Sponsored by The Tire Rack
Old 06-21-2012, 12:10 AM   #1
vorceb23
My Ride: 04 330i
Squared vs staggered?????
hate to sound like a noob, but can someone please explain to me the difference between squared and staggered wheels- and maybe some pros/cons to each? thanks
vorceb23 is offline   Reply With Quote
Old 06-21-2012, 12:18 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Square:
con - rear tires are smaller and look not that good, slightly less grip on the rear
pro - you can rotate the wheels very easily if you dont have one direction tires
Staggered:
con - can't rotate around as with square, rear camber will get to the tires faster, tires cost more
pro - better grip, looks better
Old 06-21-2012, 12:40 AM   #3
vorceb23
My Ride: 04 330i
Is there any difference in terms of appearance? It sure didn't seem like it....
Old 06-21-2012, 12:49 AM   #4
scott0482
My Ride: 2001 530i, 1997 M3/4
Send a message via AIM to scott0482
On my wheels the rear wheels have a deeper lip which looks better. On some wheels you can't really see any difference.
Sent from my Touchpad using Bimmer App
scott0482 is offline   Reply With Quote
Old 06-21-2012, 04:30 AM   #5
Reloader
My Ride: 2000 323Ci
the rear wheels are often deeper or have a deeper concave when you have a staggered setup, if you have the choice go staggered it looks 10000 times better
Dutch
Reloader is offline   Reply With Quote
Old 06-21-2012, 05:24 AM   #6
steve.k
My Ride: 05' 325Ci, 13' WRX
Example square set up;
F: 18x8.5"
R: 18x8.5"
Example staggered set up;
F: 18x8.5"
R: 18X9.5"
I.e. rear wheels usually wider.
And then you have to take into account offset, too.
steve.k is offline   Reply With Quote
Old 06-22-2012, 11:10 PM   #7
Steven747
My Ride: 05 330ci
my sig is squared with 225 all around
Old 06-26-2012, 06:04 PM   #8
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Note that you can also run spacers in the rears if you are on a square setup to push the rears out a bit and at least give the appearance of staggered, to an extent
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
csl, rims, squared, staggered, wheels
