Old 06-13-2012, 02:29 PM   #1
cookp
My Ride: 2001 330 CiC
Unable to shift into Drive
I have a 2001 330 ci convertible. Prior to today, I've had no issues with the automatic transmission (car has 133,000 miles). This afternoon, the car starts just fine and shifts into reverse, but will not shift into Drive. I'm at a loss here, as I haven't experienced this issue in the past. Any ideas?
cookp is offline   Reply With Quote
Old 06-13-2012, 02:39 PM   #2
cookp
Update
Ok, so I've gotten it to go into drive, though there seems to be some resistance depending upon my technique. If I shift from P to N and then apply force diagonally to shift into M, it will then allow me to shift into M or D. After some cycling back and forth, the transmission now allows a direction downward motion from P to D. Any ideas what may be causing this issue?
Old 06-21-2012, 05:24 PM   #3
cantwist
My Ride: e46
same problem too...
buddy i have the same problem, someone help us.. i lent the car to my mother and it wouldn't go into drive.. it's happened to me before but now i want to fix it.. ive heard rumours of a shifter cable or something... 01 325i 180,00km
cantwist is offline   Reply With Quote
Old 06-22-2012, 12:38 AM   #4
Nightmare5336
My Ride: e46 with a slushy
Lift up the shift boot. There is most likely a quarter or something stuck in there
Originally Posted by jdc336 View Post
DUMB YOUR MOM.
Nightmare5336 is offline   Reply With Quote
Old 07-02-2012, 09:08 AM   #5
cantwist
My Ride: e46
please help shift won't wift in to drive
come on boys and girls give us a hand my car just called it quits and wouldnt' shift in to gear i called a tow truck when the guy showed up the freakin thing shifted into gear. i called off the tow, the guy was pissed. i need to find out what is wrong with it...... please helppp
Old 07-02-2012, 09:40 AM   #6
norman_100390
My Ride: 2000 328ci
Send a message via AIM to norman_100390
Damn I had an issue of going from p to R. The shifter felt sticky and the tranny would make this big thump sound... But if I shift the gear box a certain way all is fine....
310 South Bay Bimmers ADD US!!! http://www.facebook.com/groups/375597152458494/
Matte Kidney Grills, Matte Badge, Matte Crome Trim, M3 Front Bumper Conversion, HID Fog Lights 35w 6000k, BMW OEM 197 BBS RX 18', Bridgestone Potenza RFT 255/35REAR 225/35Front, Smoked Corner/Side Markers/LED Eagle Eye Smoked Tail, CCFL Angel Eyes , K&N Drop In, 35% Window Tint, Zenon Dome Lighting, Nitrogen Filled, Hertz Audio
norman_100390 is offline   Reply With Quote
Old 07-02-2012, 09:45 AM   #7
jasonbimmer
My Ride: 2001 BMW 330xi
well sometimes when you park on a slop, the parking claw would get very tight and hard to get out P.
however, its also possible that the solenoid for D and R are acting up preventing the shifter to get in.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 07-02-2012, 01:39 PM   #8
norman_100390
My Ride: 2000 328ci
True about the slope but it also has happened while the car was flat.
I took it to the dealer when I first heard of the issue and after thoroughly checking the car and driving it around they came to the conclusion that the tranny could be going out. So they suggested I just wait it out.
Old 07-02-2012, 02:42 PM   #9
cantwist
My Ride: e46
I have a feeling it's has something to do with the shifter cable. Tr car is at a bimmer specialist that's works for bimmer I'll have a full conclusion for you guys tomorrow or Wednesday stay tuned
Old 07-02-2012, 02:58 PM   #10
jasonbimmer
the shifter has nothing to do with the transmission, its only a switch.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 07-03-2012, 09:35 PM   #11
SteveL1
My Ride: '02 330Ci
Have the same issue with an '02 330Ci but it's intermitent. Took to the dealer and they could find nothing worng. My wife has more trouble with it than I do but I have experienced it every once in a while. Oursa only has 46k miles on it and it's always parked on level surface when it happens. Would love to figure out what it is.
SteveL1 is offline   Reply With Quote
Old 07-08-2012, 12:18 PM   #12
cantwist
My Ride: e46
I fixed te problem
I figured out the problem it was the shifter cable. Over time the shifter cable becomes brittle and plastic bushing break and get dislodged in tr shifter assembly. Shifter cable and assembly cost 700 Canadian. I found one at bimmerparts.ca for 120. The car is running perfect. Thanks to my bmw mechanic who does work in his own shop. Any questions let me know
Old 11-18-2015, 08:44 PM   #13
relangmai
My Ride: 318 E46
Solved free!!
hi,
thanks for all the clues
had the exact same issue. initially i couldnt take out the key even on "P". then i did a little force got to take off the key. then could not move to "N" or "D" from "P". reading the clues from here, i opened up the cover and figured that there was a cable clip that fall off into the shifter. the clip is a metal clip and it blocked the shifter movement. i remove the metal clip and solved the issue. Alhamdulillah it was free thanks thanks all
relangmai is offline   Reply With Quote
automatic, drive, shifting, transmission
