Thread Tools Search this Thread Rating: Thread Rating: 268 votes, 4.97 average.
Old 11-27-2012, 08:21 PM   #501
668Ci
My Ride: 2.5 ASA Technik SKI
ok, left bank was 000 and right bank 170 ish...I filled up 2 gallons and the left side is still 000 and the right side is now 225. Yes the tank had 1/4 gallon and was there was enough fuel to cover most of the pump when I removed it. When I floor it and keep it above 3k the car stays on but dies once I depress the accelerator.
668Ci is offline   Reply With Quote
Old 11-27-2012, 08:26 PM   #502
jfoj
My Ride: 330CiC, M5, X5, E93
Left side will not start to fill until over 1/2 tank, do not worry about this now.
So you were able to start the car, but it dies above 3k RPM?
There must be more history here?
When was fuel filter last changed?
Old 11-27-2012, 08:44 PM   #503
668Ci
When I removed the filter, the fuel that was drained was pretty dirty from the back side. The filter was changed 50k ago on his car. He said his car was hesitating a little bit when accelerating that day he took it to work, and on the way home when gasing it a little on the freeway, it started to die and wouldn't start anymore once pulled over.
Old 11-27-2012, 08:48 PM   #504
668Ci
And the only way I can start the car is if I floor the pedal and keep it over 3k, after that it dies again. I was thinking vaccum leak but I checked all intake hose and throttle body boot and saw no crack. What I'm wondering is why there's no pressure at the fuel rail? It read's 0psi when on pos 2 and also 0psi when I crank it and gas it.
Old 11-27-2012, 08:53 PM   #505
Stinger9
My Ride: '04 330Ci
No offense, but I'd want to make sure that Schrader valve stem is being depressed when you screw on the gauge. Could take the valve out temporarily before you screw on the gauge.
And are we considering the ICV as a possible barrier to idling?
Old 11-27-2012, 09:01 PM   #506
jfoj
Turn engine off and depress the Schreader valve with a toothpick cut flat or something else to fit inside the test port. The fuel rail should hold pressure for hours. Watch your eyes, use a rag to protect the spray from going everywhere.
Old 11-27-2012, 09:11 PM   #507
668Ci
The valve was depressed. I just did the test on my car and the pressure was normal. But on his car, it is still 0.
Old 11-27-2012, 09:15 PM   #508
jfoj
Then you have a problem, back track, spare hose on pump output into a jug to make sure you have fuel coming out of the tank.
Did you get a pump assembly or just replace the pump?? Maybe wired backwards?
Old 11-27-2012, 09:16 PM   #509
murac14
My Ride: 2001 325i
Yes, it is a fully integrated pump with sending unit.
Is it necesary to change the passenger side sending unit
Sent from my PC36100 using Bimmer App
murac14 is offline   Reply With Quote
Old 11-27-2012, 09:22 PM   #510
668Ci
Got the pump from BMA, and I double checked the hose on the filter and pump. What could be the reason why the fuel rail is not getting fuel?
Old 11-27-2012, 09:24 PM   #511
murac14
My Ride: 2001 325i
Is it necessary to change the drivers side sending unit
Old 11-27-2012, 09:57 PM   #512
jfoj
Would not worry about the drivers side sending unit for now unless you are a stickler for PM. Easy enough to do in the future if you think you need to replace it.
I always use my trip odometer along with fuel gauge to determine when I should refuel.
As I am teaching my daughter who is just starting to drive, when the car is at 1/4 tank, it is time to fuel up. Mainly to keep from forgetting and then being in a rush and pushing it because you have to be somewhere.
Old 11-27-2012, 10:00 PM   #513
jfoj
I would put a spare piece of fuel line on the pump output and test to see if you are getting good fuel volume out of the pump, if not, pull the pump and see what is going on.
If you have good volume from the pump, then move toward the filter and try there.
30 second volume is just over 1 qt.
It is possible you got a faulty pump, but I do not think I have ever heard of anyone getting a failure out of the box.
Old 11-28-2012, 08:02 AM   #514
flyty017
My Ride: 2000 328IA
Ok I have been having these same issues with the car stalling. My problem seems to be the worst after the car has sat for a few hours. If i press the throttle and hold it at 1500 rpm for 3 to 5 min then the car is fine after that but if i dont it shakes then cuts off. I just replaced the fuel filter and the sending unit on the passenger side last night and still have the same issue. Ill be changing the relay later today. ANy one have any other suggestions?
flyty017 is offline   Reply With Quote
Old 11-28-2012, 09:06 AM   #515
jfoj
Likely not fuel related?? See the first link below in my signature.
Any codes? There should be.
Old 11-28-2012, 10:26 AM   #516
Stinger9
My Ride: '04 330Ci
Originally Posted by flyty017 View Post
Ok I have been having these same issues with the car stalling. My problem seems to be the worst after the car has sat for a few hours. If i press the throttle and hold it at 1500 rpm for 3 to 5 min then the car is fine after that but if i dont it shakes then cuts off. I just replaced the fuel filter and the sending unit on the passenger side last night and still have the same issue. Ill be changing the relay later today. Any one have any other suggestions?
Replace the sending unit on the passenger side??? Not so. The fuel pump is on that side and no one refers to this as the sending unit.
Please come back with all your details consistent.
Highly unlikely a relay could produce your symptoms. Pursue more probable solutions.
Old 11-28-2012, 11:31 AM   #517
flyty017
My Ride: 2000 328IA
Ok i miss spoke i replaced the fuel pump last night and i still have the problem. Do u have any suggestions or are u just gonna be a smart ass? All im trying to do is get my car running right. Im no machanic but im not scared to get under the car and diy either. I thought these forums where for getting info from others that shared the same passion not for being smart asses. If im wrong just let me know
Old 11-28-2012, 11:47 AM   #518
Stinger9
My Ride: '04 330Ci
Way too touchy son. Nothing in my post was smart ass. The only basis for knowing what is going on with your car is the details you post here. We can't see your car ourselves and we can't hear you speak. Big difference between the fuel pump and the sending unit.
Good luck with your problem.
Old 11-29-2012, 10:23 AM   #519
flyty017
My Ride: 2000 328IA
OK i WAS HAVING AN EMOTIONAL MELT DOWN DO TO MY CAR BEING Fd UP. oK SO MY 2000 328I IS STALLING IN THE MORNINGS. WHEN YOU ARE PRESSING THE GAS FOR ABOUT 5 MIN ITS FINE. IVE CHANGED THE GAS PUMP AND FILTER. ALSO IVE DONE THE VANOS SEALS.
Old 11-29-2012, 10:35 AM   #520
scarede46er
My Ride: 2001 BMW 325i ZSP
Have you read any codes? Why dont you first?
Rate This Thread
