Old 06-23-2012, 04:56 PM   #1
SkBuMmEr
My Ride: E46 convertible 325
e46 325ci how do i make my key open the windows without putting in the key
e46 325ci how do i make my key open the windows without putting in the key, it works right now if i put the key in and it opens windows and my top, but i know there is a way to do it without putting in the key and just holding the button down. Please let me know
SkBuMmEr is offline   Reply With Quote
Old 06-23-2012, 05:30 PM   #2
blksab65
My Ride: 323i Touring
im interested in this to, my dad can do it with his 5 series. i think with the 3 series you need to buy that program tool to add those kind of features such as the blinkers blinking when you lock/unlock.
blksab65 is offline   Reply With Quote
Old 06-23-2012, 05:33 PM   #3
maurer
My Ride: 04 Coupe
press your unlock button one time, then hold it down the 2nd time until all of your windows and sunroof are open.
maurer is offline   Reply With Quote
Old 06-23-2012, 06:12 PM   #4
Crestwood1001
My Ride: 2001 325xi
Once all doors are unlocked hold the button, I hate it and never use it cause it always tried to open the sunroof, I always leave my sunroof tilted so that bothers me
Crestwood1001 is offline   Reply With Quote
Old 06-23-2012, 11:20 PM   #5
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
see here:
delmarco is offline   Reply With Quote
Old 06-24-2012, 02:37 AM   #6
Vigilante
My Ride: 320i - 2.2 L - 170hp
Send a message via MSN to Vigilante
I can only comfort close my car I tried opening the same way I close (holding button) but didn't work.....
320i Executive Sedan | E46_AV11 | ZF5HP19 S-t | M54B22 | 170hp 210Nm | 09/2000 | 171k | 32.9 MPG
Maintenance
Re-surfaced CH | VC+VCG | CAM/VANOS timing | IMG | NGK-i | BAT+ALT | O2's | GM5 | WP WPP | PSP | DISA | TB ICV MAF | CCV | CAI | OFHG | FP | FF | A/C | FSU | AUC | WSS | BL BD BP | Mango | JFOJ | SB TP IP | springs | Shocks | tires | ASC+ | alignment | E.Flush | Castrol SAF-XJ 75W140 | ZF LGF5 ATF Flush | FCA+FCAB | Struts
Vigilante is offline   Reply With Quote
Old 06-24-2012, 03:00 AM   #7
Drew@Swift Motorworks
Past Site Sponsor
My Ride: Scooty Puff Jr
lol... just press and hold your unlock button
Drew@Swift Motorworks is offline   Reply With Quote
Old 06-24-2012, 04:04 AM   #8
M3JetBlack
My Ride: 2002 M3
I learn something new on this site everyday...
I am going to have to try this out tomorrow! Never really noticed it cause i am just so excited to get in the car and drive!
2002 JetBlack ///M3
CCW Wheels / GC coilovers / Alcon / Eisenmann / SuperSprint / Vorsteiner / HPF Stage 2
Instagram: @somuchcalitis
M3JetBlack is offline   Reply With Quote
Old 07-03-2012, 04:12 PM   #9
SkBuMmEr
I have the convertible and still only works when you put the key in. Is there a way to get it reprogrammed
Old 07-03-2012, 04:33 PM   #10
FenderGuy05
My Ride: 2002 BMW 325i
PA soft 1.4
I tried this on a friends convertible, didn't get the windows to roll down and up, but I did get it so his top would fold and unfold with the remote. I didn't have a lot of time.
FenderGuy05 is offline   Reply With Quote
Old 07-03-2012, 04:40 PM   #11
tock172
My Ride: '12 135i DCT
I'm located in San Diego and I have the device which can program your car to have the windows go both up and down with the keyfob.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 07-03-2012, 05:14 PM   #12
SkBuMmEr
Sd kinda far. Anyone in Los angeles that can do it.
Old 07-03-2012, 05:22 PM   #13
tock172
There are better places to ask around than this thread.
Old 07-03-2012, 06:14 PM   #14
SLVRgrau
My Ride: 330 Ci '05 ZHP
I've had my ZHP a 'lil over 1 year and I just discovered I can roll down windows and open/tilt sunroof while pressing the unlock button a second time for a few seconds. Pretty cool. Now I wish I could do the same for rolling-tehm up.
SLVRgrau is offline   Reply With Quote
Old 07-04-2012, 03:44 PM   #15
TRIPLE_O
My Ride: E46 Coupe
You need the proper software or someone with the proper software.
________________________________________
BMW Coding, PM Me For Details
3 Series Owners Manuals
http://www.bmwsections.com/docs/3series/
For Sale (Exterior Lights)
_________________________________________
Originally Posted by gonzaga707 View Post
My boyfriend left on vacation and left me his 95 328i for me to use while he is gone. He had 2 keys, I lost both of them this week...
..sincerely Jenny
TRIPLE_O is offline   Reply With Quote
Old 07-04-2012, 03:48 PM   #16
E40SICK
My Ride: 2001 330ci
i had all of that but recently lost the auto up. what happened?
E40SICK is offline   Reply With Quote
Old 07-04-2012, 11:26 PM   #17
oates
My Ride: 2004 320i
Works to put down windows...hold unlock
doesn't work to lock windows...hold lock (gotta turn/hold key)
Is that normal?
oates is offline   Reply With Quote
Old 07-05-2012, 06:19 AM   #18
jfoj
My Ride: 330CiC, M5, X5
Not all cars support all features, but in any event you need software to program these features. PA Soft BMW Scanner 1.4.0 is typically the easiest to use. $32 from www.xcar360.com, it is a knock off of the original but works fine. Takes about 2 weeks to get. Be careful as it is software an can be tricky to install on Vista & Win 7, 64 bit OS is even trickier. Easiest to install on XP.
As for features, you program things like not to open the sunroof or not to close the sun roof. You can also program other features on the car as well.
Slvr46, you probably need to re-initialize you window pinch protection as you have probably had your battery disconnected to too long of a period recently?
Read in your owners manual about the resetting the window pinch protection and your Auto Up feature should work again.
Old 07-05-2012, 09:46 AM   #19
E40SICK
My Ride: 2001 330ci
no the battery hasnt been since i have bought it... about 4 months now. but i will try that.
Old 07-07-2012, 06:41 AM   #20
azshorty
My Ride: Hellrot 323CI
does anyone remember how to reset the key when it stops working? i remember being a link that i used in the past to reset mine, but cant find it.
azshorty is offline   Reply With Quote
key, open, windows
