   Reply With Quote
Old 09-06-2012, 11:53 AM   #51
fanatic128
My Ride: 2005 330i
anyone?
Old 09-06-2012, 12:09 PM   #52
My Ride: Lexus
NO. Nothing ever. NOTHING NOTHING NOTHING. STOCK BUSHINGS GO IN BONE DRY. nothing nothing nothing. where are people getting this grease on stock bushings idea
Old 09-06-2012, 12:32 PM   #53
HiHoBrian
My Ride: 05 M3
Did you press them until there was even overlap of aluminum bushing housing on both sides to center it?
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 09-06-2012, 12:54 PM   #54
My Ride: Lexus
Who me? I did. not sure if you're asking me or someone else
Old 09-06-2012, 12:55 PM   #55
My Ride: Lexus
BTW i dont think the clamp is totally necessary but it helps a ton. just do it. clamps are like $3
Old 09-06-2012, 01:06 PM   #56
HiHoBrian
My Ride: 05 M3
Yes,I was was asking you indirectly,and would listen to anyone if they replied. Thanks.
Old 09-06-2012, 02:59 PM   #57
My Ride: Lexus
Originally Posted by rbalazsi View Post
If you're using OEM style split bushings, no lube should be used.
That's OE style.
and yes. 44 people just said that.
Old 09-06-2012, 03:51 PM   #58
fanatic128
My Ride: 2005 330i
I guess It will makes sense when I start doing it, but wouldn't the screw that's used to tighten the hose clamp get in the way of pressing it in? unless I use one, press it in..unloosen it-> move it back a bit -> push in again and keep repeating.
Old 09-06-2012, 04:10 PM   #59
My Ride: Lexus
overthinking. press in until you reach the clamp. remove clamp. continue to press in.
Old 09-06-2012, 04:37 PM   #60
HiHoBrian
My Ride: 05 M3
Just finished making this. I'll get some longer grade 8 rod for tommorow to do the job properly. Click image for larger version
