Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars
Complete Cars
Old 06-14-2012, 06:29 PM   #1
scrace
My Ride: 03.5 M3
FS: 2001 BMW 325Ci Topaz Blue 5MT 120k miles (MD)
**The angel eyes will not be included in the sale, sorry**
Finally is time to hand the keys over to someone else, I've enjoyed this car a lot and am sad to be letting it go, but it's time for an M3.
I bought the car on 5/27/2006 with 60k miles on it.
2001 BMW 325ci 2D Coupe 120k miles (I believe it's fully loaded, could be wrong I do not know if premium package was listed or not)
Topax Blue Meallic
Black Leatherette
Cold Weather Package ( heated front seats, headlamp cleaning system, ski bag)
Sport Package (17 x 8.0 alloy wheels, 225/45R-17 performance tires, 10 way adjustable sport seats)
Power Class Moonroof
Xenon Headlamps
AM/FM CD Player
2 Keys with keyless entry and 1 valet key
I have 75% of the service and maintenance paper work, I've thrown some of it out by mistake and lost others)
Full sized spare (never used)
MPGs it's listed as 20/29, I typically get 26-28 mixed and 32-34 highway
**The above is taken from the oriental price stick (still have it, I also have about 75% of the maintenance and services paperwork, i threw some out while doing DIY and lost some others).
I am in no hurry to sell. No tire kickers, cash in hand to test drive, be more than happy to give you a ride if seriously interested and do not have cash.
All the pictures can be found here: https://picasaweb.google.com/1099231...149/June142012
I'll be adding more once I have time to detail the outside of the car and finish the inside, hopefully by the weekend everything will be up.
The interior is probably one of the best for it's age besides A, B, C pillars need to be re-wrapped and door trim appearance issues.
The exterior is has normal rock chips and door dings, along with it being keyed a couple months after getting the car (still no idea why it was done, or who did it, just didn't bother me much and didn't get it fixed).
Mechanically it runs great, engine is strong, it will need new rotors coming up, also will be having the oil changed by the end of the month (June). Also, ambit temperature sensor needs to be replaced, the horn does not work, the outside rubber trim attached to the chrome trim is starting to crack (it is water tight, which is why I haven't bothered to address the issue) and the airbag light has been on since I bought the car, I ran the codes awhile back and it didn't concern me. I just want to be as up front as possible with all known issues.
Maintenance:
Bosch Alternator (119k miles)
New Battery (119k miles)
Struct Reinforcement Plates
Bilstein Struts and Springs, rear heavy duty shock mounts (12/22/09)
rTABs (same time as new rears)
VANOS (110k miles)
OEM BMW E46 M54 Valve Cover Gasket Kit. Kit includes valve cover gasket set and 15 rubber seals. (110k miles)
Belts (/1/25/10)
Upper and lower intake boots replaced (5/26/10)
Secondary Air pump control value, air pump hose, air pump relay (9/27/10)
Engine Oil Level Sensor (1/25/10)
Secondary Air Pump (12/27/10)
OEM BMW E46 Crank Case Vent Valve Kit. Kit includes pressure regulating valve, vent pipe, connecting line, vent hose, vacuum hose, return pipe, and dipstick o-ring. (7/11/11)
OEM BMW E46 3 Series Cooling System Repair Kit Kit includes genuine BMW:
- Thermostat w/ housing/gasket (11537509227)
- Waterpump (11517527910)
- Upper radiator hose (17127510952)
- Lower radiator hose (11531436408)
- Expansion Tank (17117573781)
- Radiator Cap (17111742231)
- Engine drain plug crush ring (07119963200)
- Lower hose temp sensor (13621433077)
- 1 gallon BMW antifreeze (82141467704)
Spark plugs (90k miles)
Cabin Filter replaced every 2 years
Air filter replaced every 2 years
Regular 7.5k Oil changes (new one will be done by the end of June, or prior to cars sale)
Brakes (can't remember when but pretty sure they were done < 2 years ago.)
Tires Fronts have 5k at most on them and rears have less than 10k miles
Full alignment done less than 5k miles ago
Fuel Filter (100k miles)
The subframe was inspected by Russell BMW in Baltimore and no action was required.
Price: $8,000 obo
PM or e-mail me with any questions scrace89@yahoo.com
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 06-17-2012, 06:08 PM   #2
Tex323GripIsKey
My Ride: 2000 323i Green
Your interior is nice man. GLWS
Originally Posted by Sweetness View Post
I used to drive fast and cowboy around, but then I realized that I can't even afford bumping into someone, so now it's slow and classy, with occasional spurts of speed. Fanatics might pick on each other from time to time, but we are all one great big family that looks out for each other in the end.
I pull up to meets, lean to one side, shakin my finger at all da playahaterz. Then I get back into my car and flash mah beamz.
323i brakes & rotors
Tex323GripIsKey is offline   Reply With Quote
Old 06-18-2012, 07:06 AM   #3
DarthVaderSeats
My Ride: Alero 5spd Ecotec
My favorite color.
Are those factory Xenons?
DarthVaderSeats is offline   Reply With Quote
Old 06-18-2012, 09:30 AM   #4
scrace
My Ride: 03.5 M3
Originally Posted by DarthVaderSeats View Post
My favorite color.
Yes. Currently have Philips ds1 5000k bulbs.
Old 06-18-2012, 09:49 AM   #5
DarthVaderSeats
I am interested.
Does your car have the following: Automatic operation rear view mirror; Includes: [403] Power Glass Sunroof And [438] Wood Trim And [459] Power Front seats w/Driver Memory.
If it has those things then yes it does have premium.
In that pic I can't tell if you have wood grain trim, but you definitely don't have a wood grain shift knob.
The link to your Picasa photo album is not working.
I would like to see more pics please.
Any rust on this car? I am unfamiliar with Maryland and if they use a ton of salt on the roads in the winter.
Old 06-18-2012, 10:37 AM   #6
scrace
My Ride: 03.5 M3
I am interested.
It does not have the premium package, seats are manual.
No rust. But it has been keyed, no rust because it's been waxed regularly to prevent it.
Link should work now, google set it to private.
Old 06-19-2012, 07:46 PM   #7
scrace
My Ride: 03.5 M3
Washed the car today, here are some pictures, the rest (and these) are at the link in the info.
Old 06-19-2012, 09:00 PM   #8
jjamal99
My Ride: 2006 BMW ZHP
Where in Maryland are you located ?
jjamal99 is offline   Reply With Quote
Old 06-20-2012, 08:38 AM   #9
scrace
My Ride: 03.5 M3
Around Frederick.
Old 06-20-2012, 12:36 PM   #10
DarthVaderSeats
Is the price too much?
Old 06-20-2012, 01:29 PM   #11
scrace
My Ride: 03.5 M3
Depends on your opinion. PM me an offer if you're interested. I KBB'd the car at 8,700 for excellent and low 7000s for fair. I would consider this car in good condition by their standards. There are definitely flaws but nothing that isn't expected from an 11 year old car. You will be pressed to find a similar car in the same condition with documented parts and maintenance.
Old 06-20-2012, 03:03 PM   #12
scrace
My Ride: 03.5 M3
Also, ran an AutoCheck here is the results, my iPad wouldn't find the wireless printer, so I took screen shots.
Old 06-23-2012, 03:19 PM   #13
scrace
My Ride: 03.5 M3
UPDATE
I will be included as many of the original parts to the car that I have, which includes the tail lights, corners, OEM grill, etc.
Old 06-24-2012, 08:28 PM   #14
Jepenboii
My Ride: Bmw 325ci
i wish you were closer.. I would pick it up love that color
Jepenboii is offline   Reply With Quote
Old 06-24-2012, 08:28 PM   #15
Jepenboii
My Ride: Bmw 325ci
glws
Old 06-26-2012, 08:10 PM   #16
scrace
My Ride: 03.5 M3
Bump
Old 06-26-2012, 08:47 PM   #17
[USMC]Skywalker
My Ride: 2006 BMW 330Ci
I absolutely love the interior trim wanna sell them
Monaco Blue/Natural Brown, BMW Performance Intake, BMW Performance Exhaust, Dinan Stage II Software and Dinan Automatic Transmission Software
[USMC]Skywalker is offline   Reply With Quote
Old 06-27-2012, 12:16 AM   #18
10biie89
My Ride: 05 325ci
My first bmw in back in 02..
Exactly the same condition as your car.
I wouldve bought yours if I was local.
Absolutely gorgerous.
GLWS
I hope you get a full $8000 cuz it's well worth it.
10biie89 is offline   Reply With Quote
Old 06-27-2012, 02:56 AM   #19
sam0182
My Ride: E90
Great looking car, interior is nice.
sam0182 is offline   Reply With Quote
Old 06-27-2012, 01:58 PM   #20
scrace
My Ride: 03.5 M3
GLWS
Tell me about it, I am already regretting selling it, even after buying an M3. It's going to be missed. I'd keep it if my parents would let me have two cars living at home.
