Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
Old 06-25-2012, 08:49 PM   #21
Gensker6
My Ride: 330Ci
Thanks, guy, for the 'heads up' on the fuel pump. It wasn't on my radar at all. I'm at 8 years / 80k miles now. In the past, I admit I fell into the 'if it breaks, scramble to diagnos and fix' camp. Now that I'm older / wiser, I've moved into the PM camp.
I agree with others - just because a specific part hasn't completely failed, doesn't mean it's not been affected by mileage & age.
The difference between a new car and staying with an older car - with a new car you KNOW it'll start virtually every time, and handle tough situations. With an older car, it becomes more of a gamble with each passing year, unless a person is diligent and keeps up with maintenance....
Gensker6 is offline   Reply With Quote
Old 06-25-2012, 08:54 PM   #22
ryannel2003
Modded ///Member
ryannel2003's Avatar
My Ride: 2000 BMW 323i
My car is closing in on 142k miles so once I get the tires and some other odds and ends done with the car, I'll be doing the fuel pump next. I'm all about preventative maintenance here as I think the car will thank me down the road... plus I won't get stranded which would really suck.
2000 323i | Orientblau | 160k miles
ryannel2003 is offline   Reply With Quote
Old 06-25-2012, 09:20 PM   #23
328ci906
My Ride: 2003 M3
Sold my old 328ci with nearly 210k miles on the original fuel pump. Although had I kept it, the fuel pump was on my list for preventative replacement
2003 ///M3 6spd Jet Black/Cinnamon (I Loan Valve Adjustment Tools! PM me...)
328ci906 is offline   Reply With Quote
Old 06-25-2012, 10:10 PM   #24
TobyB
My Ride: 2004 325xit
Coming from the 2002 school of thought (no, not year, model) we just have sevaral cars each and a AAA card.
Catastrophic in my book isn't a fuel pump failure. That's just an inconvenience. When the cooling system explodes
and takes the head with it, THAT bugs me. So I replace the plastic garbage in the cooling system prophylactically,
and let the fuel pump die of natural causes...
It's a modern contrivance that your car should be infallible. 40 years ago, they died with regularity, and cell phones
were something that Buck Rogers had.
Each to their own, though... if you want to replace the pump, well, that's certainly not going to melt a polar ice cap...
http://xkcd.com/386/ seems to be pertinent today.
t
TobyB is offline   Reply With Quote
Old 06-26-2012, 12:42 AM   #25
2003 325i
My Ride: '03 Orient Blue 325i
agreed TobyB. 104K miles on mine and 10 yrs old. Original fuel tank. So far if I recall there's only been 1 fuel tank fail under 100K, proactively replacing it at 60K is flushing money away and proven mathematically by results posted in this thread.
Old 06-26-2012, 05:24 AM   #26
jfoj
My Ride: '06 330CiC, '03 M5
In order to be old and wise you must first have been young and stupid!
Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619
Lower hose fan switch O-ring - BMW #13621743299
Old 06-26-2012, 05:57 AM   #27
todd92
My Ride: 05 330i ZHP
120K miles. Original fuel pump, fuel filter, battery, cooling system, alternator. Whatever.
todd92 is offline   Reply With Quote
Old 06-26-2012, 08:02 AM   #28
Brinkley
My Ride: 99 328i, 02 325ic
Maintain your car how you like, and I and others like me will do the same. My fuel pump is older than anybody's in this thread and doing fine. What's with the attitude about how other people maintain their cars on here? Just because we don't change our cooling systems bi-weekly or our fuel pumps yearly we're idiots and we drive rolling piles of garbage? It always helps to insult those you want to convert to your way of thinking.
Brinkley is offline   Reply With Quote
Old 06-26-2012, 08:02 AM   #29
Sweetness
E46 is strong with this one
Sweetness's Avatar
My Ride: '01 325i
changed my last week at 132k. Still felt the same as Orig Pump, but doesnt sound as deathly
Sweetness is offline   Reply With Quote
Old 06-26-2012, 08:38 AM   #30
vinny323
My Ride: 325i
My Fuel pump on my 2004 325i died at 60,000 miles 2 months ago so it only lasted 8 years, I was lucky mine died in my garage.
vinny323 is offline   Reply With Quote
Old 06-26-2012, 09:27 AM   #31
Grand Superpatriot
My Ride: M54B30
Yes. Precisely.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 06-26-2012, 09:31 AM   #32
Grand Superpatriot
My Ride: M54B30
Good job. Change the fuel filter too, right? And the fuel pump relay?
Also keep in mind fuel pressure drops as your fuel filters age. Those of you with "dirty" fuel filters are driving around with low fuel pressure. This is obviously putting strain on the pump and everything else in your car. Same goes for everything else neglected/abused.
Old 06-26-2012, 10:11 AM   #33
Brinkley
Ah ok. Thanks for clearing it up for me. I'll let you get back to wasting your money on mindless PM now.
Old 06-26-2012, 11:04 AM   #34
sweetbro858
My Ride: BMW
The coupon code for BMA is SpecE30.
I replaced mine when my Cam sensor went out, and after reading Mango's preventative maint thread.
The ONLY trouble I had was seating the new pump. I realized it's A LOT easier to fit the gasket on the tank, and then slide in the pump... sweet jesus... just popped right in.
Question though about the Fuel Pump Relay: For a 2000 323Ci, the relay is in the glove box, behind the fuse box?
sweetbro858 is offline   Reply With Quote
Old 06-26-2012, 11:08 AM   #35
Grand Superpatriot
My Ride: M54B30
Glad you guys are paying attention. Lots of barnyard dancing shoes in the garbage... along with lots of old crusty garbage pile parts.
Old 06-26-2012, 11:24 AM   #36
TX78666
My Ride: 330i ZHP, N55 135i
157,000 miles, and counting, original pump.
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 06-26-2012, 11:27 AM   #37
mrmaico
My Ride: 04 ZHP, 05 R1200 GS
Any reason to get an OE BMW pump rather than the Siemens/VDO? Or are they the same thing minus the BMW logo.
mrmaico is offline   Reply With Quote
Old 06-26-2012, 11:28 AM   #38
Grand Superpatriot
My Ride: M54B30
Same thing minus logo.
Old 06-26-2012, 11:32 AM   #39
sweetbro858
My Ride: BMW
VDO is only $100...
Old 06-26-2012, 11:42 AM   #40
FenderGuy05
FenderGuy05's Avatar
My Ride: 2002 BMW 325i
Just recieved mine today, good project for after work. My coworker is letting me borrow his 330Cic right now, not a bad replacement.
It cracks me up how heated some people get about the PM threads. You want to wait until it fails, go ahead...if you want to keep your car from leaving you stranded replace it. To each their own. And Mango definitely doesn't say every other week, just every 60-75k miles...that's years if you drive "the average" 12k a year.
FenderGuy05 is online now   Reply With Quote
