Spark plugs - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-24-2012, 12:46 PM   #1
Livinbau5
My Ride: 2003 BMW 330i
Spark plugs
I changed my spark plugs on my 330i zhp. It used to rev at about 500 rpm and now it revs at different rpms between 500-1200. I got iridium ngk plugs and they had a different tip than the stock ones. The iridiums had 1 prong on the end and the originals had 4
Bau5
Livinbau5 is offline   Reply With Quote
Old 06-24-2012, 06:24 PM   #2
BobbyC
My Ride: 2000 328I
You mean IDLE??? Did you set the spark plug end gap when you did them???
BobbyC is offline   Reply With Quote
Old 06-24-2012, 06:33 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
There is no reason to set any gap.
OP, you need the one with 4 prongs. It came in our car for a reason.
Old 06-24-2012, 07:43 PM   #4
325guy
Banned User
My Ride: 2003 325i stick
Some people are so dumb about aftermarket parts that are totally different and might work in a honda
325guy is offline   Reply With Quote
Old 06-24-2012, 08:15 PM   #5
Livinbau5
You guys are ...... I went to napa and asked for spark plugs they guy gave me the ones he said were for my car. So i installed them
Bau5
Old 06-24-2012, 09:37 PM   #6
Blocked Out
My Ride: Imola 330i M-Sport
No man, you are fvcked . People are trying to help you and you ignore the help.
Anyway, you problem is NOT the plugs, your problem is that you dont know how to work on cars becaseu you forgot to reconnect something and now your car limping and idle surging.
Our cars do NOT need iridium plugs in fact its recommended AGAINST them for stock applications.
But if one were to install them it will NEVER cause the problems you have!
You should learn how to follow advice and learn how to work on cars.
Good luck
Original BMW Teile ///
IMG_1725
Old 06-24-2012, 09:59 PM   #7
mre
My Ride: too many to list
You guys are ....... I went to napa and asked for spark plugs they guy gave me the ones he said were for my car. So i installed them
Going to napa for BMW parts is the first mistake
mre is offline   Reply With Quote
Old 06-26-2012, 05:50 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
Nice way to talk to those that are trying to help you.
Old 06-26-2012, 07:21 PM   #9
Livinbau5
I appreciate the help but the rudeness is unnecessary
Bau5
Old 06-26-2012, 07:25 PM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
So report that ONE persons post and don't refer it to the "guys" above that person.
Old 06-26-2012, 07:29 PM   #11
325guy
Banned User
Hahah you slut!
Yea but seriously just replace with NGK spark plugs from turner or ecstuning.com
Old 06-26-2012, 07:30 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
I am in a way
Yup, OP just get the NGK plugs and you will be set.
Old 06-26-2012, 08:14 PM   #13
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP, I'm sort of thinking that that one jerk in your thread might be right...and Blocked is often helpful and I think you might have taken his directness for rudeness. I say that because I often say what I think too and am often thought of as a moron!
Although you do have the wrong plug, and should check to see what gap it comes with...probably within our tolerance.
But that idle surge sounds like the result of either a bad/dirty icv, intake leak, or you did forget to plug something back in.
Not sure what you might have unplugged if you only did the spark plugs, but if you did other stuff too, let us know and we can maybe point you to other places to look for leaks.
Did you do other work along with the plugs?
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 06-26-2012, 11:11 PM   #14
325guy
Banned User
DMAX where is a good DIY for replacing the spark plugs. Im scared but a good diy could make me do it.
Old 06-27-2012, 03:45 PM   #15
dmax
dmax's Avatar
Read a number of the longer threads with 'spark plugs' in the title first. IDK where there's a diy for it.
Remove cabin air filter housing, engine covers, all the nuts (I think they're nuts...might be bolts) from the coils.
Unclip coils and pull up.
Blow out spark plug wells if you can...inspect for oil and remove with rag or something
Remove plugs with longish ratchet. If stuck, go to a longer handle.
Tighten new one down to when it hits the bottom, then maybe 1/4-1/2 turn from there...go by feel. You want them tight, but not crazy tight. Don't use anti-seize.
Probably should replace coil boots alone too...they come separate from the coil.
That's my amateur diy...probably forgot many things. Oh, have good led flashlight and magnet on a stick...and don't loose the coil nuts!
dmax on Facebook
Mangofy your E46!
Old 06-27-2012, 03:48 PM   #16
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I'm running NGK Iridiums. Car idles fine.
