Proper Diagnostic proceedure for E46 Electric Fan - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-18-2012, 11:58 AM   #1
jared_wiesner
My Ride: 1999 328i (M54b30)
Before you all scream search, I've searched high and low for a way to diagnose a failed electric fan. Not a single thread I've found has a resolution. Given that these fans aren't cheap and I've come across more then a few threads where the OP bought a new fan just to find that it still didn't work, I want to make sure I get the diagnosis right the first time.
Recently I started noticing engine temps creeping up at idle as well as loss of A/C performance at idle. Checked everything out and found that my electric engine fan is not turning on, not with a/c on, not with the engine moving towards over-heating, it won't turn on.
The car is a manual and only has one puller fan behind the rad between it and the engine.
I know the fans receive a constant supply of 12V and get a PWM signal to the third wire to tell the fan control what to do. I am getting 12V of power to the fan, I also haven't come across a broken fuse, though i could have missed one, at this point, that's all I know. Do any of you have any quick and easy ways to sort out if the fan is lacking input or if its just broken?
jared_wiesner is offline   Reply With Quote
Old 06-20-2012, 10:39 PM   #2
abefroman
My Ride: 2000 323i
I'm having the same issue
abefroman is offline   Reply With Quote
Old 06-21-2012, 08:09 AM   #3
jared_wiesner
Well it doesn't seem like anyone knows or is willing to help if they do.
Given that, this is what I settled on. The fan should come on if a/c is turned on, or if the engine is getting hot. They are triggers from two different sources and should rule out any faulty sensors being the problem. If it's not turning on under either of these circumstances, but you are getting 12 volts to the fan, then its the fan assembly (likely the fault is in the control unit).
I've ordered a fan from pelican that should be here next week. My fingers are crossed.
Old 06-23-2012, 07:50 AM   #4
MrGL2
My Ride: 2000 323Ci
How much did you pay for the fan ? I'm having the same issue
MrGL2 is offline   Reply With Quote
Old 06-23-2012, 08:39 AM   #5
jared_wiesner
I think 260ish plus shipping from pelican
Old 06-27-2012, 01:31 PM   #6
jared_wiesner
Replaced fan, problem solved...
Old 06-27-2012, 01:37 PM   #7
K'KamE46
My Ride: 323
I have the same fken problem and Ive ordered new fan from supernation. I will put it on tonight and see what thw outcome is..
Only cost me 144.
Sent from my HTC Glacier using Bimmer App
IN PROGRESS....
B&G SPRING I ANGEL EYES I M3 REP F. BUMPER I E90 RIMS I
AEM COLD AIR INTAKE I
K'KamE46 is offline   Reply With Quote
Old 06-28-2012, 06:57 PM   #8
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
Just ran into this problem. I have INPA/EDIABAS at my fingertips, so if anybody knows what to look for, please let me know.
I've tried searching under most of the engine sensors and haven't found it anywhere. Any other ideas? thanks!
-Chris
chris98891 is offline   Reply With Quote
Old 06-28-2012, 07:48 PM   #9
chris98891
My Ride: '16 X6 50i
as a bit of an update, i pulled this engine code after the car overheated:
-Chris
Old 06-28-2012, 10:35 PM   #10
jared_wiesner
Is anyone able to verify that the diagnostic method I used is sound? If you have verified that fan does not run when engine is hot, then simply turn on A/C. If you don't get fan within a few moments, it needs a new one.
Old 06-29-2012, 02:27 PM   #11
chris98891
My Ride: '16 X6 50i
well interestingly enough, banging on the relay with a screwdriver started the fan. after reseating the connection it would usually start right up. going to try some contact cleaner
-Chris
Old 07-04-2012, 03:55 AM   #12
pr0craztinazn
My Ride: '87 325
You can pull the connector from the coolant temp sensor in the lower radiator hose and the fan supposedly starts on MS42 management. This process worked on my '99 328i when the fan controller crapped out. I ended up replacing my fan with a $158 shipped unit from eBay that has done the job for the past year.
pr0craztinazn is offline   Reply With Quote
Old 07-08-2012, 12:01 AM   #13
be-doubleyou
My Ride: 02 325ci
I had this problem as well. Bought a new behr fan for an electric fan conversion and it never worked. I assumed my fan was functional, but found out the hard way when noticing my car was starting to overheat. Replaced it with the bosch and it worked right away.
I used relatively the same diagnostic method you did - bosch turned on when necessary but the behr didn't. After removing the behr fan and comparing it to a new bosch, I noticed that the behr fan had much more resistance when spinning the fan by hand - it barely spun and required a lot of force to do so(frozen motor). When installing the behr for the first time i noticed the resistance and thought it was odd. It was probably just a faulty fan from the beginning in my case. It may sound overly simple, but take out your fan and test its resistance when spinning the blades by hand. It should spin with little to no resistance, but if there is a lot of resistance it is faulty.
Bill
be-doubleyou is offline   Reply With Quote
Old 08-30-2012, 12:23 PM   #14
Mesa3077Boogie
My Ride: 325i Sport Package 0
what is MS42 management? Im trying to figure out if my coolant temp sensor or thermostat is broke. My fan only kicks on when AC comes on but does not come on when the car is hot.
what exactly does disconnecting the coolant temp sensor do as a test? What are you trying to prove or make happen?
"Brakes Stop The Wheels, Tires Stop The Car"
Mesa3077Boogie is offline   Reply With Quote
Old 08-30-2012, 12:51 PM   #15
jared_wiesner
MS42 is the computer in a 99-00 (or maybe 01?) E46
Likely doesn't matter as the theory should apply to MS43 as well.
Basically if the computer isn't getting feed from the temp sensor it will just turn the fan on automatically. (It proves the fan is functional if this works and that the problem is before the fan... likely the temp sensor.)
Old 08-30-2012, 01:38 PM   #16
Mesa3077Boogie
ok i see you responded to my last posts as well and thank you for that!
So this approach is only for the 99-00 models correct? Im a June 2003 model.
thanks for this info. So would it be smart to run the car with the temp sensor unplugged so that the fan just stays on and I dont have to worry about overheating in the mean time until I can narrow down some other avenues?
Thanks!
mesa3077boogie
Old 08-30-2012, 02:28 PM   #17
jared_wiesner
No problem.
Should work on all E46's regardless of year. You could do that but the car will not run as well as if It knows the temp. Better bet would be to run with A/C on, if the a/c will get the fan to kick on, (it should). Chances are your fan is done and you need a new one anyway. This is just a way to test that.
Old 08-30-2012, 03:00 PM   #18
Mesa3077Boogie
No problem.
Ok I get ya. This is a BRAND NEW FAN, just installed yesterday. The old fan was doing the same exact thing. I though it was running intermittently and thought the "speed controller/relay" was bad.
When I was testing my fan I bypassed the speed controller/relay (if thats what you call it) that is attached to the fan, and tested the fan motor direct with 12V and it did work. That lead me to believe that the speed controller that is attached to the fan was bad.
However, the new fan is performing the same way which leads me to believer that the problem lies elsewhere.
I have all this posted in another thread but I figured I would lurk here too to see if you guys had any suggestions..
thanks
Old 08-30-2012, 03:06 PM   #19
xixixi
Banned User
My Ride: 01 330x-xi
Hate to OT this. I see your in STL, I'm hosting a mini meet/bbq at my house in Ofallon mo. (burb) you are welcome to bring your car out, meet the crew. I will be grilling FREE FOOD! (first come,first serve) My fan is kinda messed up too. I'm going to try to retro fit some fan into the oem housing, will wire a switch to the dash. If interested in coming out drop me a txt at 989 666 six4six9 jay
Old 08-30-2012, 03:08 PM   #20
jared_wiesner
thanks
Gotcha, ya could be the temp sensor then or something else.
