Old 06-20-2012, 10:58 PM   #1
Koffinb
My Ride: 04 330xi 6spd
tips for a college kid
No, im not the average spoiled rich college kid, this is my first vehicle i purchased in my own, and i drive it responsibly. ok so i'm a college student going away next month..3 hours from home. I wanted to get some advice from you guys as to what kind of maintenance to have done, here's some info About the car:
04 330xi 6spd 112k miles
cooling system is done
VCG, cv joints replaced at 100k as well as pads and rotors all around
-106k oil change, pulleys, control arm bushings
-111k oil change, spark plugs (my fist diy)
Anything else I should look out for to prevent an unexpected breakdown while far away from home? i.e. fluids?? I'll drop in a new air filter before I leave also, but I think I'll leave the oil for about 10k..lets see how this German castrol stuff holds up..
Koffinb is offline   Reply With Quote
Old 06-20-2012, 11:02 PM   #2
scrace
My Ride: 03.5 M3
Vanos o rings
rTABs
Check upper and lower intake boots
You sound up to par.
2001 Topaz Blue 325Ci 64-120k miles SOLD
2003.5 Silver Gray M3 70k miles
scrace is offline   Reply With Quote
Old 06-20-2012, 11:11 PM   #3
Koffinb
Originally Posted by scrace View Post
Vanos o rings
rTABs
ok..symptoms for the above parts?
Old 06-20-2012, 11:23 PM   #4
My Ride: Lexus
Honestly, my advice is to sell it. Kid+BMW+debt does not add up. At your stage in life, there are more important things to do than to be funneling a significant part of your funds into a 10-year old german car.
And German Castrol hold up? You realize what oil you're talking about, right? Other oils shudder at the mere mention of the name "German Castrol."
Old 06-20-2012, 11:26 PM   #5
Koffinb
debt??? where did I mention debt in my post? I'm not selling it, I just bought it 2 months ago and I believe i've worked hard and deserve to treat myself to something that means a lot to me a BMW
Old 06-20-2012, 11:28 PM   #6
LittleChrist12
My Ride: 2003 BMW 325xi
Welcome. I was a college student with 116k on my 325xi. It sounds like you've got most of the mechanical things taken care of. You might want to get a new fuel filter and changes your rear differential, transmission, and transfer case fluid. At that point, you should be set. After 112k miles, your suspension is probably a bit tired, but it isn't going to fail and leave you stranded.
As for what scrace mentioned, the rear trailing arm bushings (rTABs) will wear and allow the rear tires to wander in the corners. The car will feel loose and you'll get excess rear tire wear. The lower intake boot on our cars also gets brittle with age and can crack. This is usually accompanied with the SES light or a whistle under acceleration. Finally, the VANOS o-rings can go bad and make the car feel sluggish as you accelerate through the rev range. While this won't damage the engine, you'll lose performance and fuel mileage. You can probably hold off on fixing this until you need to replace the VCG again in the future.
Best of luck at school and enjoy the car!
2003 BMW 325xi
2010 BMW M3 Sedan
LittleChrist12 is offline   Reply With Quote
Old 06-20-2012, 11:28 PM   #7
My Ride: Lexus
So you're paying for your education in cash? Must be nice! Nobody said you don't work hard. You asked for tips, I gave you some.
Old 06-20-2012, 11:30 PM   #8
Koffinb
3rd year in college and paid everything out of pocket, seems like an exaggeration but its the 100% truth
Old 06-20-2012, 11:32 PM   #9
Koffinb
yes, i'll do the fluids for sure and i'll check on the rest thanks
Old 06-20-2012, 11:34 PM   #10
My Ride: Lexus
Sounds good to me!
Old 06-21-2012, 12:00 AM   #11
JayKayo
Account closed at users request
My Ride: 2005 330Ci ZHP
Send a message via AIM to JayKayo
"Average spoiled rich college kid?" Someone's jealous/bitter
JayKayo is offline   Reply With Quote
Old 06-21-2012, 01:22 AM   #12
Koffinb
not bitter at all, actually prod of myself that I was able to accomplish this by myself. I'll give myself a nice pat on the back
Old 06-21-2012, 01:29 AM   #13
325guy
Banned User
My Ride: 2003 325i stick
I have a 325i 2003 with 83,000 miles.
Its had regular oil services
At 83,000 miles
Oil change
Alternator broke then replaced
Bilstein struts replace oem struts all around
At 78000miles
Differential output shaft seals replaced
Brake service/ brake fluid
At 65,000 miles
Oil change
Valve cover gasket
Replaced lower control arm bushings
At 52,000 miles
Brake repair
Brake pads
Replaced drive belts
At 29,800 miles
Oil change
Oil level switch replaced
What should i be thinking about in maintenance. I know it was a women who owned the car before me and she traded in this car for a mercedes. She only serviced it at BMW of alexandria VA. What should i be thinking about??
Manual trans / diff fluid change??
Water pump pulley replace?
Pulleys replaced?
Fuel filter?
Cooling system?
What should i be thing about?
E46Mango?? Thanks
325guy is offline   Reply With Quote
Old 06-21-2012, 01:32 AM   #14
325inthe510
My Ride: 152ci of madness
"Average spoiled rich college kid" detected
325inthe510 is offline   Reply With Quote
Old 06-21-2012, 01:51 AM   #15
albarran9
My Ride: E46, E53, E90
I too am a college kid. The best thing I did is get a code reader. I have the Peak and BMW scanner 1.4. It's helped me out a lot when trouble shooting issues. It let me know that my pre-cat O2 sensors were going bad. My sedan has 111k on it. I started with the cheapest DIY's and worked my way up because I didn't have all the tools accumulated yet. With a simple craftsman mechanics tool set I was able to do most of them. With our cars being high milage cars, the rubber is the first thing to look at. I checked all my hoses and VCG and replaced most of them after inspection. Don't forget to change your power steering fluid if you havent already. Pretty easy to do with a transfer pump and not expensive. Fuel filter is critical one to do as well.
albarran9 is offline   Reply With Quote
Old 06-21-2012, 03:56 AM   #16
JayKayo
Good job then!
Old 06-21-2012, 04:24 AM   #17
Chris-TK
My Ride: Mk VI GTI
Buy beer.
K.
Chris-TK is offline   Reply With Quote
Old 06-21-2012, 04:31 AM   #18
Toxx
My Ride: 2000 323i
Originally Posted by Chris-TK View Post
Buy beer.
+1 Busch light isn't going to pay for itself, ATO reppin
Toxx is offline   Reply With Quote
Old 06-21-2012, 05:11 AM   #19
Lusticles
My Ride: 325Ci
I feel like every one of these threads starts off the exact same; "No, I'm not the average spoiled teenager, I paid for this car all on my own...." then something along the lines of blah blah blah something covered in 3,000 other threads blah blah blah.
For what it's worth I make ~3 hour trips quite often and never feel the need to perform any big maintenance beforehand. Check the tire pressure, oil level, and your car should be good to go.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 06-21-2012, 06:57 AM   #20
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Take your tools with you and don't worry so much. Maybe source a local diy garage...make local friend with garage and swap diys for garage time.
Find local female with garage...swap fluids with her and you should be good to go!
Facebook.com/DMAXstandup
Mangofy your E46!
