Old 02-01-2013, 07:08 PM   #21
jsanchez2791
My Ride: 2001 e46 M3
Agree with F1004fun
My 2000 323ci had the same problem. Ended up being the belt
Pulleys.
Cheap and easy fix
To test it take out your belt and try spinning the pulley, if
They free spin there are bad. They must be sorta stiff.
I believe theres a few DIY videos on YouTube
jsanchez2791 is offline   Reply With Quote
Old 02-05-2013, 10:24 PM   #22
yellow2000s/r
My Ride: 330ci
Originally Posted by jtshawtek View Post
i did no modifications. just put a k & n filter instead of factory filter.
Replace your belts and pullies, it's only $160 if you use all Dayco parts from Advance...
I had a similar squeal and then it turned into only squealing around 1200 - 3000 rpm at light to moderate throttle sounding like a supercharger. I changed my belts and pullies (2 ended up being bad) and now it's silent.
My CCV went bad last week and leading up to it, it didn't make any weird noises like this. Back in the summer/fall it did moan sometimes when shutting off the car instead of a clean hiss indicating it was about to fail/getting clogged.
yellow2000s/r is offline   Reply With Quote
Old 03-03-2013, 09:38 PM   #23
romania1991
My Ride: 2001 330XI
My car makes a noise kind of like a supercharger as well but only sometimes and only when the engine is cold. It goes away after a while...
-2001 BMW 330XI (Sold)
-2002 VW Jetta TDI
-2004 Audi A4 1.8T Quattro
romania1991 is offline   Reply With Quote
Old 03-03-2013, 09:44 PM   #24
ZHPinthe103
My Ride: 325i Black on beige
OP, where did you buy your m tech 2 bumper from? How did you install it?
ZHPinthe103 is offline   Reply With Quote
Old 03-03-2013, 10:17 PM   #25
yellow2000s/r
My Ride: 330ci
Pulleys. Replace them and the belts before a pulley locks up, you throw a belt, and you're stranded and/or overheat the engine and/or loose power steering.
Old 03-05-2013, 04:00 AM   #26
romania1991
My Ride: 2001 330XI
Ok thanks a lot. Around how much would I be looking at spending for changing the pulleys and belts?
-2002 VW Jetta TDI
Old 03-05-2013, 05:23 AM   #27
yellow2000s/r
My Ride: 330ci
$155ish is what I spent on both tensioner pulleys, the ider, and both belts from AdvanceAuto. I got all Dayco brand and did it myself in like 20 minutes. It's very easy on coupes, I read that sedans have a mechanical fan but haven't verified that. Coupe fan has a clip on one top corner and a bolt in the other, remove a couple harnesses from top passenger side and it lifts right out.
Old 03-05-2013, 02:07 PM   #28
romania1991
My Ride: 2001 330XI
Isn't there also different type of pulleys that free up more power or something like that? Should I get something like Rogue or Turner Motorsport pulleys?
-2002 VW Jetta TDI
Old 03-05-2013, 09:23 PM   #29
romania1991
My Ride: 2001 330XI
I think I'm gonna go with the Turner Motorsport ones.
-2002 VW Jetta TDI
Old 04-23-2013, 02:36 PM   #30
romania1991
My Ride: 2001 330XI
ok so I just got the Turner Motorsport pullies and belt, now I'm wondering if I should change the water pump too... How do I know if it needs to be changed?
-2002 VW Jetta TDI
