Old 06-22-2012, 12:11 AM   #1
2002redE46
My Ride: 02' 325i Red
E46 sedan engine bay smoking.
the car:
2002 325i
132,000 mi
so I was driving the car for about an hour around town and noticed that the engine bay was starting to smoke. I opened the hood and white smoke was coming from the back passenger side of the engine. the car also smells like burned plastic when it's off. occasionally I get the yellow oil light when I turn the car off. the cars last oil change was 2,000 ago. it was also recently repaired for an oil leak. anyone know what the heck is going on with this? could it be the vanos?
2002redE46 is offline   Reply With Quote
Old 06-22-2012, 12:21 AM   #2
supercrew90
My Ride: 03 bmw 330
Valve Cover gasket for sure this happen to my car the other took it a mechanic and said that was the problem yup seems like burnt plastic nasty smell
[SIGPIC]
supercrew90 is offline   Reply With Quote
Old 06-23-2012, 12:12 AM   #3
Jets330
My Ride: scrapes alot
Well ya got your oil gasket cover repaired? perhaps you forgot about the valve cover gasket. jus recently replaced mine, had the same problems as you. my oil light came up every so often, and leaked.. more then to my likings, if any at all. valve cover gasket isnt a big job, theres plenty of DIY's, about a 30 minute job for me, jus needed to let my car sit to let the sealent dry. 200$ fix, or so.
Jets330 is offline   Reply With Quote
