Old 05-12-2017, 04:20 PM   #1
jmland
My Ride: 2001 BMW 325xi
DIY coding for retrofit alarm
I installed a retrofit BMW alarm on my 2001 325xi Touring and now need to activate it. I was looking at getting the Schwaben BMW Scan Tool from ECS Tuning, but I can't figure out if it is capable to doing this coding to activate and configure the alarm.
Does anyone know if this tool will do the job?
I bought a BMW Scanner 1.4.0, but I have been unable to get the software to work correctly (the drivers will not register the device on my computer).
jmland is offline   Reply With Quote
Old 05-12-2017, 05:14 PM   #2
armenh7
My Ride: 2002 325i
Which version of windows do you have? Ftdi released drivers that won't work for the fake chips, so if you can, set up a virtual windows xp and then try
armenh7 is online now   Reply With Quote
Old 05-12-2017, 05:18 PM   #3
jmland
I have tried pretty much everything to try to get FTDI drivers to work, including virtual XP and running directly on an XP machine, but nothing is working, so I have given up on trying to work with the Scanner 1.4.0.
My main question is about the Schwaben BMW Scan Tool and whether it is capable of coding my retrofit alarm.
Old 05-12-2017, 05:22 PM   #4
armenh7
My Ride: 2002 325i
Why spend so much money on it?
I get home in ~1 hour. If you want, we can do a teamviewer session.
Old 05-12-2017, 05:29 PM   #5
jmland
Thanks, but I won't be home today. I might be able to do it this weekend if you're around.
Old 05-12-2017, 05:31 PM   #6
armenh7
My Ride: 2002 325i
Yeah sure no problem. Just pm me when you're ready
Old 05-12-2017, 05:40 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
You MUST plug the interface into the cars OBDII port for the final drivers to load. The car does not need to be on.
The issue is the chipset is NOT fully powered by USB, parts of the interface are powered from the OBDII port.
This causes EVERYONE problems.
