Australia
Old 10-05-2012, 01:54 AM   #1
Hazey82
My Ride: M3
M Track Mode (MTM) on std M3
Anyone seen this and experience doing it?. Looks like its pretty easy,requires some coding and a little fiddling to get the software working which is where Im stuck
http://www.m3forum.net/m3forum/showthread.php?t=371119
I've managed to isntall BMW standard tools and EDIABAS 6.4.3 and loaded the e46 daten files but I'm getting Chassis error messages.
I'm also not sure if the bmw scanner cable I have will work with this either.
Would be a nice little feature add.
Hazey82 is offline   Reply With Quote
Old 10-05-2012, 03:29 AM   #2
CortinaD
My Ride: lots
Try different source for the chassis data, I ended up mounting my progman/sss disc and copying them across and that got winkfp working.
Do you have an EDIBAS cable?
CortinaD is offline   Reply With Quote
Old 10-05-2012, 05:39 AM   #3
Hazey82
My Ride: M3
Ive got what ever the cable is that came with bmw scanner. Where can I get another source for chassis data
Old 10-29-2012, 06:59 PM   #4
Ballistic325
My Ride: slow and steady
Hazey82 your problem is the scanner device - it is not compatible for use with NCS / SSS etc.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
