Old 06-15-2012, 08:57 AM   #1
jared_wiesner
My Ride: 1999 328i (M54b30)
Fouling Plugs Fast
I keep noticing gradual diminishing power after replacing spark plugs with the single pronge BKR6E plugs. They seem great for 500 or so KM and then I start to loose low end power gradually. When I pull them to look at them they are somewhat carbon fouled, especially around the base of the plug. Install New plugs and the car instantly peps up again.
I have headers, Long Tube CAI w/ velocity stack and the M54b30 intake manifold. No tune as of yet.
Do you guys think I've maxed the flow out to the point where the engine is having trouble getting the mixture right and needs a tune to correct or is it likely something else?
jared_wiesner is offline   Reply With Quote
Old 06-15-2012, 09:11 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
Pics of "fouled" plugs?
Old 06-15-2012, 09:59 AM   #3
jared_wiesner
I can take some later but right now I don't have any pics. For visual reference though, heres a pic of a plug that looks like mine do when they come out. Not the most fouled I've seen a plug, but enough to make a difference. (And enough to know its not quite running right)
