Old 06-17-2012, 02:25 PM   #1
thomn8r
My Ride: 2002 6MT M3
A/C Ouput issue
This is a 2002 M3 6MT with 93k.
I've been having an issue with my A/C: with the system on and the output selector set for the middle (in your face) position only, I get cold air out of the side vents and hot air out of the middle vents. If I switch to the top (windshield) vent, I only get hot air towards the windshield. If turn on both the bottom (foot) and middle (face) outputs, I get cold air out of the middle, and hot air from the foot outlet; by "hot" I mean hot.
Yes, the center dash dial selector is set to the proper position.
The refrigerant level is fine, and the fan and compressor seem to be kicking in when they're supposed to.
Engine temps are normal.
When I get cold air, it's cold, but I shouldn't be getting hot air from other vents at the same time.
I suspected it might be the final stage resistor, but from what I've read (and previous experience) a bad FSR affects fan speed or shuts the fan down altogether.
It is 100+ right now, and we had to take the wife's Saabaru downtown to dinner last night because of a lack of A/C :shame:
thomn8r is offline   Reply With Quote
Old 06-17-2012, 02:47 PM   #2
mq124
My Ride: slow and sorta low
I had a very similar problem in mine. Mine would blow hot air out the top and bottom and slightly cool air out the middle even with all selected to max cold setting. Mine had a fresh recharge and everything seemed to be functioning properly. I even took it to the dealer and they told me it was a bad heater control valve which restricts or allows flow to the heater core however this did not solve my problem. The heater/AC module in my car turned out to be bad so I bought a used one out of a parts car on ebay. If you have access to someone with an e46 ask if he/she would mind you swapping the modules (the unit in the dash) and see if that fixes your problems. I have a hunch it will but that way you dont have to commit to spending any money. Also, the heater control valve, also known as the heater water valve, could be bad. This valve allows or restrict coolant to the heater core and the theory is that if the valve is stuck open the heat created will overpower any AC you have working at the time. I know there is a way to test these valves but I do not remember off hand. Hopefully this helps a bit as I was beating my head against the wall trying to figure mine out. If you have any questions feel free to PM me
mq124 is offline   Reply With Quote
Old 06-17-2012, 04:03 PM   #3
thomn8r
Thanks for the tip!
I did a search on heater control valve and came up with this post which seems to describe the problem to a "T"
I'll try replacing the valve and see what happens.
Old 06-17-2012, 08:40 PM   #4
thomn8r
Is this the correct valve? http://bmwfans.info/parts/catalog/E4...s_water_valve/
64 11 8 369 807
Item # 2
Old 06-18-2012, 01:04 AM   #5
rlddlr53
My Ride: 92 325ic bye m3
Yes, that valve is what causes the hot air in the middle. Had this problem on my m3 a few months ago
rlddlr53 is offline   Reply With Quote
Old 06-18-2012, 07:26 AM   #6
jasonbimmer
My Ride: 2001 BMW 330xi
anytime you have hot air mixing with AC its this valve's issue.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 06-29-2012, 08:27 AM   #7
e46mook
My Ride: 2004 330cic
let me know if this valve replacement fixed your issue because I have a similar problem. All of my searching has ended with replacement of this valve or some control module behind the dash
Remus - Dinan - H&R - AC Schnitzer
e46mook is offline   Reply With Quote
Old 06-29-2012, 08:39 AM   #8
jasonbimmer
it surely fixed mine. if your AC is on and set temp is lower than inside the car, the heater SHOULD not be on at all.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 06-29-2012, 08:42 AM   #9
thomn8r
I just got the valve a couple of days ago, and I plan to do the replacement tomorrow morning.
Old 06-29-2012, 08:48 AM   #10
jasonbimmer
have some coolant ready cuz you might lose some.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 06-30-2012, 12:31 PM   #11
thomn8r
Done - replaced the valve this morning. It took about an hour and a half because I lolligagged it. This indeed fixed the problem.
ID:	458719   Click image for larger version
Old 06-30-2012, 02:23 PM   #12
jasonbimmer
very interesting M3's got a different one.
2009 Mazda RX-8 R3
2008 YAMAHA YZF-R6
Old 06-30-2012, 02:33 PM   #13
thomn8r
The M3 has a different (and more expensive) everything. The valve was $215 from Tischer
Old 07-14-2012, 11:17 PM   #14
BWOODM3
My Ride: 2002 M3 convertible
did you have to get it coded? would you happen to have anymore pictures of the location of it as well? :d
BWOODM3 is offline   Reply With Quote
Old 07-15-2012, 12:01 AM   #15
thomn8r
I didn't have to get it coded. This thing is easy to find - it's right under and behind the airbox. I have a couple pix, but they're on another PC.
Old 07-15-2012, 09:07 AM   #16
mmaldin
My Ride: '04 325xit '94 325i
I replaced mine with good results this week too. I clamped the hoses and lost very little coolant. Very easy and accessible DIY.
mmaldin is offline   Reply With Quote
