Thread Tools Search this Thread Rating: Thread Rating: 268 votes, 4.97 average.
Old 09-04-2012, 08:10 PM   #241
RangerDave
My Ride: '00 328i ZSP w/ 214k
My gas mileage has gone up since I installed a new fuel pump last month, but I don't understand why. I used to get 32-33 mpg on the freeway, and now I am consistently getting 36-37 mpg. Any thoughts?
BMW - Suzuki - Jeep
RangerDave is offline   Reply With Quote
Old 09-04-2012, 09:21 PM   #242
Stinger9
My Ride: '04 330Ci
Age old trick: Someone's sneaking gas into your tank at night to make you believe it's possible to get that kind of mileage that no BMW e46 can get.
Ooooor... You're driving all your miles downhill.
Old 09-04-2012, 09:28 PM   #243
jfoj
My Ride: 330CiC, M5, X5, E93
Those figures sound VERY optimistic to me.
Your mileage may have well improved due to more stable fuel pressure with a new fuel pump allowing for a better spray pattern, vaporization and fuel distribution. But again, I am doubtful you are getting the values your OBC is reporting?
Suggest you track your fuel economy the good old fashioned way by noting the amount of fuel put in the car and dividing the miles driven by the amount of fuel used.
If you have a smart phone, you can get free apps that allow you to easily log and trend your fuel mileage.
Old 09-05-2012, 03:37 AM   #244
MJLavelle
My Ride: 2001 BMW 330ci
My thoughts would be that your figures are coming from the gauge on the dash, which is nothing more than a vacuum operated (IIRC) guesstimate.
You need to do a real measurement by filling up, resetting your trip odo to zero miles, and driving. Then, top up your tank again, and divide the exact number of gallons you put in by the number of miles traveled.
Anything else, including the gauge or the instrument cluster computer, is just a guess, and not accurate.
There was a guy a few months ago making similar claims about milage, and it turned out he was just going by the gauge, and not really calculating the real number. He had several people freaking out, and a lot of others scratching their heads until I finally asked exactly how he was getting his numbers.
If you are correctly calculating your numbers, then they are extremely good, if not too good to be true.
If you are going by that silly gauge, then I can do one better. I hav seen more than 50mpg on my car for seconds at a time.
Old 09-05-2012, 03:42 AM   #245
MJLavelle
The second part of this old trick is even better. You are supposed to do this to a new car owner. After he starts bragging about his crazy high MPG's, you start removing gas each night, until he takes the car back to the dealer and says "I was getting 55mpg on this car, and now it is down to 9mpg! What the Hell is wrong?"
Old 09-05-2012, 09:17 AM   #246
Stinger9
My Ride: '04 330Ci
I'll go you one better. Driving out west I've actually gone from a high elevation area to a lower one over the course of thirty or forty miles where the OBC reading was in the high forties!
And I also maintain that no e46 comes close to even getting in the high thirties on an inaccurate OBC!
I knew the second half of the gas trick. Was just leaving it out to try and show a bit of compassion.
Story first made the rounds big time back in the sixties.
Old 09-05-2012, 11:30 AM   #247
///MPR77
My Ride: 02 ///M3 Tri-Ped
I can get mine to say 99mph.
I can't remember if it displays triple digits, but I have done it.
And it will for those moments, be accurate.
Old 09-05-2012, 07:28 PM   #248
epistaxis2008
My Ride: 2002 330ci
r u kiddin me???
epistaxis2008 is offline   Reply With Quote
Old 09-05-2012, 07:32 PM   #249
epistaxis2008
My Ride: 2002 330ci
with the price of gas these days i wish someone would do that for meee!!! (in a olde tyme hick voice or those dumb redneck comedians that people actually thought were funny a few years back)... hey dmax i see u have shows listed and ur a comedian or something like that...ur not one of those redneck funny guys r u???
Old 09-05-2012, 07:48 PM   #250
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I might replace the pump for the hell of it when I get back from vacation at the end of the month. 119k on the car. Filter replaced 30k ago.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 09-05-2012, 08:29 PM   #251
MJLavelle
Originally Posted by epistaxis2008 View Post
r u kiddin me???
Thanks! That is exactly what I wanted to say, instead of the logical explanation I wrote. It sounds like that fuel pump turned his car into a Prius! No fvcking way.
Old 09-05-2012, 08:33 PM   #252
MJLavelle
I actually heard that story in a documentary about comedians, and it was Johnny Carson telling it, so it is an old one for sure! And the 2nd half is the big payoff. You have to leave it in!
Old 09-05-2012, 08:36 PM   #253
MJLavelle
Yes, for those 10 milliseconds that the computer is measuring it, you are getting 99mpg.
Now you have made me wonder if it will hit triple digits.....
Old 09-05-2012, 10:25 PM   #254
Stinger9
My Ride: '04 330Ci
Now you're writing schtick for me from the land of Hee-Haw?
Was not trying to tell the joke. Other goals.
Old 09-05-2012, 10:56 PM   #255
///MPR77
Get to the top of a tall hill.
Reset OBC
drive gingerly, and you will see mpgs skyrocket I can't remember if there were three digits and if so there shouldn't be lol.
I might go check tonight for fun
Old 09-05-2012, 11:19 PM   #256
Stinger9
My Ride: '04 330Ci
Next guy who posts without definitively knowing whether there are three digits in the MPG OBC display gets banned for life!
Old 09-05-2012, 11:28 PM   #257
TrippinBimmer
My Ride: Just Fast!
Huh?
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 09-06-2012, 02:15 PM   #258
MJLavelle
You see this ( ) means I was kidding. So no, I was not trying to write jokes for you, but thanks for getting all agressive on me, out of the blue. Nice.
Just because I live in the south, does not mean I am from the south. I live in the 2nd largest banking center in the US, with NYC being the 1st. So, not a lot of HeHaw going on here.
You are more likely to run into an Indian or Chinese Analyst, or a New Yorker who got tired of paying $3k a month for a broom closet, so he moved here, where he could buy not just a real house, but a really large house, with land, for $2k a month. You would have to drive about 50 miles from the center of the city to find someone you could classify as "HeHaw" types, but they would still be the minority.
But thanks for the stereotype.
My wife is Latina, so I guess she looks like Sofia Vergara, and runs around in skin tight dresses yelling "Ay, Dios Mio!" all day, instead of being an SVP at Bank of America. Oh, BTW, that is what I do for a living as well, an SVP at BoA.
If we're going with stereotypes, I am going to guess you are - 80lbs overweight, you wear a track suit over a wife beater T-shirt to work, with lots of gold chains and a gold pinkie ring. And, as soon as you venture out of the State you stand around the whole time, loudly complaining to no one in particular that "the food here fuggin sucks! Its nowhere near as good as what we got back in NY, and ya know, everything is better in NY! I wouldin feed this sh!t to my fuggin dawg", as you smack your loser kid in the head.
Meanwhile, your wife, who still has gigantic '80's hair, fake nails, leather pants, 6in heels, and a leopard print shirt, only stops smacking her gum long enough to say "stop hittin him in the fuggin head like that! Yer gunna make him stoopider than he already is! Stinger Jr, get yer ass ova here, you know yer father is an aaashole when he's hungry" and then resumes applying her lipstich, and smacking on the same gum she has had in her mouth since 1979.
Old 09-06-2012, 02:36 PM   #259
Stinger9
My Ride: '04 330Ci
All the teasing here by me means little.
I love the South and Southerners. And the food!
Could see living there.
And think I don't get enough NY jokes?
Hmmmm..... who's the weasel that told you about the wife beating??
Good riff tho on your part!
EDIT: and if I neglected to throw in an apology if I misjudged the impact of what I said, I apologize.
Want to continue to go back and forth with you on the tech side.
Old 09-06-2012, 07:53 PM   #260
epistaxis2008
My Ride: 2002 330ci
it has 3 number spots or places as we are taught in 2nd grade but it is only 2 whole number digits then a decimal... so half of u are right as well as half of u are right and the rest of u are wrong...figure that one out!
And when I reset mine in 4th or 5th on the highway goin 50-70 mphs then let it coast downhill enough (usually coming down the other side of the Tobin Bridge on rte 1 N) to keep it at that speed without using the gas at all I can keep it goin for about 2-5 miles at 60 or higher. it'll stay at 99 till I hit the gas pedal again.
yeah,.... so,... mine gets 99mpgs without driving """GINGERLY""" (in an Austin Powers/Dr. Evil voice)
even tho... i gotta find my problem somewhere tho cuz at best I get 15-17 city and 20-25 highway... ima do the filter and flush the lines soon. checking the throttle body and fuel rack soon too
Rate This Thread
