Old 06-22-2012, 10:14 PM   #1
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Scored an aluminum radiator!
Had to show it off...never guess how much I paid for it.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-23-2012, 11:51 AM   #2
paraklas
My Ride: ESS TS2 320ci
$109.10?
Have you fitted it yet?
Old 06-23-2012, 07:18 PM   #3
bigjae1976
bigjae1976's Avatar
Not yet. $350! I couldn't believe it!
Old 06-23-2012, 07:32 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Slut!!!
Old 06-23-2012, 08:53 PM   #5
K'KamE46
My Ride: 323
Lucky u man.... ive been looking for one. Cheapest one goes for 1300 plus...
Sent from my HTC Glacier using Bimmer App
IN PROGRESS....
B&G SPRING I ANGEL EYES I M3 REP F. BUMPER I E90 RIMS I
AEM COLD AIR INTAKE I
K'KamE46 is offline   Reply With Quote
Old 06-23-2012, 10:29 PM   #6
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Wow. Nice
Sent from my Kindle Fire using Bimmer App
Old 06-23-2012, 10:34 PM   #7
B_Cyrus
Banned User
My Ride: Malfouf
I like the expansion tank/reservoir.
B_Cyrus is offline   Reply With Quote
Old 06-23-2012, 10:44 PM   #8
Russian172
My Ride: e46 sedan e46 m3
Looks fail proof
I got mine a regular one for about 150$ is that too low ? By the way it was made in boulgaria Mmmm quality
Russian172 is offline   Reply With Quote
Old 06-24-2012, 07:34 AM   #9
bigjae1976
bigjae1976's Avatar
The one head scratcher is you need to T in the heater core return hose to the feed line. Cost cutting?
I will post a review. Might be worth it for a track car. Otherwise stay OEM. Unless you can find a used one...which i've only seen one. Zionsville sometimes has warehouse specials for about $1000
Old 06-25-2012, 12:00 PM   #10
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Can't tell from the photo - one or two rows? Since mine is FI I am always looking for cooling solutions. Already have an automatic transmission external cooler.
Jim
Jim Murphy is offline   Reply With Quote
Old 06-25-2012, 03:35 PM   #11
bigjae1976
bigjae1976's Avatar
Can't tell. Its the same thickness as the OEM radiator though.
Old 06-25-2012, 06:41 PM   #12
sedanpowersc
My Ride: 330i 5 speed
Never have to worry about expansion tank blowing, lucky!
| BB Gen 3 Headers | Cosmos Racing V2 CAI | Muffler Delete | RE Underdrive Pulleys |
| 3.46 Diff | Tein S-Tech | Bilstein Sports | Hawk HPS | ASA AR1 | 35% Tint |
sedanpowersc is offline   Reply With Quote
Old 06-25-2012, 07:57 PM   #13
Blocked Out
My Ride: Imola 330i M-Sport
Which Et cap does it use ? And what pressure does it run at if it uses its own cap? if you know
Would it accept an OE like cap? Very interested to know
Is it Zionsville or Misumoto?
At the price you got it, its very nice and very usefull BUT make sure you pressure test it BEFORE You put it on. And pressure test it to DOUBLE psi then what you currently run. I dont know what pressur eyou run in your system but make sure you test to double what you run now.
I say that because alot of E39 guys blow though Zionsville rads like crackers at a cheese party.
Keep me up to date please
Original BMW Teile ///
IMG_1725
Old 06-25-2012, 09:20 PM   #14
aggieE46
Keep it clean
aggieE46's Avatar
Really? For the price you'd think it'd outlast the car.
Old 06-25-2012, 09:29 PM   #15
Blocked Out
Thats what thought as well.
Its not a concern for any of the M5X E39 , only M62 E39s are having this problem.
Some think its because of the torque the car makes some think its the combination of that and the placement of the "out" nipple on the rad itself .
With anything used you'd want to double check it before you put in on your car and a rad is gotta be the easiest thing to check
IMG_1725
Old 06-25-2012, 10:18 PM   #16
bigjae1976
bigjae1976's Avatar
It is a zionsville.
He did a pressure test but I will take your advice and do one as well. I do have to buy a 30psi stant cap for it.
Old 06-26-2012, 09:21 AM   #17
Jim Murphy
Originally Posted by bigjae1976 View Post
It is a zionsville.
Would a good radiator shop do a pressure test for you if you handed it to them?
Jim
Old 06-26-2012, 12:02 PM   #18
Blocked Out
It is a zionsville.
Go down to 20 psi cap. I have a 20 because i think 30 is a bit much
Sent from my X10a using Bimmer App
IMG_1725
Old 06-27-2012, 08:26 AM   #19
bigjae1976
bigjae1976's Avatar
Jim
I'll just install it and take it to the shop. The radiator is pretty easy to install. The original owner already did one so I'm no super concerned.
I just have to figure out my fan situation...may have to pony up some more $$$ to get the Zionsville wiring kit. So should I go for the single or dual speed fan? What's the benefit of the dual speed? I assume that the high speed on the dual is the same as the single speed?
Old 06-27-2012, 11:57 AM   #20
Blocked Out
Get a separate switch for the fan so u can cool the engine at the pit between runs
IMG_1725
