///M3 Forum
Old 02-14-2013, 05:51 PM   #41
RAZ M3
My Ride: 05 M3
I forgot to mention I already replaced the relay and still nothing. I also put a new battery in.
RAZ M3 is offline   Reply With Quote
Old 02-15-2013, 04:19 PM   #42
roadtrip1098
My Ride: 06 STi
Did the indy shop read the codes? What were they? How long does the pump prime before it shuts off? Have you checked the hydraulic fluid reservoir? I only ask because in the video it looks like the floor is wet and a leak would cause issues. Almost sounds like it's not able to shift from gear to N. So without seeing the codes my best guesses are problems with the actuator that shifts gears, the actuator that engages/disengages the clutch, the shift springs, or inadequate pressure to complete the shift. It is very rare to have more than one item fail at the same time. I suppose it could be a GPS as well if it has completely failed.
roadtrip1098 is offline   Reply With Quote
Old 02-15-2013, 04:31 PM   #43
RAZ M3
My Ride: 05 M3
Thanks for your reply
http://www.m3forum.net/m3forum/showt...=433347&page=4
If you go to this link I took some picture of the fault codes
But my battery was nearly dead.
When I unlock there's no priming noise. I haven't checked the fluid reservoir. But the wet floor is from snow we had here in mn.
Old 02-15-2013, 04:59 PM   #44
roadtrip1098
My Ride: 06 STi
First picture says GPS module communication fault. Later on there's one that says hydraulic pressure sensor. The hydraulic one may have been from the battery being so low. The GPS being bad would most definitely cause the issues since it is basically the only thing telling the actuators where they've shifted to. Now that the battery is replaced I would see if someone with the DIS/GT1 software can check your codes again for you. There are quite a few members that have the cable and software to do it, and since we're all nice people, someone should be able to help you out without having to send your car in again. If you want to check and clean the connection for the GPS and see if that fixes it, follow the wiring down the passenger side of the transmission, the one that snakes to above the driveshaft is the GPS sensor wire. Most likely the sensor has **** the bed, but there's a chance the plug is loose or the wires got clipped by something....
Old 02-15-2013, 05:02 PM   #45
roadtrip1098
My Ride: 06 STi
BTW that list of faults is pretty intense. You may want to get the DIS/GT1 software for yourself so you can do all the adaptations and stuff and clear a bunch of those. You can find ripped versions on eBay for about $40. It takes a while to ship, and it is a PITA to install (virtual machines, addressing ports, ect.) but once you have it going it will save you a ton of money.
Old 02-15-2013, 07:41 PM   #46
Chewy
My Ride: '03 LSB M3 Vert SMG
Hi, my car is shuddering on take off/very low revs (taking off from a rolling stop in second.)
Also seems weird sometimes when coming to a stop, basically when the clutch disengages.
I've done the soft reset and the adaptations using DIS and changed the relay.
It does seem to be an engagement problem.
When running, gear changes are fast and crisp.
However, I have installed a hpf stage 2 clutch in it and the car is na.
Would this be because of the heavy duty clutch or a smg problem?
Cheers,
Andrew
Chewy is offline   Reply With Quote
Old 02-15-2013, 07:53 PM   #47
khawejaa
My Ride: E46 M3 convertible
Send a message via MSN to khawejaa
hi there i need your help i have m3 e 46 2006 convertible, and i have an issue in the gearbox , when im driving and the gear is changing gear by itself or im changing them manually there is a strange sound between every gear untill 4th 5th, its sounds like (dubb) its like a gap, however the gear are not engaged properly and when the gear is downgrading shifts it freezes on the downgraded gear for couple of seconds and then goes normal again but sometimes when goes freeze for a bit long, the yellow light comes on and that gear is canceled anymore, i cant use it, untill i switch off the car and turn it on again, and everything comes back to normal, lately i changed the compression springs but still the same issue,
NB: A deep sound between each gear and a gap , no smooth changes.
down shifts freeze for couple of seconds on a specific down shifting specially 4th and 3rd gears.
what should i do?
khawejaa is offline   Reply With Quote
Old 02-15-2013, 07:59 PM   #48
RAZ M3
My Ride: 05 M3
Arnt the symptoms of gps like i cant go into r 2 3 4 5 6. Would it cause my pump not to prime and not go into gear? Ill try and have the codes read some how. thanks again for the help
Old 02-15-2013, 08:01 PM   #49
RAZ M3
My Ride: 05 M3
Will autozone code reader work with car? I can rent it from them.
Old 02-16-2013, 03:34 PM   #50
roadtrip1098
My Ride: 06 STi
No, autozones code reader is a standard OBDII scanner, it will only say "Transmission Problem" or something like that. I'm only going by what the sheet said. It said that there's an issue with the GPS, you said it had a nearly dead battery, which would cause the hydraulic pressure sensor error. Again, in the video, it sounded like it was priming to me. Maybe it's my crappy laptop speakers.
Old 02-16-2013, 03:47 PM   #51
RAZ M3
My Ride: 05 M3
It only primed a bit when we tried to start the car. But when I unlock the car it doesn't prime at all. I'm gonna try and see if its the GPS sensor.
Old 02-16-2013, 03:56 PM   #52
RAZ M3
My Ride: 05 M3
Is there a easy way to check the sensor?
Old 02-18-2013, 07:16 AM   #53
roadtrip1098
My Ride: 06 STi
Not really, I would suggest cleaning the connector and see if that changes anything. Check the wires, ect. Unfortunately though, it's a sealed unit and kind of a pain to get to. If you want to go through the trouble of taking it out, here's what to look for:
Cracks in the housing
Splits in the wiring
The metal plunger should have a pin towards the end
The metal plunger should move in and out with a little resistance, but feel smooth. If it's sandy feeling, probably a bad sensor.
Even after checking all that it could still be a bad sensor, since it appears to be a signal issue judging by the error code.
Old 02-19-2013, 11:39 AM   #54
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Any one else have this happen? I went to start my car and nothing. Did the reset sequence with the key resetting the smg computer then it started. The next day same thing. I had the cog light come one a few days earlier and it went out on its own. The car drives great no issues. Any ideas?
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 02-19-2013, 11:46 AM   #55
being3
Modded ///Member
being3's Avatar
Cheers,
Andrew
I have an HPF m3 with stage 2 cluch and it shudders if u take off slowly. It's normal for this to happen with this cluch. It's meant for a lot of HP / TQ so there is a compromise. I make sure that the car goes into first when I do a rolling stop.. The smg will stay In second and will shudder a lot if u dont put it in 1st. So I make a complete stop and put it in first which gives far less shudder.
Old 02-21-2013, 02:31 PM   #56
benjamcm3
My Ride: 2002 BMW M3
reversed indication
My 2002 M3 shows "S" when its actually in Automated, and "A" when actually in sequential. Anyone ever heard of this happening? How to fix it?
benjamcm3 is offline   Reply With Quote
Old 02-21-2013, 02:39 PM   #57
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
The display is slightly confusing - I'm assuming you are the other one who has created a thread about this... ya? I just replied to your thread with your solution. Just a simple case of the display not being the most ideal in function and misinformation from your friend.
Check the other thread for an in depth response w/ picture.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 02-22-2013, 09:28 AM   #58
roadtrip1098
My Ride: 06 STi
what should i do?
Get that code read, more than likely it will give you an idea of the faulty part. You can try the soft reset listed in the OP. My list of possibles on this would include the shift springs, gps, or even possible a wheel speed sensor (I know it sounds weird, but the wheel speed sensors do affect shifting)
Old 02-26-2013, 11:52 AM   #59
kiwami
My Ride: 04 ///M3 SMG
My car is giving me problems: stays in gear "solid" losses drive & it won't engage into gear until it is turned off & wait a few minutes.
I scanned the codes & it has two codes:
36 Selector angle (WW) position sensor evaluation
37 Shift path (Gear) position sensor evaluation
Is there anything I should test or try before ordering a new position sensor. And where is the more reasonable place to order it from.
I will try a new relay later on today.
SMG pump primes for about 7 to 10 seconds.
Update: I cleared the codes & tried to go for a test drive. backed it up in driveway & put it in first and it stayed blinking in N and the yellow SMG gear icon came on. Read the codes and the same two codes came back . turned it off and on and engaged 1st. then I just parked it & left it alone.
kiwami is offline   Reply With Quote
Old 02-26-2013, 02:49 PM   #60
roadtrip1098
My Ride: 06 STi
You can check the plugs for the gear position sensor, they are on the passenger side of the transmission and can get wet and stuff. Most likely the sensor is bad, but it never hurts to check, clean the connectors and stuff. I saw a thread last week where the GPS unit had actually been cracked and you are the 3rd person so far this year to have contacted me with errors that point to the gear position sensor.
